Tire pressures
Discussion in 'Wheels & Tires' started by PWMDMD, Feb 17, 2020.
  1. Feb 17, 2020 at 3:16 PM
    PWMDMD
    PWMDMD [OP] New Member
    Worcester, MA
    2020 Tundra Platinum
    New owner of a 2020 Platinum. This is my first truck and was surprised to see they recommend 30psi for fronts and 33psi for rear wheels. The dealership delivered the truck to me with 37psi in front and 36psi in the rear in 15F temps. I always just follow there sticker on the door for tire pressure but these seem pretty low - any reason to run higher pressures? I've read a couple of threads with people getting poor tire wear.
  2. Feb 17, 2020 at 3:17 PM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    I run mine at 40 all around, I don't remember why - but I remember researching and deciding that was best for me.
  3. Feb 17, 2020 at 3:18 PM
    TheBeast The Beach
    stock tires you good with 35+. if you get bigger off road tires later one. 40 psi is good for the tundra.
  4. Feb 17, 2020 at 6:35 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  5. Feb 17, 2020 at 6:43 PM
    TundraAllTheWay
    TundraAllTheWay New Member
    2018 Cement Grey Toyota Tundra SR5 CrewMax TRD Off-Road
    My sticker on my door says 30 in front and 33 in back but I just leave mine at 33 in the front and 36 in the back. It's winter here so my dealer told me to fill them higher cause of cold temp changes.
  6. Feb 17, 2020 at 7:01 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    44 psi on all four tires. I'm on 275/60/20 Nitto Terra Grappler G2's.
  7. Feb 22, 2020 at 1:01 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    You are on stock P load tires, so go by the door sticker. You could add a few more LBS if you like. It would be helpful to add some when/if you do any towing. The stock P load tires do not require high PSI to carry the designed load. They probably have a max PSI of around 40 PSI. On your door sticker will be a load index showing that the stock tires can "carry"...how many pounds, based on the specific pressures listed on the sticker.
    If you ever move to a larger LT type tire- C, XL, E load tires you would need to run them at higher pressures to handle the same load. LT tires have max pressures that are much higher than standard P tires...up to 60, 80 PSI, etc.
    I usually run my crewmax 4x4 at 33psi front and 35 rear, a few pounds higher than the sticker indicates...stock Michelin tires with the OffRoad package.
    Darkness likes this.
  8. Feb 22, 2020 at 1:12 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    This thread is all over the place :rofl:
    What tires are on your truck? What size? What rating? There is not enough info for us to guess what pressure is appropriate.
    On passenger tires I generally run 10 percent higher than the door sticker on stock sized tires just for gas mileage, but I do the chalk test to be sure I won't wear out the centers.
    On E rated tires I don't think any rule of thumb applies, you must chalk test.
    AK 6.7PSD Replacement likes this.
  9. Feb 22, 2020 at 1:21 PM
    frichco228
    He has a brand new truck with the stock tires- 2020 platinum
  10. Feb 22, 2020 at 1:24 PM
    AK 6.7PSD Replacement New Member
    IL, MO, KS, DE, IL, AK, SC...
    2018 SR5 DoubleCab 4x4
    I run about 124psi in my Cannondale.
    Does that count for anything on this thread?
    2018 Tundra with LT275/70R18 at 45psi
  11. Feb 22, 2020 at 2:08 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    I run. 37-39 PSI in my 275/55/20’s year round. It’s a harder ride than the door sticker pressures but the handling is much better as is the mileage.
    P-Factor likes this.
  12. Feb 22, 2020 at 5:46 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've seen plenty of dealerships throw aftermarket wheels/tires on brand new trucks. I don't like to assume.
