Timing Chain Possibly Getting Ready to Grenade?
Discussion in '2nd Gen Tundras (2007-2013)' started by 650h1, Oct 19, 2017.
  1. Mar 17, 2018 at 7:35 AM
    #121
    No kidding. Looked into it...wrong one.
    Good eye.
    BTBAKER[QUOTED] likes this.
  2. Mar 17, 2018 at 7:36 AM
    #122
    I looked, they have not changed.
    BTBAKER and epa4wd[QUOTED] like this.
  3. Mar 17, 2018 at 7:38 AM
    #123
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I can’t help you in that one but it is different than my 17. It also appears not be be plastic which comes stock normally. They make an OEM aluminum but that doesn’t look like it either. If you’re leaking it could be the gasket placement which is critical or either to loose or to tight. I believe the specs are 18 ft lbs on the filter housing and 9 on the cap.
  4. Mar 17, 2018 at 7:41 AM
    #124
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Something doesn’t look right but I could be wrong.
  5. Mar 17, 2018 at 7:41 AM
    #125
    well maybe the 4.6L is different?
  6. Mar 17, 2018 at 7:42 AM
    #126
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Very well could be.
  7. Mar 18, 2018 at 9:34 AM
    #127
    Thee_Oddball
    Thee_Oddball New Member
    Eric
    Chicago
    2013 Double cab 4x4 5.7L, 78,000 miles, Nautical blue.
    So that tapping in my 5.7 I hear from a cold start for about 3-4 minutes in normal?
  8. Mar 19, 2018 at 6:27 AM
    #128
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    If it's the same noise that has been reported and asked about frequently starting back since 2007 when the second gens came out with the 5.7... then unfortunately I would have to say yes. Mine does it, iv had people ride along and askif it was a diesel, seems the 5.7 is just a growly beast on an engine. I also have an extended warranty....so in the event something was to happen I feel warm and fuzzy. Until then I know what noises the truck/engine make and until those known noises change for the worse, i have no worries .
  9. Mar 19, 2018 at 7:19 AM
    #129
    Thee_Oddball
    Eric
    Chicago
    thnx for responding, I also bought an extended warranty for 3/36 that will replace almost everything.
    apparently it's not just Toyota, when i test drove the new 1500 on Tuesday it sounded like it had a spun main bearing when i started it, i told the service manager and he said that was normal, it was the fuel injectors......
  10. May 10, 2018 at 6:48 AM
    #130
    xstevo76x
    xstevo76x New Member
    Thanks to the OP for the post.... I've been struggling for a year now to figure out the noise my truck is making and it is identical to yours. Mine is a 2010 with 226k Kms(141k Miles)
    Exact same noise... runs fine for a couple mins then noise starts... cycling clicking noise(only at idle), then goes away after 3-4 mins when truck is up to temp. Dealer couldn't diagnose and nobody could give me a straight answer... I suspected it was a tensioner.. but could never find hard proof until this thread.
    Unfortunately I have no warranty left so I'm gonna eat a hefty bill... but I love this truck and it's worth it... Just called toyota for a quote and I'll update with cost.
    TexasTundra27 likes this.
  11. May 29, 2018 at 2:46 AM
    #131
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    What did the quote end up being?
    SOTABOY likes this.
  12. Jun 30, 2018 at 2:19 PM
    #132
    TexasTundra27
    Mark
    I’m having my tensioners and guides replaced this coming Thursday, was quoted right at $3000 to have it done. Glad I found this thread to finally help me pinpoint my problem, having the work done a week before I leave for a 2500+ mile road trip
    SOTABOY likes this.
  13. Mar 6, 2019 at 6:32 PM
    #133
    SOTABOY
    SOTABOY Yota fam!
    Bjorn
    2012 5.7 Platinum 4x4 NOT Flex!
    Borla dual exhaust Light bar / ditch lights Readylift 3/2 leveling kit BFG K02 33's K&N intake shroud More to come...
    Well shit... I'm a little above 140k on my '12 platinum - well out of warranty. Been hearing this exact sound for the last couple months... Couldn't pinpoint it but had a feeling it was the tensioner.... Wonder what parts woyld cost to do this work myself? And is that even a good idea?.... Thoughts?
  14. Mar 6, 2019 at 6:53 PM
    #134
    TexasTundra27
    Mark
    I wanna say it’s around $700-$800 for parts from Toyota
    SOTABOY[QUOTED] likes this.
