Tires very close to UCA need suggestions
Discussion in 'Suspension' started by Edier08, Oct 16, 2020.
  1. Oct 16, 2020 at 9:19 AM
    Edier08
    Edier08 [OP] New Member
    Is there anything that can be done for this? It’s hitting something when it pull into a steeper driveway at full lock.
  2. Oct 16, 2020 at 9:22 AM
    BUCS_KID88
    BUCS_KID88 New Member
    SPACERS!! Or offset wheels lol. Then need push bumper out with shims or just cheapest way heat up plastic... need to add some bump stop extenders aswell I can see they ain’t doing anything sitting high...
  3. Oct 16, 2020 at 9:28 AM
    Edier08
    I plan on keeping the stock wheels. Let’s talk spacers. Brand and size? Will this push the tires out just a hair
  4. Oct 16, 2020 at 9:29 AM
    BUCS_KID88
    betotundra likes this.
  5. Oct 16, 2020 at 9:30 AM
    BUCS_KID88
    Here you go I did it for you lol. This all you need
  6. Oct 16, 2020 at 9:31 AM
    Edier08
    Thanks for your help man greatly appreciated does @14burrito approve of this
    BUCS_KID88[QUOTED] likes this.
  7. Oct 16, 2020 at 9:32 AM
    BUCS_KID88
    Where are you located?
  8. Oct 16, 2020 at 9:33 AM
    Edier08
    Gulf coast Ms
  9. Oct 16, 2020 at 9:35 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    for the OE 18" wheels, I believe to achieve the best wheel offset a BORA 1" spacer works best...I will need to go and double check my notes and OE offset specs on those wheels you have.
  10. Oct 16, 2020 at 9:36 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    He doesn't need those bump spacers unless he added a shim or additional lift on top of his bilsteins. Bilstein provides a shim in the kit, he should use that for best performance.
  11. Oct 16, 2020 at 9:37 AM
    BUCS_KID88
    Oh dang I would’ve helped you but I’m in ATL. I was having same problem so decided to buy CB pro kit and came with everything, but didn’t use the spacers decided to buy sr8 wheels instead put me at +25 offset. Spacers will put stock wheels at +28 offset which about same. But wheels look better lol
    14burrito likes this.
  12. Oct 16, 2020 at 9:38 AM
    BUCS_KID88
    Okay
  13. Oct 16, 2020 at 9:39 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Just being honest and saving him $ from unnecessary HW. after all, he already bought it when buying the kit. bilstein figured out the block height, provided a shim to work best with that specific set-up.
    not trying to be a butt about it
  14. Oct 16, 2020 at 9:39 AM
    BUCS_KID88
    Okay
  15. Oct 16, 2020 at 9:40 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    lol
    Tundyfundy likes this.
  16. Oct 16, 2020 at 9:43 AM
    Edier08
    Thanks man! Braves looked solid last night
  17. Oct 16, 2020 at 9:44 AM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    Will a 1" spacer work without trimming the lugs? I thought that 1.25" was the min.
    @Edier08 spacers will push the wheel out and give more clearance between the tire and UCA and it may help with the swaybar. Stock wheels are a +60 offset and a 1.25" spacer will change this to about a +28 wheel offset.
    The downside to spacers, and pushing the wheel out, is that (as others have said) it could then cause rubbing on the front liner or possibly the cab mount behind the tire. If it rubs the liner, that is an easy fix to just push the liner forward. If it rubs the cab mount then an alignment with a good shop that knows lifted truck might help.
    FWIW, I have wheels with a +25 offset and I was rubbing the swaybar with 35x12.5 tires. It only rubbed at full lock and even then, not all of the time. 295s are a little narrower so you should be ok or once the tires are worn down a bit, the issue might go away (until you get new tires again).
    14burrito[QUOTED] and BUCS_KID88 like this.
  18. Oct 16, 2020 at 9:44 AM
    BUCS_KID88
    Lol I’m a rays fan. I’m from Tampa but work here in ATL but always go back. GO RAYS
    Edier08[QUOTED][OP] likes this.
  19. Oct 16, 2020 at 9:44 AM
    #49
    Edier08
    Thanks @14burrito you are the man. Let me know
  20. Oct 16, 2020 at 9:45 AM
    #50
    BUCS_KID88
    Couldn’t have said it better
    14burrito and sr5shark[QUOTED] like this.
  21. Oct 16, 2020 at 9:47 AM
    #51
    14burrito
    2014 SR5 CM 4x4 5.7
    Easier to just remove the swap bar and move on :)
    regarding spacers, yes i would agree with what you and @BUCS_KID88 stated with the 1.25" on the 60mm wheels. RW wheels are 50mm (which is what I run) and I was thinking 1" spacer on those to net 25 on the offset.
    JMB and sr5shark[QUOTED] like this.
  22. Oct 16, 2020 at 9:49 AM
    #52
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    lol - yep, my swaybar is off. Much better for off-road and with 700# springs on-road cornering is not too bad.
    14burrito[QUOTED] likes this.
  23. Oct 16, 2020 at 9:49 AM
    #53
    Edier08
    Decisions! I do like the spacer look because right now they are tucked into the fender well a lot and it might help the sway bar situation. Does it matter which brand for wheel spacers
  24. Oct 16, 2020 at 9:50 AM
    #54
    BUCS_KID88
    Bora or spidertrax only!!
    sr5shark and 14burrito like this.
  25. Oct 16, 2020 at 9:50 AM
    #55
    14burrito
    2014 SR5 CM 4x4 5.7
    personally never felt unsafe myself with 600lb coils and the bar off. its been removed since about 8k miles once the 5100s were installed.
    *removing the sway bar - end user is held liable for anything and everything. i am not responsible for anything that may happen*
    sr5shark[QUOTED] likes this.
  26. Oct 16, 2020 at 9:51 AM
    #56
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Either Bora or Spidertrax. You want a good quality hub-centric spacer.
  27. Oct 16, 2020 at 9:53 AM
    #57
    BUCS_KID88
    Got some boras 1.25 brand new in the box need them? LMAO
  28. Oct 16, 2020 at 9:56 AM
    #58
    Edier08
    I just might. Need to see what the cost is for parts labor etc
  29. Oct 16, 2020 at 9:58 AM
    #59
    BUCS_KID88
    Nah would be cheaper for you to buy online and do it yourself it comes with instructions or just YouTube lol.
  30. Oct 16, 2020 at 10:02 AM
    #60
    BUCS_KID88
    The only downside takes 4-10 weeks for boras to make to order or buy used ones from someone here.”I don’t like used lol”. Or spidertrax would ship faster but they are blue. That’s why I choose bora they black blends in with wheels....
