Tire Offset Confirmation
Discussion in 'Wheels & Tires' started by xk49, Oct 24, 2020.
  1. Oct 24, 2020 at 11:03 AM
    xk49
    xk49 [OP] New Member
    Jerome
    2012 Tundra
    Leveling Kit
    Looking at these wheels/tires:
    https://www.ebay.com/itm/20x9-Fuel-D680-Rebel-Gray-33-Wheels-Rims-Nitto-Tires-5x150-Fits-Toyota-Tundra/283595396199?ssPageName=STRK%3AMEBIDX%3AIT
    The specs says postive "1" offset 5" backspacing on a 9inch wheel, but doesn't that put the tires way out beyond the fender. I thought stock offset was like positive 50? Don't mind going a little pass the wheel well but not over two plus inches.
    Also, when I look at the pictures on the ebay site, they look like they have a much bigger positive wheel offset than "1" as the wheel face looks pretty close to the outside of wheel.
  2. Oct 24, 2020 at 11:40 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    here is my truck with 20x9 +20mm offset. +1mm offset would stick out another 3/4":
  3. Oct 24, 2020 at 11:43 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    They are +1 offset. They will stick out 2” more than a +50 offset.
  4. Nov 6, 2020 at 8:22 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    I read AND search!! So I am bumping this thread instead of creating a new one since I am asking a similar question. I have 2 option for the Fuel D671 bronze rim. I want flush or just a tad bit over. Not a fan of mud and rock chips all up the side of my new truck.
    What makes the +1 offset an aggressive fit? I don't want my tires to look "sunk" into the sides. Can someone explain? My master plan is to run 6112's Bilstiens and 285's (33s) on a 20x9 (I know the rim size is obvious since I posted the image below).
  5. Nov 6, 2020 at 9:16 PM
    ohreary
    ohreary Party!
    2020 Platinum
    +1 is considered aggressive because the wheel will be offset 59mm more than what comes on the truck stock.
    BravoDeltaRomeo likes this.
  6. Nov 6, 2020 at 9:30 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
  7. Nov 6, 2020 at 10:59 PM
    YotaTruckLtd
    YotaTruckLtd Secret Squirrel
    2014 MGM Limited CM
    Bilstein 6112/5160 Boss 4x4 shims Boss 4x4 shackles Fuel Off-Road Vector wheels 20X9 Nitto Terra Grappler G2 35" tires SPC UCAs OEM TRD Pro Grille OEM 2020 LED headlights and OEM LED fog lights OEM color matched mirror caps and door handles OEM black exhaust tip Ecoological color matched front and rear bumpershellz V3 Go Rhino RB20 running boards XPEL Prime XR Plus ceramic tint 30% front 15% rear 70% windshield BAKFlip MX4 tonneau cover Dasaita 13in Vivid Headunit AJT interior chrome delete black kit AJT climate control black knobs AJT V3 shift knob TVD exterior emblem black inlays 3BMakers Yota hitch cover Husky front and back floormats K&N Select engine air filter GTR Lighting Armor Series LEDs Reverse lights Cargo lights 3rd brake light License plate lights
    Here are my 20x9 +20 offset Fuel Vectors for comparison. Running the Nitto TG2 35" tires. I also didn't want the wheels to go too far outside of the fender.
    AircareTundra likes this.
  8. Nov 7, 2020 at 5:03 AM
    xk49
    Jerome
    2012 Tundra
    Leveling Kit
    I ended up doing a 20x9 +18 offset with a 295/55/r20 tire. I like the look of the tire sticking out some, but currently it's just a tad too much. I'll be adding one inch flares which will cover 90% of whats sticking out and that's OK.
    SprinterAE86 and BravoDeltaRomeo like this.
  9. Nov 11, 2020 at 10:17 AM
    ejl04
    ejl04 New Member
    The more the tires stick out past the fenders, the more "aggressive" the look. I have a 0 offset, which is basically the same as +1. They stick out quite a bit past and I'm not a fan. Does fling snow and dirt all over the sides. If you don't want that, I would make sure to get +25 offset at least. Keep in mind the width of the wheel as well. Mine are on a 17x8.5. A 20x9 would stick out an additional 0.25".
  10. Nov 11, 2020 at 11:20 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    I have +0 with flares and they stick out a tiny bit
  11. Nov 11, 2020 at 11:23 AM
    Kanobi13
    Kanobi13 New Member
    Plus 25 was excited it did not throw mud all over on hunting trip. 20201108_115758.jpg
    ejl04[QUOTED] likes this.
  12. Nov 11, 2020 at 11:38 AM
    ejl04
    ejl04 New Member
    Which flares did you go with? Pics?
  13. Nov 11, 2020 at 12:01 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    +12, ended up getting flares after, then I decided to go 295. :rofl:I made it stick out some more.
  14. Nov 11, 2020 at 12:21 PM
    xk49
    Jerome
    2012 Tundra
    Leveling Kit
    I'll be getting one inch wide flares. It will cover all the tread of the 295, but not the bulge of the side wall and that's OK with me.
