To patch or not to patch
Discussion in 'General Tundra Discussion' started by kurtwp, Oct 16, 2017.
  1. Oct 16, 2017 at 7:06 AM
    kurtwp
    kurtwp [OP] What
    Kurt
    Charlotte, NC
    2016 Tundra Limited TRD 4x4 Off Road DC
    Since the screw is close to the outside wall can this be patched. Currently it does not appear to be losing any air.
    Kurt
  2. Oct 16, 2017 at 7:19 AM
    Under warranty? Take to dealership see what they say... Me, no patch
  3. Oct 16, 2017 at 7:21 AM
    That is a close one. I think the hole has to be 1” away from the sidewall.
  4. Oct 16, 2017 at 7:27 AM
    kurtwp
    kurtwp [OP] What
    Kurt
    Charlotte, NC
    I don't think screws/nails that insert themselves into tires are covered.
    Kurt
  5. Oct 16, 2017 at 7:34 AM
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    Plug it. Should be fine.
    CJ21 likes this.
  6. Oct 16, 2017 at 7:41 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    If it’s not leaking it’s possible the screw is too short to have punctured the tire. Until you pull it out you will not know. You may be worrying about fixing something that ain’t broke.
  7. Oct 16, 2017 at 7:48 AM
    kurtwp
    kurtwp [OP] What
    Kurt
    Charlotte, NC
    Well going to go out and tug on it a little and see if I can hear some hissing.
    Kurt
  8. Oct 16, 2017 at 7:54 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Wherever you take it will tell you if it can be repaired. Might be just the excuse you need for bigger tires. :D
  9. Oct 16, 2017 at 7:59 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Looks like it’s one of these:
    Pretty short
    4x4_Angel likes this.
  10. Oct 16, 2017 at 8:43 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    no Philips hole.
    More like one of these
  11. Oct 16, 2017 at 9:07 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    I had something similar at 3k miles so I had them patch the tire and swap the tire with the spare tire (they are the same). I wouldn't want to put 30k+ on that tire, but to use in a pinch on my spare rim was a sensible option. The $40 I spent on that was a hell of a lot cheaper than $200 for the new tire.
  12. Oct 16, 2017 at 10:33 AM
    CJ21
    CJ21 CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
    Plug It you will be fine!!:hattip:
  13. Oct 16, 2017 at 11:26 AM
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Take some soapy water and see if it's leaking, if not, pull the thing out. A shop won't patch it, but you could plug it.
    There is a difference between a patch and a plug FYI.
    I agree with @COMiamiFan the Philips head has probably worn off
  14. Oct 16, 2017 at 11:39 AM
    kurtwp
    kurtwp [OP] What
    Kurt
    Charlotte, NC
    I went to tug on the screw a little and heard air come out. Time to make sure I know how to use the tire jack and other tools on the Tundra to change the tire because you all
    know that the tire will go flat during a week long server thunder storm.
    Kurt
    Thegr8punkin and gosolo like this.
