Timing chain tensioner - does it need to be replaced?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Fundra14, Oct 3, 2023.
  1. Feb 28, 2025 at 8:15 AM
    AZBoatHauler
    So.Arizona
  2. Feb 28, 2025 at 8:26 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    I don't doubt that it could eventually lead to a failure. CCN implies the same by saying it does need to be fixed, the question is how soon.
    However, that was the only post made by that user and there was no other information given. Lack of data = lack of credibility
  3. Feb 28, 2025 at 9:18 AM
    Care car nut…. :facepalm:
  4. Feb 28, 2025 at 12:07 PM
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    Mine was pretty noisy, I tried a couple of synthetic 5w30s, when I swapped to Amsoil, it got quiet and hasn't made a noise sense.
  5. Feb 28, 2025 at 4:09 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    "Hasn't made a noise sense."
    So several 5w 30 didn't help...
    So that means you haven't started it. Or you work for or have stock in Amsoil?
  6. Feb 28, 2025 at 4:42 PM
    Tried Mobil 1 5w30 for 5k miles - still noisy
    Tried Supertec 5w30 for 5k miles - still noisy
    Tried Kirkland 5w30 for 5k miles- still noisy
    Tried Amsoil 5w30 - Quiet
    If you're ever in Orlando FL you are more than welcome to come listen to the truck. If I'm lying, I'll buy you a 12 pack.... but if I'm right - you have to video your apology and post it here...lol.
    Also, other than being a customer, I have nothing to do with Amsoil.
    Mater, Js18tundra and FabioXc like this.
  7. Feb 28, 2025 at 5:28 PM
    Adamace1
    Adamace1 New Member
    None....
    I thank you for the info. I also didn't get improvement with thicker oil. Now I'm wondering if Amsoil is really that good. Maybe it's worth the price...
  8. Feb 28, 2025 at 5:38 PM
    You're welcome.
    I read about someone on here trying different brands and running an analysis on each oil change. He had also mentioned that amsoil made it quieter, so I gave it a try.
    It is worth it to me. Just wait for a sale on their website and you can get free shipping.
    FabioXc likes this.
  9. Mar 6, 2025 at 6:47 PM
    FabioXc
    FabioXc New Member
    None
    Well I started that thread when I first got the truck I was shocked at first of the rattling sound but seems like it hasn’t caused major motor fails .I’ll change it to 5w30 next oil change but other than that it’s still there but I do wanna fix
  10. Mar 7, 2025 at 1:13 PM
    j6y
    j6y Recovering Perfectionist
    16’ Moby Dick
    Mine does the same on 5w30 but only when it's cold and on my driveway which is inclined for about 2 seconds!
    Its odd and just started overnight it seems (5k oil changes @ 108k)
    FabioXc likes this.
  11. Mar 7, 2025 at 9:15 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    As an Amsoil salesman, and an avid user. I can attest to hearing of his experience. Also have had clients say it got rid of their tick in their hemi’s. On a side note, haha, if anyone is interested in purchasing let me know!
  12. Mar 8, 2025 at 3:29 AM
    Adamace1
    Adamace1 New Member
    None....
    I thought the "Hemi Tick" was a exuast manifolds leak? How would Amsoil leak out of the motor then fix a leak in an area that is so hot it would instantly burn the oil?
    Does Amsoil also fix the dreaded chevy ignition switch problem?
  13. Mar 8, 2025 at 12:37 PM
    Js18tundra
    The exhaust manifold issue is one of them, but they also have lifter issues as well. We ran the cleaner through it, filled it up with signature 0w-20, and has been quiet since ‍♂️.
  14. Apr 19, 2025 at 9:29 PM
    Tim98TA
    Tim98TA New Member
    I had the dreaded timing chain rattle. After hearing several people tried the Valvoline Restore and Protect, I tried it with my oil change last week. Unbelievably no rattle any longer. I'm sold.
    FabioXc, j6y and KNABORES like this.
  15. Apr 21, 2025 at 9:37 PM
    j6y
    16’ Moby Dick
    Under what conditions were you getting the rattle? I have a slight rattle for about 1-2sec only under certain conditions.
    Nose up on the driveway (its steep) and under a 40 degrees ambient temp cold start, outside of that I get zero rattle.
  16. Apr 21, 2025 at 10:02 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    Depends on where your getting parts toyota kit with everything is 1000 bucks I would not buy some cheap internet partially you will do is put a new one on. These hydraulic tensioner have a built in lock to keep it tight. I put 365000 on it 200000 of those it has rattled
  17. Apr 21, 2025 at 10:04 PM
    Vince
    Vince New Member
    Vincent
    Youtube car care nut old toyota mechanic explains stuff very well. Learned a lot by just listening to him speak.
  18. Apr 22, 2025 at 5:12 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    I have an opinion based on what I have seen (various teardown videos etc.).
    I believe that it is a combination of three things:
    1. 1. Space and leverage of the driver's side tensioner vs. the passenger side. The driver's side has a big leverage disadvantage and requires more force to keep the chain tight. This also allows the chain to push it back much easier. If you take #2 and #3 below and this creates a perfect storm.
    2. Tolerances. The problem is the most persistent when the temperatures are cold. I believe that the fit of the piston to the housing is just a little too tight when cold causing the piston to hang up in the bore. Just a little, but enough to where it will take a second or two to rebound. This is not an issue when new and everything is clean but just a little oil varnish makes the problem apparent.
    3. Oil varnish. Just a little around the bore causes the tensioner to be a little sticky.
    The driver's side also has a small check valve in it. I did not see this on the passenger side in the teardown video. I am not sure what this is for or what it does but could this be limiting pressure in the unit? If the pressure is limited, does it allow more chain movement?
    I am willing to bet that the guys/gals who do very little short runs and a lot of long distance with their trucks will not see this as frequently. This would IMO follow the varnish theory. Does the million mile 5.7 have this problem? I would bet that it does not.
    I am intrigued by the posts above claiming that different oils eliminated the issue. Is a different oil with a very high detergent (Restore and Protect/Amsoil) enough to remove some of this varnish? Is it that simple?
    I do not believe the this rattle only at cold is harmful. I do not believe that it will ever harm the engine. But I do agree that it is VERY ANNOYING and makes your truck sound like a total pile of crap. I have been there :) It only feeds my hate of timing chains...... Can I have my timing belt back?
