Tire pressure?
Discussion in 'Wheels & Tires' started by zeke7681, Oct 19, 2018.
  1. Oct 19, 2018 at 4:40 AM
    zeke7681
    zeke7681 [OP] New Member
    Zeke
    PA
    2018 Black TRD Sport CM
    I'm currently running 275/70/18 Nitto Ridge Grapplers and was wondering what a good tire pressure is. When I had them mounted and balanced they filled them to 34lbs each and I thought that seemed a little low. I've read about the chalk test but I was just curious what others were having luck with. Thanks in advance.
  2. Oct 19, 2018 at 7:24 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    My 295/70R18 NRG's are definitely low at door sticker PSI. I have them at 47 front/43 back, I used to have them at 42/40 and still looked low but seems to pass chalk in the 40's. I just rotated them, will keep an eye on overall wear pattern.
    15whtrd likes this.
  3. Oct 19, 2018 at 7:55 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I'm at 30/33 psi on 35's. And every bit of that width is planted on the ground...lol
  4. Oct 19, 2018 at 8:42 AM
    wigsplitter
    wigsplitter New Member
    DFW Texas
    2018 SR5 TSS Crew Max
    not the same size but my stock 20's I run at the door sticker pressure (49psi) and have never had a problem
  5. Oct 19, 2018 at 8:56 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Same tire and size at 36 but should probably go to about 34. Wear is consistent but inside lugs are wearing just a slight bit more than outside lugs on either side at all four corners.
  6. Oct 19, 2018 at 11:03 AM
    mtodd
    mtodd New Member
    I emailed Nitto and was provided the following. This was based on a 2010 crewmax. I have about 1000 miles on them so far and ride fine.
    275/70/18 NRG
    38 front
    42 Rear
  7. Oct 19, 2018 at 2:42 PM
    zeke7681
    Zeke
    PA
    Thanks for the replies, much appreciated!
