Tire upgrade
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Airfire06, Sep 17, 2018.
  1. Sep 17, 2018 at 5:25 PM
    Airfire06
    Airfire06 [OP] New Member
    2016 trd pro
    Nothing yet
    Here it is before and after....295/70r18 nitto terra grappler G2 remove the front mud flap and that’s it. Stock height stock rims...no rubbing on insider fender damn looks so good and stoked on how it turned out...lmk if u got questions
  2. Sep 17, 2018 at 5:41 PM
    jagged155
    jagged155 New Member
    2018 Platinum Pro
    Debating if I want to do stock size G2’s or your set up. I’m concerned about the addition weight and rubbing off road. Can you advise ?
  3. Sep 17, 2018 at 6:53 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Are those the LT or P rated ones?
  4. Sep 17, 2018 at 6:59 PM
    Airfire06
    2016 trd pro
    Nothing yet
  5. Sep 26, 2018 at 11:31 AM
    Rhubarb Johnson
    Rhubarb Johnson New Member
    Rhubarb
    '17 TRD Pro Dbl Cab; Barc Red
    New windshield wipers....just getting started
    EXACTLY the look I want when it comes to replace the tires. And no rubbing??? GREAT!
    I LOVE the Pro, but honestly, the stock tires look way too small.
    Is the speedometer way off?
  6. Sep 27, 2018 at 5:55 PM
    Airfire06
    2016 trd pro
    Nothing yet
    Yea I jus got it and that was the first thing I changed...what do u mean by speedometer way off
  7. Oct 6, 2018 at 9:52 AM
    TrdUllrPro
    TrdUllrPro New Member
    Bozeman, MT
    2015 TRD PRO DC
    Fuel Vector 18x9, 295/70 Yokohama Geolander MT, AFE Dry Pro S Air Filter, TRD Air Flow Accelerator, carbon air filter delete, Firestone airbags, stubby antenna, inlay decals, WT mats, frogskinz center console, Leer topper.
    295/70 Yokohama geolander mt
  8. Jul 19, 2019 at 8:18 PM
    ncomeau35
    ncomeau35 New Member
    North of Boston
    2019 White Toyota Tundra TRD PRO
    Nitro Ridge Grappler 285/75/18
    nice set up, I just went with the Nitto Ridge Grappler 285/75/18
    jewsNbrews likes this.
  9. Jul 19, 2019 at 9:05 PM
    Cmilla25
    Cmilla25 New Member
    2015 Tundra Trdpro
    I went with 295/70/17 nitto Ridge Grapplers no rubbing just removed front mud flap20190718_132407.jpg
    Ely010606 likes this.
  10. Sep 30, 2019 at 12:56 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Stock rims or aftermarket? Trimming required? Thinking this size myself. Thanks in advance
  11. Sep 30, 2019 at 1:42 PM
    ncomeau35
    North of Boston
    The tires are mounted on the stock 18" TRD rims. I did have to remove the two small spats (flaps) on the inside of the front bumper (two 8mm screws I think) on each to remove. After that no rubbing
  12. Sep 30, 2019 at 1:43 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Sweet!
  13. Oct 6, 2019 at 4:19 PM
    GarTX526
    GarTX526 New Member
    2016 QuickSand TRD-Pro
    Many pending.....
    I’m thinking about going with the Readylift 2” lift just to add a little altitude and looking at this tire size. Thinking it will get me close enough to a 35” but eliminate need for BMC and other trimming. Any thoughts?
