Tinting tail lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by RocSteadyNy, May 10, 2019.
  1. May 10, 2019 at 12:46 PM
    RocSteadyNy
    RocSteadyNy [OP] New Member
    Dale
    Rochester
    2019 Calvary Blue Tundra SR5 TRD Offroad CM
    The stock tail lights are the hardest thing to tint!
    It took forever to do that one.
    Ostrich, louscrw and TXMiamiFan like this.
  2. May 10, 2019 at 12:48 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    hopefully the 2nd one will be a little easier/faster. I really want to do mine
  3. May 10, 2019 at 12:51 PM
    Looks great. :thumbsup:
  4. May 10, 2019 at 12:51 PM
  5. May 10, 2019 at 12:52 PM
    RocSteadyNy
    Dale
    Rochester
    It's not the prettiest job. I did it off the vehicle. The second one I'm going to try doing on the vehicle. You should do it. Cheaper than swapping them out. I'm using vivid+ air release headlight tint. I did it previously with some wet application but that didn't go on so well because of the vortex generators
    Pudge likes this.
  6. May 10, 2019 at 12:53 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Thinking a lite coat of Linex in a can may be easier...... :)
    RocSteadyNy[OP] likes this.
  7. May 10, 2019 at 12:53 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    Wait. How? spray? if it was vinyl how did you get over the fin? Could you take a closeup up the fin if you did it with vinyl?
    Also, did you switch to LED to increase light output?
    ****you posted at the same time I did. Still interested in the closeup of the fin and how TF you did it!
    DesertRoads and RocSteadyNy[OP] like this.
  8. May 10, 2019 at 12:56 PM
    RocSteadyNy
    Dale
    Rochester
    I did a spray and it looked horrible! I used vinyl it's not so pretty around the fins. I'll get a close up. I have plenty of tint so once I get the other side done if I do a better job I will redo the left side. To get over the fins I made a small hole in the tint to get air out. I have led tails light bulbs on order... will be here tomorrow
  9. May 10, 2019 at 1:00 PM
    RocSteadyNy
    Dale
    Rochester
    Like said, it's not pretty. Once I do the other side I'll know if I can do this successfully. It was hard off the truck.. but it's so windy outside I didnt want to do it... maybe I'll get to the other side tomorrow if it's not so windy
  10. May 10, 2019 at 1:01 PM
    RocSteadyNy
    Dale
    Rochester
    I do think I can get it around the fins properly. When I get to the other we will see though. Might not be able to do it good enough.
  11. May 10, 2019 at 1:30 PM
    Trooper2
    JR
    JK, being silly. :rofl:
    Would think Linex coated lights would not turn out well, would also need mega LED Lumens!
  12. May 10, 2019 at 1:49 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
    I spent at least 2 hours tring to get the fins to look perfect. Watched several videos on how to wrap complex shapes and threw in the towel.
    Good luck though!
  13. May 10, 2019 at 2:04 PM
    TheBeast The Beach
    paint and clear coat is the best.
  14. May 10, 2019 at 2:05 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Agree never have to worry about them again!! I had it done in my 08 now I need to find some one to do my 17.
    TheBeast[QUOTED] likes this.
  15. May 10, 2019 at 2:07 PM
    TheBeast The Beach
    I paid $60 to get my 2 tail lights and brake light cover done. local paint guy in the South bay. was worth it.
    jewsNbrews likes this.
  16. May 10, 2019 at 2:10 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    That’s cheaaappp. My friend did mine but he’s long gone from Cali so now I’m looking.
  17. May 10, 2019 at 2:15 PM
    RocSteadyNy
    Dale
    Rochester
    I may have to look into that... I have a spray gun just never really thought of doing that... hmmm. YouTube here I come
  18. May 10, 2019 at 2:23 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    What my friend did was get clear coat and add couple dots of black paint until you get the tint you want and spray away
    TheBeast likes this.
