Tire PSI question
Discussion in 'Wheels & Tires' started by travpayne, Sep 19, 2019.
  1. Sep 19, 2019 at 8:34 PM
    travpayne
    travpayne [OP] New Member
    17 Tundra CrewMax 4x4
    quick question-
    I just got a set of BFG AT2 put on my 17’ crew max.
    They are 285/75/17 and pre inflated to 70 all around.
    It seems a bit much?
    Any input would be greatly appreciated!
    Also have the 5100 on the truck set in the middle (level).
    Thanks in advance!
  2. Sep 19, 2019 at 8:41 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Way too much. First step call or email BFG and give them your truck info (lift specs, wheel size/offset, tire size, etc.) and they should be able to give you a starting point for PSI go with that monitor and adjust as necessary. I did that with Nitto surely BFG can point you in the right direction.
  3. Sep 19, 2019 at 8:43 PM
    travpayne
    Thanks man.
    The max says 80 so I assume it’s not too far off. Maybe 60-65.
  4. Sep 19, 2019 at 8:47 PM
    Rngr188
    Chad
    Harrison AR
    My Nitto LT275/70/18 are 80 max but Nitto recommended about 38 rear and 36 front. I do 38 all around and am getting good even wear. YouTube the chalk line test to adjust for even wear.
  5. Sep 19, 2019 at 8:47 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Way too much, between that tire pressure and 5100s pre loading the coil springs that truck must ride like the flintstone wagon.
    Go down to 40-45 and do the chalk test to fine tune. It'll rude so much better and increase traction, tread wear and tread life.
  6. Sep 19, 2019 at 8:50 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    60-65 is likely still way high. Most I’ve calculated for LT tires on a tundra is 55.
    What are the specs of the tires that came on the truck originally?
  7. Sep 19, 2019 at 8:53 PM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Go for a ride. After a half hour or so stop and run your hand over the tread. If its warm in the middle and cooler on the edges, too much air. If its warm on the edges and cool in the middle too little air.
    Pudge likes this.
  8. Sep 19, 2019 at 8:56 PM
    Racingjohndeere55
    I have 43 lbs in the LT tires on mine. Same temp all the way across.
  9. Sep 19, 2019 at 8:58 PM
    Pudge
    CT
  10. Sep 19, 2019 at 9:00 PM
    travpayne
    Thanks all.
    I’ll give the chalk test a go tomorrow
  11. Sep 19, 2019 at 9:33 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I run 32psi in my 285/75r18s and the middle of the tread is still wearing faster on my Toyos RTs.
