tires and factory 20s??
Discussion in 'Wheels & Tires' started by Bam69limitedcrewmax, Aug 27, 2016.
  1. Aug 27, 2016 at 4:43 PM
    Bam69limitedcrewmax
    Bam69limitedcrewmax [OP] New Member
    2008 limited crewmax 4x4 5.7L TRD
    2" leveling kit in front nothing to the back
    Can u put 35/12.50s on the factory 20" wheels??
  2. Aug 27, 2016 at 5:03 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I don't see why not. Might want to upgrade to a 9 inch rim for that extreme of a width though. Just to be safe. I'm sure others that are more knowledgeable than I am on this subject will chime in soon enough!
  3. Aug 27, 2016 at 5:26 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Check out the 295-65-20.
    They're a true 35" tire but closer to 11.5" wide.
    NewImprovedRon likes this.
  4. Oct 7, 2016 at 9:16 PM
    Asutton
    Asutton New Member
    Andrew
    2008 Tundra Limited
    3" level in the front
    I have 35x12.50x20 on the 08 limited 20s. They fit just fine on stock rims. You will have to space the tires away from the upper control arm. I have a 1.5" spacer, you should only need a 3/4" or 1" spacer with the stock rims. I went too big on the spacer
