Tire sensors
Discussion in '1st Gen Tundras (2000-2006)' started by Luvmytruck, Apr 28, 2021.
  1. Apr 28, 2021 at 8:41 AM
    Luvmytruck
    Luvmytruck [OP] New Member
    Stephen
    '06 white Texas edition sr5 4 door
    Low profile 20" tires, sprayed in bed liner, Extang Tribeca 2 Signature tonneau cover. Pioneer bluetooth system with remote, saddlebag seatcovers
    Is there a fuze for tire sensors on 2006 Tundra. About ready to change out sensors for regular valve stems . So wanting to turn off tire sensor light.
  2. Apr 28, 2021 at 9:07 AM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    Read this thread on different Tundra forum. There is a how to with pictures on page 2 on which wire to cut and ground out to disable the TPMS system.
    CodyP, bmf4069 and jerryallday like this.
  3. Apr 28, 2021 at 10:53 AM
    sflips
    sflips New Member
    Middle Tn.
    2006 DC XSP
    I just by-passed mine a couple weeks ago.
    TPMS light came on a week ago. Mine is a 2006 DC, I decided to try and disable it by cutting the pink/silver wire and grounding it. Worked like a champ. I cut the wire and ran it thru a 3 way switch then to ground. The other leg of the switch, I ran the wire back up to the harness, completing the circuit like it was factory. Now in bypass mode, no light. In the mode that completes the circuit, I have a flashing TPMS light. In the "center" switch position (open circuit)I have a steady on TPMS light.
    I have a tire pressure gauge, I rotate and inspect my own tires and I look at my tires every time I get in/out of the truck. I'm not going thru the hassle and expense of fixing this on a 15 year old truck. Just like the check engine light for the secondary air injection pump. Sometimes delete is the best option.
    I had to pull the radio, I couldn't get my fat hands thru the glove box side. A little tight and awkward but well worth the effort.
    I don't trust much of what I read on the internet, especially when it comes to cutting a wire and grounding it. I put a 2 amp fuse in the wire I grounded. I hate the smell of hot electrical smoke.
    stupidchicken03 likes this.
  4. Apr 28, 2021 at 11:15 AM
    weadjust
    weadjust New Member
    Tupelo, MS
    If you have disabled your TPMS system. Do you have any problems buying new tires? Does the tire store not want to do business with you if your TPMS doesn't work or they can't pad their bill on the TPMS new sensors and programming upsell?
  5. Apr 28, 2021 at 11:27 AM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    Is it easier to simply remove the lamp for the annoying idiot light? That's what I did with the seat belt idiot light but I don't have experience with the TPMS light.
  6. Apr 28, 2021 at 6:57 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Total disagree.
    The only thing between you and the pavement is 4 PROPERLY INFLATED TIRES..
    You have no argument here.....
  7. Apr 28, 2021 at 7:25 PM
    lamboboy732
    lamboboy732 New Member
    The argument is that TPMS is a fairly new invention in the overall existance of automobiles. For decades we have been able to keep tabs on tire pressure and inflate tires when needed without TPMS. In fact my tundra was the only vehicle I'm my fleet with tire sensors. If you keep tabs on your vehicles condition and maintenance as you should, then you will never need the system to alert you of tires needing air. Its really not complex and everyone can do as they please with their own vehicle wether you like it or not.
    Brewster and tvpierce like this.
  8. Apr 28, 2021 at 8:21 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    You can check tire pressure at 65 MPH?
    Like to see that
  9. Apr 28, 2021 at 8:33 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    The last flat I had at 70 MPH (ran over a tire weight). I new it by the way the truck was riding before I noticed the TPMS light was blinking.
    My wife says every winter. Can you check the air in my tires? The tire lights been blinking a couple of months.
  10. Apr 28, 2021 at 10:51 PM
    jimf909
    Washington or Idaho
    Proper tire pressure is important. Tires fail, babies fly out windows and general mayhem ensues when tires are run well-below recommended tire pressures (sometimes).
    TPMS is far more helpful for cars with low profile tires and less helpful for trucks with 75 series tires. A 35-45 series tire gives little visual cue that its underinflated while 65 - 85 series tires show clearly when they're low on air.
    Darwin's law comes into play when anyone drives a FGT with tire pressures 10% - 20% underinflated and doesn't stop to do something about it. No chimes needed.
  11. Apr 29, 2021 at 4:41 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    +1
    My wife's winter wheels have TPMS sensors in them, but I'm just not inclined to take the trouble to reprogram the system every fall and every spring when I swap them. If my wife wanted it, then I'd do it, but she agrees: it's more trouble than it's worth. (and I have a working copy of Techstream on a laptop)
    I guess my 2000 Tundra is a death trap, because it doesn't even have a TPMS system.! :eek2::eek2::eek2:
  12. Apr 29, 2021 at 4:51 AM
    lamboboy732
    Nope but the feel and sound of a low tire would let me know of the issue just fine. How in the world did we survive before before this technology! The horror!
  13. Apr 29, 2021 at 8:11 AM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Suit yourself. I prefer systems to work as designed. The older gentleman that I bought my truck from never fixed the TPMS. He stated it can not be fixed.
    Sure, it cost a fair amount to get repaired. But it has also paid off.
    The XSP wheels have 2 valve stems. On 2 different tires I have had an air leak.
    The truck looked perfectly fine. No leaning, no pulling.
    Yet the system did as it was designed. It alerts the driver to POSSIBLE problems.
    it’s like an oil pressure gauge. Sure, I would know if I was 4 quarts low on oil.
    “Truck runs great”. RIGHT! It’s your money.
    while you are at it, take all your gauges out of the dash.
    Model T never had those, they did just fine.
  14. Apr 29, 2021 at 8:13 AM
    lamboboy732
    That's really my point. You can choose to keep if functional if you so desire and the rest of us can also enable or disable it as we please. There is an argument for both sides.
  15. Apr 30, 2021 at 4:47 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    My truck must be a super death trap then. No abs, no tpms, no sway bars (that's the only one I miss), and whatever else you can imagine would give a bureaucrat and itching for a fresh #2 and a clean pad.
    bmf4069 likes this.
  16. Apr 30, 2021 at 5:05 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    You should disable the airbags too. We die like real men.
    onesojourner likes this.
  17. Apr 30, 2021 at 5:21 AM
    KarmaKannon
    Utah
    Some junk
    I almost did in my ranger. It still needs the recall. Who knows if the airbags on my toyota are good to go. I did the recall last year and immediately got a letter saying great job now you need to come back for air bags. I was confused.
    bmf4069[QUOTED] and onesojourner like this.
  18. Apr 30, 2021 at 5:25 AM
    Professional Hand Model
    Hand Protectors
    Airbags release a toxic gas into the Atmosphere. They need banning. Unite! Fight! For your Rights!
    bmf4069 and KarmaKannon like this.
  19. Apr 30, 2021 at 6:14 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    I am considering adding an aftermarket system. Have you guys gone down this route? I want a system that allows me to monitor 7 tires. I want real time or nearly real time results.
    Does anyone know what the perimeters of the factory system are?
  20. Apr 30, 2021 at 6:41 AM
    KarmaKannon
    Utah
    Some junk
    I haven't added anything, but I have seen some that look alright. Seems like it would be good for monitoring your trailer tires. It can be hard to tell when you blow a tire on a tandem axle trailer. Especially if you are driving straight.
