Tire sensor
Discussion in 'Wheels & Tires' started by Toney198, Nov 19, 2022.
  1. Nov 19, 2022 at 9:56 AM
    Toney198
    Toney198 [OP] New Member
    2014 1794 4X4
    after having two flats, I got new tires. Since this time the the low tire light randomly flashes then will stay on for an hr or days. I have checked them many times, pressure is fine, would it be safe to assume I have a sensor going/gone out?
  2. Nov 19, 2022 at 10:20 AM
    Toney198
    2014 1794 4X4
    also if you think they are bad, does it matter the brand or what ever discount tire puts in?
  3. Nov 19, 2022 at 10:21 AM
    citrusmaster
    citrusmaster New Member
    Tielar
    2015 Tundra RCLB
    If your pressure is good then yes your sensors are going out.
    Stupid things cost hundreds of dollars to fix. I tossed mine a long time ago. A quick walk around the car and you'll see if you have a low tire. This is how to remove the light from the dash. Going to order the pieces one of these days. Already got them all bookmarked
    https://www.amazon.com/Projects-Resistors-Watt-Choose-Quantity/dp/B07BRPQNVQ
    https://www.amazon.com/Projects-2-2k-Resistors-Choose-Quantity/dp/B071DZTF2Q
    https://www.amazon.com/Set-Diode-1N5349B-Zener-AXIAL/dp/B0086FBOFQ
    Toney198[OP] likes this.
  4. Nov 19, 2022 at 10:21 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    they generally last 5-10 years, so yes you are about time being a 2014 truck. I would suggest that you stick with OEM, aftermarket unit dont always play nice and can have sync issues. Or you can roll the dice and see if that DT installs will work for you.
  5. Nov 19, 2022 at 10:27 AM
    Toney198
    2014 1794 4X4
    I will pay a little extra to not mess with it. That light absolutely drives me crazy!
