Tire size with bilstein 5100 top setting
Discussion in 'Wheels & Tires' started by jetsweeps, Mar 15, 2020.
  1. Mar 15, 2020 at 5:07 PM
    jetsweeps
    jetsweeps [OP] New Member
    I just bought a 14 CM 4x4. I'm thinking about running 295/70 r18 stock trd rims which I think have a 60mm offset with bilstein 5100 all the way at top setting in front. Is anyone else running this set up? If so were there any mods that had to be made? Any pics of this set up?
    For the experts will this fit without rubbing or having to make just minor alterations?
  2. Mar 15, 2020 at 5:37 PM
    Tundrajoe
    Tundrajoe New Member
    Joe
    2014 crewmax super white
    Bilstein 5100s cooper at3 xlts, tint, full custom exhaust, methods
    That combo will not rub, ran it that way before new wheels with different offset. Will be close on the upper arm though
  3. Mar 15, 2020 at 5:42 PM
    jetsweeps
    Do you have any pics of that set up? I'm going to install bilsteins 5100 on all 4 and run at top was thinking about 295/70 r18 or 275/70 r 18 but was wondering if 275 were too skinny but I know they will fit.
  4. Mar 15, 2020 at 6:40 PM
    19h341
    19h341 New Member
    Scott
    League City
    19 MGM crew
    Tint, scs ray 10s, bfg 275/70/18
    I went 275/70/18 on stock suspension +25 offset tires and was going to install 5100 in front but now I’m not just rubbed the front mudflap a little. I like the stock rake though. After installing larger tires it makes it almost look like I raised the suspension
    Iowa12tundra likes this.
  5. Mar 15, 2020 at 9:09 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    35s should clear with rock warrior wheel offset, 50mm/8" wide rim
  6. Mar 21, 2020 at 1:46 PM
    Crews44
    Crews44 New Member
    Southern NJ
    2025 Platinum TRD MGM CM 3” TRD lift
    I just went to 285/65r18 from 275/70 and i like to wider look better. They did look a touch skinny.
  7. Mar 24, 2020 at 4:40 PM
    jetsweeps
    I ended up going on middle setting and bought 20 inch oem limited wheels and went with 285/60r20. Had to trim skid plate and that was it.
    InfernoToyo likes this.
