Timing chain replaced...truck won't start!!!
Discussion in '2nd Gen Tundras (2007-2013)' started by Twintowers11, Dec 22, 2020.
  1. Dec 31, 2020 at 3:04 PM
    #61
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    It's possible that the low number on 8 was from the cam being off the 20 deg you found. It may have opened the valve early before pressure maxxed. It might not hurt anything more if you set it right and tried running as is.
  2. Dec 31, 2020 at 5:22 PM
    #62
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    I think I would put the chain, gears, and tensioner on and do a compression check before I put it all the way back together or tore it down more. See what the compression numbers are with it in time.
  3. Dec 31, 2020 at 5:22 PM
    #63
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Don't pull the head! If anything, you could snake a bore scope into the spark plug hole and look for dents (shiny metal dents at least) in the piston. 20 degrees doesn't seem like the end of the world, I think you'll be OK. I would do a compression check on 8 though after you have it all together.
  4. Dec 31, 2020 at 5:24 PM
    #64
    Twintowers11
    Twintowers11 [OP] New Member
    Phil
    2011 red tundra 5.7
    Appreciate it guys...I will put the chains on tomorrow and do a compression check...
    worktruckwhite likes this.
  5. Jan 1, 2021 at 2:59 PM
    #65
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    I would correct the timing and recheck the compression. At that point if it is ok, it is a win win. If not then do the head. Like I said a borescope would rule that out. You can buy one very cheap for your smart phone if you have one and they work great. You can even take pictures with it. Just my opinion.
    Amazon.com : inspection camera
  6. Jan 1, 2021 at 5:14 PM
    #66
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
  7. Jan 27, 2021 at 1:41 AM
    #67
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    So......what happened? Fixed?
