To be or not be: Icon Mid Travel or LT
Discussion in 'Suspension' started by opitmus_tundra, Apr 29, 2019.
  1. Jul 7, 2019 at 10:01 PM
    #91
    tahoetrails
    tahoetrails New Member
    So for all the guys running spring under, how’s the durability been?
    Re-arching?
    Breaking?
    Dragging on the u bolt plate/threads?
    my soa leafs have been solid. Jw the maintenance for spring under.
  2. Jul 7, 2019 at 10:22 PM
    #92
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The spring pack is basically where the factory lower shock mount is. If that isnt dragging now it wont be an issue.
    I loved my sua on my last tundra. But sua setups typically have very low load carrying capacity
  3. Jul 8, 2019 at 6:22 AM
    #93
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    I believe @osidepunker had to have some insano 3" wide leafs made to carry the weight he does with SUA.
    zcarpenter92 likes this.
  4. Jul 8, 2019 at 6:35 AM
    #94
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    yes, I had to switch to 3" wide leaf packs. But I also weigh 8k lbs with 3900 lbs over the rear axle
  5. Jul 8, 2019 at 10:47 AM
    #95
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    I just realized The Truck's new name, since you gave us Komodo for our stubby legs.
    Dumbo
    Cuz it's fat as fuck, but somehow manages to fly.
    I tried to think of something cool like Komodo, but everything large that flies has a goofy name: Shamu, Gooney Bird, The Truck, etc...
    At least Dumbo is cute.
    TheBeast, d0zer, zcarpenter92 and 2 others like this.
  6. Jul 8, 2019 at 10:51 AM
    #96
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I would name it Bustard before I named it Dumbo
    But its always gonna be called the Truck
    joonbug, Vizsla and KevinK[QUOTED] like this.
  7. Jul 8, 2019 at 3:31 PM
    #97
    M C M
    M C M New Member
    You have to find a place to stuff a 2' tall leaf pack on each side.
    I still think for the guys looking for a "do-all" application, leaf springs are always going to win.
    Now if we really wanted to open a can of worms, we would start talking about air bags with reservoirs mounted on links for a true adjustable load carrying set up that allows the bags to cycle and compress without blowing up. Some crazy shit was tried back in the 70s/80s in off road racing.
    Sunnier, 831Tun and KevinK[QUOTED] like this.
  8. Jul 9, 2019 at 4:50 AM
    #98
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Lots of raptors are running a air shock in addition to a bypass in the rear. Seems like a great idea if you are always changing your loads or towing sometimes
    KevinK likes this.
  9. Jul 9, 2019 at 6:55 AM
    #99
    GravityGear
    Aurora, CO
    Has anyone ran bags AND hydro bumps at the same time?
  10. Jul 9, 2019 at 9:30 AM
    #100
    tahoetrails
    So what can the i96hd pack handle? It seems more worth it to get a pack built to specs with al the weight you’ll be carrying and weigh the truck+axle. I’ve just seen some saggy rear ends with lt. assuming those aren’t on purpose.
  11. Jul 9, 2019 at 9:42 AM
    #101
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Yes its best to weight the axle and let Jeff at Deaver make you a custom pack for your specific weight.
    But stock leafs are 2.25" wide and they are limited in how much weight you can build the pack for. At just under 4000 lbs for the rear axle (maybe 3700-3900), Jeff couldn't get them to hold the weight. Thats when I decided to switch to 3" wide leafs. I was able to build the packs thinner and still hold 4000 lbs
    Sunnier and joonbug like this.
  12. Jul 9, 2019 at 9:43 AM
    #102
    osidepunker
    Alex
    2013 Tundra DC 4x4
    A regular I96 pack is made for zero weight in the bed. The HD pack is made for a few hundred lbs
    joonbug likes this.
  13. Jul 9, 2019 at 10:07 AM
    #103
    tahoetrails
    Ok I assumed a few hundred. I like the direction you went with the 3” wide pack. How much thinner was the pack compared to the hd?
