Tips for removing rust/dust?
Discussion in '1st Gen Tundras (2000-2006)' started by MrAristo, Apr 7, 2020.
  1. Apr 7, 2020 at 5:14 AM
    MrAristo
    MrAristo [OP] Hounty Bunter
    South FL
    ‘01 4X4 Limited TRD
    As everyone knows our trucks have had infamous “rusting” frame issues. While many of us don’t, we experience the dusty rustiness which I have on certain parts, primarily the front undercarriage below the engine. Anyone got something? I saw mixing vinegar with 2 to 3 parts water and spraying it is effective.
    3297265C-B810-4393-AA69-A8CEBA02578D.jpg 71535FC3-AF78-4C25-8213-34FE891252F9.jpg 30D57C57-0B84-498C-B7E1-D71B4C8A337A.jpg CF883E6B-FEA0-4B66-9C7B-824452D2A8FC.jpg
  2. Apr 7, 2020 at 5:28 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Salt water use? The paint, do you wax it?
  3. Apr 7, 2020 at 10:58 AM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    @T-Guy69 bought this thing mid January, been in FL for years but original location way back when was Missouri! No wax yet.
  4. Apr 7, 2020 at 12:22 PM
    T-Guy69
    T-Guy69 New Member
    Long Island
    I found this found this: https://www.carbibles.com/best-rust-remover/
    In most cases, you have to remove the rusty part, and with a rust remover and then some elbow grease. After the rust is gone, you will have to prime and paint. I have used rust-oleum professional spray paint which I purchased from Home Depot. From the pics, some parts may need replacement. The body parts with paint may need a body shop. But my guess is the color will be hard to match. Others may want to chime in.
    MrAristo[OP] likes this.
  5. Apr 7, 2020 at 1:29 PM
    Warreng
    Warreng New Member
    Small handheld sandblaster will work alright without removing base material.
  6. Apr 7, 2020 at 2:57 PM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Great suggestion. I looked at blaster Not that bad price wise and would make your life easier.
  7. Apr 8, 2020 at 6:23 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    For the belly pan and the bumper support, I'd use Ospho -- available at any building supply or hardware store -- or on Amazon. It's phosphoric acid. Brush it on, and it chemically converts the rust to a black hard surface. You can top-coat it or not.
  8. Apr 8, 2020 at 6:39 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Ive used that stuff on old musclecars...does work well. Top coat it with a good rattlecan paint.
    tvpierce[QUOTED] likes this.
  9. Apr 8, 2020 at 2:30 PM
    tvpierce
    Maine
    I believe it's UV stable. So if you like/don't mind the flat black look (which I think is perfect for these two applications) you can just leave it.
  10. Apr 11, 2020 at 4:26 AM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    Gonna be doing couple O2 sensors this morning, plan on picking up Ospho at Home Depot and trying you guys on this. Any specifics for application/drying? From what I see this stuff turns the rusting into a black and also white color? Do you just leave it on or?
  11. Apr 11, 2020 at 5:18 AM
    tvpierce
    Maine
  12. Apr 11, 2020 at 6:11 AM
    Captainjohn
    Captainjohn New Member
    2019 Tundra Dbl cab
    Rock sliders, topper, sliding bed
    Nothing beats a good coat of wax on paint
