Tire recommendation?
Discussion in 'Wheels & Tires' started by Theshark, Feb 17, 2018.
  1. Feb 17, 2018 at 1:46 PM
    Theshark
    Theshark [OP] New Member
    2018 tundra 1794
    Hey guys.... I’ve read thru lots of posts and am in information overload. I have a 2018 mgm 1794 with 20 inch choke clad wheels. I’d love to get rid of those but for now I’ll just focus on tires. I’d like to get a more aggressive looking all terrain tire. Anyone have any recs or pics of what looks good? I’m not terribly concerned with longevity as I work from home with no commute and go thru trucks fairly often. I do some off-roading at my hunting club but am mostly highway. Don’t want to sacrifice too much ride or sound if possible? Appreciate your
  2. Feb 17, 2018 at 2:06 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    You can't really go wrong with BFG KO2s. If you are swapping out your rims, I would recommend going to 18s. You get more sidewall tread with a smaller rim, and that adds to the "aggressive" look. I'm sure someone will post up some pictures, or just do a search for some of the tire threads on here. There are plenty. Also check out the wheel and tire section for more info on specific tires.
    TheBeast and netranger6 like this.
  3. Feb 17, 2018 at 2:15 PM
    Theshark
    2018 tundra 1794
    That’s a good insight. If I have 20s and keep em... will it be a waste to get at’s for the aggressive look?
    20s used to be a must have for me. Guess things have changed!
    JH5370 likes this.
  4. Feb 17, 2018 at 2:56 PM
    JerseyTundra1260
    JerseyTundra1260 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
    I had ko2s first liked them a lot have since gone to Nitto Ridge Grapplers love them...
  5. Feb 18, 2018 at 10:47 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I had Nitto Terra Grapplers on truck before, they do have the look you are after. You can check photos and specs on discountire.com.
  6. Feb 20, 2018 at 4:53 PM
    Theshark
    2018 tundra 1794
    Looks like I’m gonna go with Falken wildpeaks at3 after much review. Will go on stock 30 inch rims.... the only question now is 275/60s or 275/55s?
    Basically have all four installed for 830.
  7. Feb 20, 2018 at 5:47 PM
    BayRunner
    2017 Tundra Platinum
    Where do I sign up for these? :rofl:
  8. Feb 20, 2018 at 5:54 PM
    Theshark
    2018 tundra 1794
    Ha! They are pretty sweet... no rubbing either!
    Black Wolf likes this.
  9. Feb 20, 2018 at 5:58 PM
    Mike's Custom Toys
    Mike's Custom Toys New Member
    275/60/20 falken at3w will rub factory mudflaps
    BlueBottle likes this.
  10. Feb 20, 2018 at 6:00 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Good Choice. This is our second set of wildpeaks AT3 and I love em. Warning they are heavy. Here is a set of 20’s on the wife’s whip
    Theshark[QUOTED][OP] likes this.
  11. Feb 20, 2018 at 6:02 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    It ain’t fun without a little rub! :thumbsup:
    Bmxrider1331 likes this.
  12. Feb 20, 2018 at 6:09 PM
    Theshark
    2018 tundra 1794
    Hmmmmm... 55s vs 60s will rub? I had no idea. 55s it is....
  13. Feb 20, 2018 at 6:10 PM
    Mike's Custom Toys
    Or pull the mudflaps, up to you
  14. Feb 20, 2018 at 6:23 PM
    Heeler13
    Heeler13 21MGM
    Eastern NC
    2021 Sr5 XP
    Bilstein 5100 Front @ middle setting Bilstein 5100 Rear @ stock height Oem older Pro wheels 285/75/18 Maxxis Razr a/t
    60s will fit. I have a 2018 limited with Falken at3w 275/60/20. It almost touches that small front mudflap in front of the tire at full lock. Clears the rear mudflap fine. Like stated above, take off that tiny flap if it hits it and bothers u.
  15. Feb 20, 2018 at 6:31 PM
    Theshark
    2018 tundra 1794
    Much appreciated.... could i see a pic the tires and rims?
  16. Feb 20, 2018 at 6:44 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I ran Cooper ST Maxx on my Tacoma. I need a very durable tire in rocks, cactus, mesquite, and aggressive tread for mud. Took a little weight to balance but put 30k on them with no problems. Probably most aggressive AT out there. I had a better pic but deleted it.
  17. Feb 20, 2018 at 6:58 PM
    JerseyTundra1260
    Marc
    New Jersey
    I had 275/60/20 BFG Ko2's Trimmed my skid plate that's it. Kept all flaps. They were mounted on +60 Toyota Carve wheels
  18. Feb 20, 2018 at 7:08 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    Here is a good st maxx picture. I have been considering these but heard they wear fast? A buddy of mine has them on his Ram.
  19. Feb 21, 2018 at 4:46 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Your truck will look like this:
    Black Wolf and Theshark[OP] like this.
  20. Feb 21, 2018 at 5:30 AM
    Mssmith8
    Mssmith8 New Member
    2018 Tumdra Limited
    I am looking at doing the same on my limited with 20 in rims pretty soon. Just out of curiosity how much did road noise increase going from the duelers to the AT tires? I was looking at the Nitto Terra Grappler G2's and had not considered the Falkens.
  21. Feb 21, 2018 at 5:39 AM
    chphilo
    chphilo Tundra addict
    Western PA
    275/60/30 is 43 inches in diameter. I think you are gonna need to do more than just take small mudflap off, haha.
    4Runner likes this.
  22. Feb 21, 2018 at 7:36 AM
    Theshark
    2018 tundra 1794
    What....I like being above the traffic!
  23. Feb 21, 2018 at 7:38 AM
    Theshark
    2018 tundra 1794
    I actually haven’t bought them yet. Likely today. I read a lot of review about them... all really positive and they are 30perc or so cheaper than the higher ends...
  24. Feb 21, 2018 at 8:15 AM
    Mike's Custom Toys
    That is what we run into most of the time. Most people would rather save over $50 a tire and get a great product that meets most peoples All-Terrain needs. They are very quiet as well. I love ST MAXX but sometimes its a hard sale.
  25. Feb 21, 2018 at 8:19 AM
    Mike's Custom Toys
    Here is a set of Falken At3w's we did yesterday with some new fuel Hostages. Size 275/60/20
    parker44 likes this.
  26. Feb 21, 2018 at 8:31 AM
    Theshark
    2018 tundra 1794
    Looks awesome!!!
    So... will the 60s rub or not? Kinda heard both ways...
  27. Feb 21, 2018 at 8:33 AM
    hartebreak
    hartebreak New Member
    2017 Tundra Doublecab
    I know you said you are just focused on tires at this point, but the MGM Tundras just scream for black wheels. In my opinion the chrome wheels don't look that great on the MGM. As you stated, you're doing the change mainly for looks, so jump in with both feet and go all new. You could probably sell your take-offs for $500-$700 to offset some of the cost. That being said, I put Toyo MTs on mine and they look awesome, but are loud when compared to like a KO2.
    Theshark[OP] likes this.
  28. Feb 21, 2018 at 9:06 AM
    Mike's Custom Toys
    Yes they rubbed the DC from yesterday. Definitely will need to remove the small ones up front. The passenger side barely touched the rear flap.
  29. Feb 21, 2018 at 9:08 AM
    Theshark
    2018 tundra 1794
    Thanks for the update
  30. Feb 21, 2018 at 9:51 AM
    BayRunner
    Ummm.... No!... even the booth babe has to look away. :)