  19. May 10, 2019 at 5:44 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    One of the faster ways to get pulled over here in TX
  20. May 20, 2019 at 5:45 PM
    kleiker0303
    kleiker0303 New Member
    Kyler
    Kansas City
    ‘16 Platinum
    Bilstein 6112 @ 1.9" Bilstein 5100's in rear Afe drop in filter Afe intake tube Afe throttle body spacer Afe catback with vibrant resonator added Stubby antenna TRD front grill Paint matched door handles Paint match mirror caps RCI skid plate All LED bulbs Undercover flex cover 20% tint all around Husky floor liners ESP under seat storage 2018 headlight mod Baja designs fog light kit 275/60/r20 falken wildpeak at3w 20x9 fuel ripper
    How did the other side turn out? Did you use a heat gun to try to get the vinyl around the fins? Been thinking about doing this on my truck and have been hesitant. Do you have a link to the vinyl you used?
  21. May 20, 2019 at 6:11 PM
    RocSteadyNy
    Dale
    Rochester
    I have not had a chance to get back out there... it's been rainy and windy. Hopefully I'll have sometime to clean the garage out and get back to it... here is a link for the tint I used VViViD Air-Tint Dark Black 20%...
    I did use a heat gun. I need to replace my xacto blade cause the one I used wasn't very sharp. And it may help to poke holes in the tint to get air pockets out. For just having the one side done I got a lot of compliments. And the tint is the perfect color
  22. May 20, 2019 at 6:17 PM
    kleiker0303
    Kyler
    Kansas City
    ‘16 Platinum
    Good to know. 20% looks about perfect, just wondering if you've ever thought it was too dark? How does the light transfer through it during the day?
  23. May 20, 2019 at 6:58 PM
    RocSteadyNy
    Dale
    Rochester
    So I had my friends behind me one day when it was super bright outside and they said it looked bright. They said that although it was tinted they could see the brakes and turn signal. Also I had my wife step on the brake so I could see and it looked well lit in day light.
  24. May 20, 2019 at 7:03 PM
    kleiker0303
    Kyler
    Kansas City
    ‘16 Platinum
    Thanks for the input!
  25. May 21, 2019 at 9:49 AM
    RocSteadyNy
    Dale
    Rochester
    If you end up tinting it share some pictures. Also I just thought about this... I used heat gun but I think it was way too hot. Next time I'm going to use a hair dryer
  26. May 21, 2019 at 10:04 AM
    kleiker0303
    Kyler
    Kansas City
    ‘16 Platinum
    Just ordered some tint. I'll post pics if it turns out ok... hahaha
  27. May 21, 2019 at 10:06 AM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore, My Factory Skid Plate Was Stolen
    Tinted tail lights look great until I rear end you in broad daylight because your tail lights are too dark for me to see that you're stopping or turning. I hope you've put brighter bulbs in to compensate for the darker lenses?!?
  28. May 21, 2019 at 10:07 AM
    kleiker0303
    Kyler
    Kansas City
    ‘16 Platinum
    I have led bulbs in there now and they are bright.
  29. May 21, 2019 at 10:45 PM
    Yota707
    Yota707 New Member
    David
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    I used a spray gun and black cherry paint. Came out fine around the fins
    Pudge and RocSteadyNy[OP] like this.
  30. May 22, 2019 at 5:55 PM
    ohmyheck
    ohmyheck New Member
    2016 DC SR 5 w/ sweet valve stems
    Driver side handle, Shift knob, sway bar tonneau cover, leveled, 2018 OEM fogs, 275/70 KO 2's and sweet valvestems
    I am impressed with everyone’s ingenuity and willingness to try new things. I will follow others example after they have already got the bugs out. Personally,though, I can never figure out why tail lights ( or headlights)need to be tinted to make them darker. I always want the brightest lights for others to see me. Here in Utah,with the selfish and fickle drivers, I need all the warnings I need to dodge the idiots!
    French Avocado likes this.
