Tire Wear
Discussion in '2.5 Gen Tundras (2014-2021)' started by MrMitch96, Jun 24, 2020.
  1. Jun 24, 2020 at 4:17 AM
    MrMitch96
    MrMitch96 [OP] New Member
    Mitch
    ME
    2014 Toyota Tundra SR5 TRD-Off Road
    Outside of my tires seem to be wearing more than the inside.
    When I bought the truck from Toyota it had 295/75/18s already on them.
    As far as I can tell Suspension looks stock.
    Truck doesn't pull one way or the other
    Drive 60 miles a day on the highway
    Going to need new tires before winter and would like this to not happen on a new set.
    Would like to avoid going back to stock tire size if possible cause the truck looks too good with them.
    Any ideas?
  2. Jun 24, 2020 at 4:25 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Get an Alignment. Your Camber is off.
    MrMitch96[OP] and ColoradoTJ like this.
  3. Jun 24, 2020 at 4:35 AM
    LML 3500HD
    Toyota’s alignment specs is pretty wide range when it comes to toe.
    Camber or toe is off.
    Pinay, Seafury and MrMitch96[OP] like this.
  4. Jun 24, 2020 at 8:27 AM
    pv355
    pv355 New Member
    Peter
    2018 CM SR5 5.7L 4x4 in Gray
    Installed: TRD Rear sway bar HIKARI Ultra LED H4 & HIKARI LED H11 Power tailgate lock JBL Stadium 5 + JBL GTO609c Kicker 43TCWRT102 in passive radiator box Waiting on install: Wishlist: Component speakers Leather seats + vented/heated Puddle lights Illuminated ignition ring ESP Rear seat storage Chrome grille delete Parking sensors
    I have the same problem with my stock 2018 crewmax with 30k miles. There was minor pull at highway speeds, but I didnt think it was a big deal. A week ago I started getting steering wheel vibrations at highway speeds. I got an alignment done yesterday and new tires today. So far so good, there is no pull or vibrations.
    Pic of my old tire and alignment below. I dont understand how the alignment got so out of whack?
    I found this video on uneven tire wear very informative. https://youtu.be/G3fsWXszSfY
  5. Jun 24, 2020 at 8:31 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Could be multiple different things. Pothole, curbs, worn out shocks or other suspension points. I'd assume with yours being an 18 that it was probably potholes or road conditions.
  6. Jun 24, 2020 at 8:40 AM
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    Is there a spacer lift on top of your coil overs? Looks like your bump stops got a little spacer mounted on them.
    MrMitch96[OP] likes this.
  7. Jun 24, 2020 at 9:04 AM
    MrMitch96
    Mitch
    ME
    Could be possible?
    I heard a spacer is needed for these size tires on stock.
    I'm not really sure what to look for to confirm what you're asking, I apologize.
  8. Jun 24, 2020 at 9:07 AM
    canadianguy
    Kevin
    Snap a pic of the top of your Coilover.
  9. Jun 24, 2020 at 9:45 AM
    pv355
    pv355 New Member
    Peter
    here's my 2018 stock suspension for reference. i dont know how different the 2014 models are.