  14. Jul 9, 2019 at 10:11 AM
    #104
    osidepunker
    Alex
    2013 Tundra DC 4x4
    not much, about 3/4" thinner but I gained a 4" lift
  15. Jul 9, 2019 at 4:10 PM
    #105
    M C M
    M C M New Member
    We are doing a similar setup on mine and a friends tundra, but mainly for towing as they will be easily removable. depending on the room you have if you can have them cycle similar to the main shocks and not limit the travel, you can use them to help with load variance without affecting your performance. The only downside is you need to have nitrogen handy, and you have to fully droop the shocks everytime you need to adjust the pressure.
  16. Jul 9, 2019 at 4:11 PM
    #106
    M C M
    M C M New Member
    I96HD is 3-400, I96XHD is 5-600 roughly.
    Sunnier and 831Tun like this.
  17. Jul 10, 2019 at 5:21 AM
    #107
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Yep. I've always thought this is the perfect solution for someone who wants to load and unload their truck after every trip. Doesn't seem hard to cycle an air shock for full travel and its not a big deal to carry an n2 bottle. In fact, you could use some super soft leafs, like regular I96 and have a very nice ride. The air shock would keep your ride height and just valve it soft. Then, get a bypass with clickers and use that to control the dampening and use the clickers for when your load changes. haha if I was rich I'd be switching my setup right now...
    joonbug and Sunnier like this.
  18. Jul 10, 2019 at 9:18 AM
    #108
    KevinK
    Tundras to Sedona
    OK, new plan...
    4 link with ORI gas struts and bypasses - no leafs at all.
    I already carry a bottle of N2 on the truck at all times
    I almost went with ORI on the front, but shied away because I was concerned about heat induced gas pressure increase after long runs, but there's a tacoma in AZ running them and he does some extended runs and says the difference isn't noticeable.
    831Tun and joonbug like this.
  19. Jul 10, 2019 at 9:30 AM
    #109
    M C M
    M C M New Member
    Or maybe just make a 3.0 or 3.5 Air Bypass.... Would be a cool set up to try.
    831Tun and osidepunker[QUOTED] like this.
  20. Jul 10, 2019 at 9:38 AM
    #110
    KevinK
    Tundras to Sedona
    Well fuck - look at that magical beast.
    talk about solving some weight and clearance issues.
    Is that on a side by side?
  21. Jul 10, 2019 at 9:50 AM
    #111
    KevinK
    Tundras to Sedona
    Ha!
    I just looked at this closer and if I didn't know any better, I'd say you're pretty good at photoshop - but really it looks like the bastard child of an ADS bypass and ORI strut. I dig the idea.
    joonbug and 831Tun like this.
  22. Jul 10, 2019 at 12:55 PM
    #112
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I feel like school is in session.
    KevinK and joonbug like this.
  23. Jul 11, 2019 at 8:08 AM
    #113
    M C M
    M C M New Member
    ADS has had Air Bypasses for years, its more popular on smaller sand rails and such. That one pictured is something in the works for the Can Ams, it just happens to be bolted up on a RZR. They are pretty cool set up. They really help solve alot of the negatives associated with air shocks.
  24. Jul 11, 2019 at 10:53 AM
    #114
    KevinK
    Tundras to Sedona
    So you could, in theory at least, run a relatively lightweight spring under to get the travel and axle locating accomplished, and then an air bypass to get the load carrying and shock tuning ability.
    No links needed.
    hard-ons ensue.
  25. Jul 11, 2019 at 10:55 AM
    #115
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Stop repeating us
    joonbug likes this.
  26. Jul 11, 2019 at 10:55 AM
    #116
    GravityGear
    Aurora, CO
    I still feel like running a bag and cradle setup would be the most cost effective and fool proof method of getting it done. Not the most baller and not very good instagram like bait, but effective.
  27. Jul 11, 2019 at 5:55 PM
    #117
    KevinK
    Tundras to Sedona
    What am I repeating?
    831Tun likes this.
  28. Jul 12, 2019 at 5:20 AM
    #118
    osidepunker
    Alex
    2013 Tundra DC 4x4
    This:
  29. Jul 15, 2019 at 8:25 AM
    #119
    M C M
    M C M New Member
    Except SUA has alot of forwad and aft movement since the springs have so much arch. Air bags also would only support a certain portion of the travel. Air bags also don't like to be bottomed out, hence when they had resis on the air bags when they tried using them on the offroad trucks in the 80s.
    831Tun likes this.
