Tips, tricks and I tried that
Discussion in '1st Gen Tundras (2000-2006)' started by Hooptytrix, Nov 26, 2019.
  1. Nov 26, 2019 at 4:02 PM
    Outbound
    Aaron
    Northern Alberta
    I never thought to look under the lid. I always just replaced the main filter. I'll have a look next time I swap filters. Thanks!
    I clean the MAF every time I change my filters and don't use oiled filters anymore either.
  2. Nov 26, 2019 at 4:04 PM
    Hooptytrix
    Hooptytrix [OP] Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    Don't thank me, I found it posted in another thread. Cleaning up or replacing that maf helps a lot. I went with the Jet maf just because
    Outbound[QUOTED] likes this.
  3. Nov 26, 2019 at 4:12 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I think she did
    War Machine[QUOTED] likes this.
  4. Nov 26, 2019 at 4:15 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Asked about that filter a number of weeks back and a few posts following the below post talked about it.
  5. Nov 26, 2019 at 4:17 PM
    Hooptytrix
    Dirty South
    From what I understand, this intake system is only on the 05-06. Is that correct?
  6. Nov 26, 2019 at 4:22 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    You call me out on my avatar but not observant to see I have a 2004 which is where that pic is from :facepalm::duel:
    GODZILLA likes this.
  7. Nov 26, 2019 at 4:30 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  8. Nov 26, 2019 at 5:16 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yes, but it's good entertainment.
  9. Nov 26, 2019 at 5:26 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    TXMiamiFan[QUOTED] likes this.
  10. Nov 26, 2019 at 5:30 PM
    Kerch71
    Mechanicsville VA
    Yeah, shift kit and upgrade the torque converter is the current plan. The dyno guys suggested it and transmission guy agrees given the hp and torque. Going Monday for them to drop the tranny and take a look at it. Will keep you posted.
  11. Nov 26, 2019 at 6:28 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    No, it's on all first gens. If yours doesn't have it then a prior owner ripped it out. I ripped mine out in 2008 because all the cool kids were doing it.
    Outbound likes this.
  12. Nov 26, 2019 at 6:36 PM
    Hooptytrix
    Dirty South
    I figured you were using another internet sourced stock photo....... My bad for judging
    BubbaW[QUOTED], GODZILLA and Darkness like this.
  13. Nov 26, 2019 at 7:15 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I have a tip...
    Learn to weld.
    I have a trick...
    If nobody has tried the mod you wanna do, maybe there's a reason. Yeah I know that from personal and recent experience.
    I have an I tried that...
    I put 2018 raptor coilovers on the front of my truck. What silly thing have you spent two months doing that someone else hasn't done haha.
    Aerindel and Darkness like this.
  14. Nov 26, 2019 at 7:17 PM
    Outbound
    Aaron
    Northern Alberta
    So you're saying that if I rip mine out I can finally be a cool kid!? :yes:
  15. Nov 26, 2019 at 7:19 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    That and paint your truck black, you're in!
    TX-TRD1stGEN likes this.
  16. Nov 26, 2019 at 7:22 PM
    Outbound
    Aaron
    Northern Alberta
    What, and deduct 50hp from my truck? Being cool is NOT totally worth that. No thank you. Good. Day. Sir.
  17. Nov 26, 2019 at 7:50 PM
    Hooptytrix
    Dirty South
    You know what they say..... Once you go black you never go back
    Outbound[QUOTED] and BubbaW like this.
  18. Nov 26, 2019 at 8:40 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I tried a K&N intake kit a few times. Made awesome sounds but no noticable improvement on acceleration. I did notice better MPG on freeways.
    I tried adapting a Volant airbox to that K&N kit. It worked but barely, I think the filter was being impeded by the box. The Volant filter must be quite a bit slimmer. I didnt like the way it drove at all.
    I tried a K&N drop in filter with the stock box. Made whistling noises and didnt filter that well.
    I tried an airaid intake kit with the tube and dry filter. It made noise because the tube lacks the silencer that the OEM tube has, but no noticable gain. The filter looks terribly made but seems to filter quite well.
    I tried opening a 1.5" diameter hole in my stock airbox. This made a bit of noise but again, no noticable gain. I did this because a very scientific study showed that there is a mild vacuum created between the fender opening and filter at wide open throttle. The study determined that a 1.25" opening in the airbox would alleviate the vacuum. The trouble is it allows hot air in as well but probably just at idle. I have a feeling on the freeway it causes turbulence.
    I'm now back to the stock airbox, no hole, and dry airaid filter.
  19. Nov 26, 2019 at 8:57 PM
    #49
    Hooptytrix
    Dirty South
    Good info, I have been eyeing the airaid system but I have read that it makes noise but not power. I'm starting to believe spending $300 on 12 hole injectors is better than $300 on intake system.
  20. Nov 26, 2019 at 9:02 PM
    #50
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Or an lsd if your truck didn't come with one
  21. Nov 27, 2019 at 2:53 AM
    #51
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    I can assure you it's all good, what you couldn’t see was the shit eating grin on my face conversing with ya :wave:
  22. Nov 27, 2019 at 6:26 AM
    #52
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yup. I had got it used for $50 from a different forum, got the Volant box used for $15. The K&N is the only one I got new but at least it was on sale. If I could find a dry filter to fit I would run it in winter.
  23. Nov 27, 2019 at 6:30 AM
    #53
    Hooptytrix
    Dirty South
    Have you looked at the aem site? They have a few different dry filter sizes
    Darkness[QUOTED] likes this.
  24. Nov 27, 2019 at 7:21 AM
    #54
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yes, I figured they of anybody would have a dry cone that would fit since they're owned by K&N, but they don't have one. The inlet size is oddball, the only option I would have is to go up on the inlet size and wrap rubber material on tube to act as a spacer. I don't like doing stuff like that.
