Tire Chains Anyone
Discussion in 'Wheels & Tires' started by TRD Pro Rookie, Nov 8, 2016.
  1. Nov 8, 2016 at 10:41 AM
    TRD Pro Rookie
    TRD Pro Rookie [OP] New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Planning a family vacation next month in Colorado so I went online yesterday to TireChain.com and scored some heavy duty (7mm) tire chains with V bars. Also scored some tensioners and storage bag for around $150 shipped. I did zero research so i probably got robbed. What do yall think?
  2. Nov 8, 2016 at 10:59 AM
    T-Rex266 Moderator Staff Member
    Lived in CO for almost 9 years. Haven't needed them, yet. If you're going deep into the mountains then maybe...depending on the weather and any recent storms.
  3. Nov 8, 2016 at 11:06 AM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Gonna spend a week in Summit county.
  4. Nov 8, 2016 at 1:59 PM
    ColoradoTJ Moderator Staff Member
    Ford F-350, Roush Mustang, Jeep Crawler
    I have only used chains a couple times in CO.
    -Blizzard of 07
    -Stuck cutting firewood in 06, muddy as hell.
    Enjoy the trip.
    Watt maker and FlashCulprit like this.
  5. Nov 8, 2016 at 2:01 PM
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    At the moment there is no snow in Summit County........ You will most likely not use them but it never hurts to be prepared.
  6. Nov 8, 2016 at 8:48 PM
    cheehab
    cheehab Fan Boy
    Southern Maine
    2015 TRD Pro CrewMax
    Not sure about the price but you won't need them, unless you got one of those Southern Edition 4x2 Pros. Would've been better off spending your $150 on a Breck lift ticket.
    TheBeast likes this.
  7. Nov 8, 2016 at 10:50 PM
    landphil
    Phil
    Canaduh
    ‘08 TRD doublecab
    I just got my Tundra a couple weeks ago, going to size a set of 7mm V-bar chains equipped with cam tensioners once I get the new duratracs on this week. I used my chains a minimum of 5 times a year on the Tacoma with duratracs, late season hunting in the mountains, etc. Never used them on a maintained road, but carried them all winter anyway. $150 doesn't sound too bad for that setup.
  8. Nov 8, 2016 at 11:02 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Always thought about getting them but have never needed them thus far. Even in the mountains during a snow storm. Just drive slow. If it's that bad on the roads, it will be the lack of others that keep you from driving.
    FlashCulprit and ColoradoTJ like this.
  9. Nov 9, 2016 at 7:51 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Blizzard? Snow? What are these things you speak of?
  10. Nov 9, 2016 at 8:51 AM
    Black Wolf Everywhere I go, there I am......
    2018 Chevrolet Suburban LT 4WD
    Been here in CO since 9/2004 (minus 9 months in AK) and haven't ever had to use chains although there were times where chains could have helped.
  11. Nov 9, 2016 at 11:25 AM
    TheBeast The Beach
    Florida making America great again !
    AnonVet, aperezsh, CaptTyler and 2 others like this.
  12. Nov 11, 2016 at 5:20 AM
    Tundra....Making America great.... period...heh heh
    aperezsh likes this.
  13. Nov 11, 2016 at 8:25 AM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    tire chains arrived yesterday. The heavy-duty ones, (7 millimeter) are definitely heavy duty. Not sure there would be enough room left between the change in the fenders if I was running oversized tires. The only negative I see is that it says "made in China" stamped all over. We'll do a test fit and final adjustment this weekend. And nobody better leak it to my wife that I didn't need these! Since when is this forum about stuff you need rather than stuff you want?
    driverdog and JC303 like this.
  14. Nov 11, 2016 at 5:36 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    You can live inside the arctic circle and never need chains. Depends where you go and when. I have had to chain up regularly to climb some mountain grades on the interstate here in AZ. Lots of times they have check points and will limit access unless chained or have 4x4.
    I had 2 sets and occasionally chained up all4 wheels on my lifted 1st gen taco to safely go on off road trails in several ft of snow. In conditions like that you can't really identify a log or low stump. For a few of my trucks I had 2 full sets of wheels and tires. I would put the studded mud n snows on in the fall and take em off in the spring. Chains are a good purchase for peace of mind. Unfortunately I don't think that there is enough clearance from the upper control arm on the tundra to run chains on the front.
    Wrongside likes this.
  15. Dec 29, 2016 at 9:59 AM
    Wrongside
    Wrongside New Member
    AB
    2016 Tundra
    Have you looked into this any further, gosolo? Do any of our other members have any information Re: chains on Tundras?
    I want to have a set before next winter and would prefer to have a full set of 4.
  16. Dec 29, 2016 at 10:17 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I have fit a set for the front and with these stock Michelin tires the chains clear the UCA by about 1/2". Are you running stock rims and tires? I have modified chains dozens of times to fine tune the fit. Whatever you get, test check it in your garage with the truck wheels jacked up and good light not out on the road in the dark with a ft of snow!
    Wrongside[QUOTED] likes this.
  17. Dec 29, 2016 at 6:36 PM
    landphil
    Phil
    Canaduh
    ‘08 TRD doublecab
    Are you running aftermarket wheels with higher offset? With my stock 18" wheels, I don't have room up front for anything more than light duty chains of cables. I'm fairly certain the pair of heavy duty v-bars with cam tensioners I sized for the rear will suffice. Running Duratracs too, don't usually put the jewelry on unless it's a steep icy hill or over 15" of snow.
  18. Dec 29, 2016 at 7:13 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Stock pro rims (which I like) and stock Michelin tires (which I don't like).
    I'm in complete agreement with you, only use the rear set unless you're in trouble (or about to be).
    Mine are also heavy duty with the V track welded to the cross chains
  19. Dec 29, 2016 at 10:39 PM
    landphil
    Phil
    Canaduh
    ‘08 TRD doublecab
    As long as the Tundra can keep up to what my Tacoma did in snow, I'll be happy. Those were only twist-link chains on the taco, not v-bars.
    I haven't run the chains on the tundra yet, but they are sized and ready.
    Watt maker, gosolo, Wrongside and 2 others like this.
  20. Dec 30, 2016 at 9:52 AM
    Wrongside
    AB
    2016 Tundra
    Appreciate the info!
    I'm running TOYO AT2 275/70 R18 on stock TRD rims. So one size up from factory, I believe. Not sure how that would effect chain fit on the trucks...
    I hear you on the test fitting and trial runs! Nothing worse than nasty surprises in the backcountry and I do all I can to avoid them.
    gosolo[QUOTED] likes this.
  21. Jan 11, 2018 at 7:51 PM
    landphil
    Phil
    Canaduh
    ‘08 TRD doublecab
    I’ve run my chains a couple times in steep icy terrain when cutting some firewood for a buddy back in November. Nigh unstoppable...
    Black Wolf and Wrongside like this.
