Tire sidewall care
Discussion in 'Detailing' started by joesTundra, Sep 22, 2018.
  1. Sep 22, 2018 at 5:14 PM
    joesTundra
    joesTundra [OP] New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    having difficulty with my side that look rusty looking. I have been using three different rim cleaners and whiter wash on side wall. I do
    believe it is the rim cleaner it the brands that turn red or purple or pink or like a jel anyone experiencing the same problems. I do not
    iuse and tire dressing. thanks for the help
  2. Sep 22, 2018 at 5:18 PM
    I only use Simple green on my tires and they always look good.
  3. Sep 26, 2018 at 5:34 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Aerospace 303
  4. Sep 27, 2018 at 8:11 AM
    War Machine
    War Machine SSEM # 5 3MW
    This is gonna happen with tires unfortunately. What I use is Mother’s Foaming Tire and Wheel Cleaner. It’s available at Walmart and auto parts stores.
    Spray it on the tire, scrub with a brush, and spray it off. You may have to repeat it if they’re pretty bad.
    It will come back periodically. I don’t know of anything that will permanently stop it.
    A good tire dressing like Waxaddict or Meguair’s Gel will help keep it from showing so much.
  5. Sep 27, 2018 at 8:12 AM
    I like aerospace 303
  6. Sep 30, 2018 at 10:25 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    I use Adam's polishes tire and rubber cleaner, never a issue. Look em up.
    -Jason
