Tire upgrade
Discussion in 'Wheels & Tires' started by MurphMan, Apr 15, 2025.
  1. Apr 15, 2025 at 6:35 AM
    MurphMan
    MurphMan [OP] New Member
    2025 Tundra LTD TRD
    Hi all, first post, appreciate your insights, getting lost with all the different info on google. I have the 2025 Limited TRD and the tires look too small. I'd like to go an inch to an inch and a half bigger but worried about rubbing etc. Any tire suggestion sizes and brands? Much appreciated.
  2. Apr 15, 2025 at 7:04 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Welcome!
    There are MANY good tires out there. Depends on what your needs are.
    Do you / will you tow? Heavy? Off road a lot?
    275/65/20 comes in at a tick over 34", fits on your stock 20" wheels. Someone else can confirm, but I believe these will fit fine without lift.
    The Nitto Recon Grappler is available in that size and is SL rated for load, instead of E. Makes for a lighter tire.
    One possibility of many.
  3. Apr 15, 2025 at 8:37 AM
    MurphMan
    2025 Tundra LTD TRD
    Thanks, BlackNBlu, I tow several items but nothing extremely heavy. I offroad to go hunting, fishing, and sledding. My understanding is the TRD package included a lift 1.75 inch lift hence the small tire look. I'm wondering if a 35-inch tire will give me grief and what width as most options seem to be at 12.5. Any experience would be appreciated. Thanks
  4. Apr 15, 2025 at 8:54 AM
    BlackNBlu
    Rich
    MN
    TRD Offroad (package) is NOT lifted from factory. Maybe you're thinking TRD PRO. (model)
    Yes, if you want 35's, it's advisable to do a "level lift" in front of roughly 1.5" to 2". Plenty of room in back at stock height.
    Some have fitted 35's at stock front height.
    "Skinny" 35's can be had, either a 35 X 11.5 or in my case I have 285/75/18's. (34.8 tall)
    A 285/65/20 gets you to 34.6, close to 35".
    Understand up front that 35's and a lift will drop your mpg by approximately 2 mpg.
    MurphMan[OP] likes this.
