Tire wear with leveling kit
Discussion in 'Suspension' started by Dirtbikemike, Aug 14, 2015.
  1. Aug 14, 2015 at 12:54 PM
    Dirtbikemike
    Dirtbikemike [OP] New Member
    2011 Tundra Crewmax
    Leveling kit
    I have a 2011 Tundra 5.7 Crewmax that has a leveling kit. It seems to wear the outside of the front tires a lot worse than at stock height. Any ideas or suggestions would be greatly appreciated!
    Thanks,
  2. Aug 14, 2015 at 12:55 PM
    Welcome from CO. Have you had a re-alignment done?
  3. Aug 14, 2015 at 12:56 PM
    Dirtbikemike
    2011 Tundra Crewmax
    Leveling kit
    No, I have not...
  4. Aug 14, 2015 at 1:14 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Alignment is first thought.
  5. Aug 14, 2015 at 1:17 PM
    Dirtbikemike
    2011 Tundra Crewmax
    Leveling kit
    Thanks for the alignment suggestion! I will try that first.
  6. Aug 14, 2015 at 1:18 PM
    Dirtbikemike
    2011 Tundra Crewmax
    Leveling kit
    I am also wanting to put bigger tires as well. I'm wondering if I can fit 305 65R18's??
  7. Aug 14, 2015 at 1:43 PM
    csuviper
    Broomfield, CO
    Check here.
  8. Aug 14, 2015 at 2:42 PM
    Dirtbikemike
    2011 Tundra Crewmax
    Leveling kit
    Thanks, csuviper!! Very informative.
  9. Aug 14, 2015 at 5:06 PM
    Agreed with alignment first. Any suspension upgrades you should always do an alignment.
  10. Aug 15, 2015 at 8:46 AM
    chphilo
    chphilo Tundra addict
    Western PA
    What kind of leveling kit is it?
    For the most popular leveling kit (3/1), some popular sizes are
    35x12.5x18
    305/65/18
    295/70/18
    295/65/18
    285/65/18
    275/70/18
    (For 20 inch wheels, just subtract 10 from the second number--so for example, 295/60/20 is very close in size to 295/70/18)
    The key is the offset of the wheels. About 35 mm is the optimum offset for 9 inch wide wheels (the most popular width for after-market wheels). Lower you go, smaller the tires have to be in order to avoid serious rubbing.
  11. Aug 31, 2015 at 2:51 PM
    Tundrazy
    Tundrazy Turd Bro
    David
    '17 CM Cement PRO
    I had the same issue with the 2.5" leveling kit on my 2007. The outside edge of my Toyo Open Country's wore VERY prematurely even after getting it aligned 3 times in 3 years. Eventually I also developed steering wheel "shimmy". I paid way too much for the Toyos to have them only last 15000 miles. I finally took the kit off and went back to stock with Duratracs and they are wearing even after 15000 miles.
