Tire light
Discussion in '1st Gen Tundras (2000-2006)' started by Lee, Jan 18, 2020.
  1. Jan 18, 2020 at 10:59 AM
    Lee
    Lee [OP] New Member
    Lee
    2006 Tundra
    It's always either on or blinking. Tire air pressures are all good as well as the spare. Why?
  2. Jan 18, 2020 at 11:56 AM
    Cacoleman2014
    Cacoleman2014 New Member
    Louisiana
    2006 Tundra SR5 double cab
    Dead batteries in the sensors.... Wait for my tires to wear out so I can replace mine. I put a tiny piece of black tape over the light cause it drives me crazy!
  3. Jan 18, 2020 at 12:02 PM
    SouthWestGA
    SouthWestGA New Member
    First generation Tundras were the “Toyota Trial TPMS Sensor System” so to speak
    They are Plagued with issues. Most people don’t even spend The $$$ fighting with it. You can only have 1 set of sensors programmed at a time.
    On 1st gens,you have to go to the dealer and have them go into the ECM to delete all the sensors and program the sensors back in. Our computer does not have the ability to “relearn” new sensors. Tire Shops with their “relearn/re scan tool” cannot help you. It’s an ECM issue.
    It’s a complete pain and useless feature anyways. In my opinion a TPMS system should at lea set be able to tell you which specific tire has issues.
    There is a way to ground out a wire on the TPMS computer harness and make the light permanently stay off.
    Here is a photo Album Pics and the process to permanently disable the light
  4. Jan 18, 2020 at 3:31 PM
    mobicola
    mobicola New Member
    2006 Tundra Double Cab XSP
    Thanks for the information and pictures! A couple of questions please... does another white plastic connector (like a male or female) plug back into the one shown in your pictures when you are done splicing? If not, could I connect the pin corresponding to the pink and silver wire to ground and accomplish the same thing without splicing?
  5. Jan 18, 2020 at 9:37 PM
    SouthWestGA
    I have not done the procedure to my 2006 yet
    i plan on doing it soon
    i can’t advise from experience,sorry!
    i do know that i will do it as the photos show just for the mental ease of knowing it works
  6. Jan 19, 2020 at 2:00 AM
    mobicola
    mobicola New Member
    Can you update us with what you find? Thanks
  7. Jan 20, 2020 at 8:59 PM
    simonmiles
    simonmiles New Member
    I just did this mod about a month or so ago. After you cut the pink and silver wire you can just connect the wire directly to the pictured ground screw with another piece of wire. The portion of the pink and silver wire coming off the white plug can be left like that. I did exactly like the pictures and I added some spade quick connects so that I could re-enable the TPMS system easily. Hope this helps.
  8. Jan 20, 2020 at 9:06 PM
    SouthWestGA
    So basically the only wire you ground is the one that’s on the plug?
  9. Jan 21, 2020 at 11:06 AM
    simonmiles
    I edited this post to include a picture. After you cut the pink/silver wire you will connect the part coming from the wiring harness side to the ground screw. The other section of pink/silver wire that comes off the white plug can be left alone. Hope this helps.
  10. Jan 21, 2020 at 12:19 PM
    SouthWestGA
    Got it! Thank you for the clarification! I’ll see if I can get it done to my 06 sometime This year haha
  11. Aug 1, 2021 at 8:58 AM
    daveeasa
    David
    Thanks for the info here. I was just thinking about this topic as I plan new wheels for my 2002. I happen to have a tactrix and techstream so I’ll see if I’m able to connect and view and possibly change. Might be tricky to find proper sensors though? Since they are the old design?
  12. Aug 1, 2021 at 10:49 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Was TPMS an option in 02?
  13. Aug 1, 2021 at 10:55 PM
    daveeasa
    David
    Well, shoot, I was assuming based on @empty_lord but is that maybe one of those differences between '02 and '05?
  14. Aug 1, 2021 at 11:42 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Tpms was introduced in 2005 on the tundras.
    Tundra2 and daveeasa[QUOTED] like this.