  15. May 3, 2019 at 6:04 PM
    #135
    caperstu
    caperstu New Member
    I have the same noise going on with my 2014 Tundra I was told by the dealer in Whitehorse Yukon that it’s a timing chain issue they are going to replace all under warranty.
  16. Nov 8, 2019 at 2:26 PM
    #136
    Tundratrd13
    Tundratrd13 New Member
    Hey I’m new to the site , I have a 2011 Tundra Trd that has the same noise as yours. I read the thread and was wondering how you made out with repairs done by the dealership.
  17. Nov 22, 2019 at 6:38 PM
    #137
    SnowSurfer
    SnowSurfer New Member
    back in the day i re-built an 88 Suba Gl Turb Wagon. "theWhiteSleepa" she was a bad bitch. But threw an old SUbaru forum , i was lucky to have had the help from an old timer from the navy , he was a Turbo Specialist , dude was the real deal . Over the freaking phone , a land line mind u. the dude was able to tell me what injectors were bad , cam noises , lifters , etc by me placing the long driver onto certain spots and holding it to the f-ing receiver . i was a young grom at the time and it was my 1st engine "build" , my mind was blown . the dude was so legit.
    but since then , the long driver stays in the truck. So i can just listen to things .. lol .. like a stethoscope :laser:
    Les7311[QUOTED] likes this.
  18. Nov 22, 2019 at 7:29 PM
    #138
    Blue4x2
    Blue4x2 New Member
    2007 SR5 Double Cab
    AMP power steps Corsa catback exhaust BHLM Toytec Boss Aluma series Leveling kit 295/60 Falken WildPeak AT3 20” XD Monsters II w/ 0 offset
    I Have the exact same noise as the video in the op. Truck currently has about 152000 miles and the noise started at around 150000. Definitely worried and have no idea what it could be reading through this entire thread. Most annoying part of it is probably op and the other couple of people in this thread who also had this issue and never reported back...
  19. Nov 23, 2019 at 2:58 PM
    #139
    Blue4x2
    Blue4x2 New Member
    2007 SR5 Double Cab
    Lol. Maybe why the op and the couple of other people who had the same problem and never reported back were too embarrassed to. So in my case, I could hear the same sound coming from the video in the op from the cabin. At first I thought it was just the dashboard making noise as the temps have gotten quite chilly around here. As I left the ignition on and went inside a gas station, I could here the sound coming from where approximately the 5.7 badge is located and I popped the hood and could hear the sound even more clear and loud. As some might, I expected the worst and became quite worried. I was sure that it was coming from the engine bay from somewhere as the sound definitely was coming from there.
    Well today as I was cold starting my truck and the sound was louder and lasted longer than ever (as mentioned in the op about 3-5 minutes), I got perturbed and was about to start ordering some parts for process of elimination. Before I got online and started throwing away $, I decided to look in the wheel well out of desperation; As strange as it sounds, the sound was there but not nearly as loud and clear like from under the hood. Being so sure and looking for any confirmation biases that it was coming from the under the hood, I didn't notice that one of the clips in the wheel well liner was not connected:
    Put the clip back through the well liner and snapped it back in place and behold; No more noise!! I'll cold start the truck again tomorrow just to make sure that I got the bugaboo as the sound would only come on at cold start. If that wasn't the fix and just a freak coincidence, then I'll 100% come and report back to not leave anyone who may have had this problem hanging (present or future)
  20. Nov 27, 2019 at 6:39 AM
    #140
    Blue4x2
    Blue4x2 New Member
    2007 SR5 Double Cab
    I’ve been cold starting without that rattling noise for three days straight now. Seems like that was indeed the source of the problem and was the best case scenario for a sound so daunting.
    Looks like I have to replace the front passenger wheel well liner as two of the corners are ripped so the clips can’t go in them correctly. No noise but I can feel some heat dissipating from the liner. I looked on sparks parts but couldn’t find it. Anybody know the part number?
  21. Feb 10, 2020 at 2:27 PM
    #141
    RiverFox
    RiverFox New Member
    10k oil change, boss always said engine work not cheap oil is, clean oil = long engine life, I bought a 2012 toyota tundra with 172.5k on it from a ford dealer it has a tiny amout of timing chain noise when first started for 3 to 5 seconds after setting 10 to 12 hours the temp are below 30F is this normal?, I checked the vin on toyota website it had it's first 2 services done at the dealership after that it was back in at 169k for the air pump issue, I just wonder how it was treated, it was a company truck for a construction company that is the main contractor who subs the work to other contractorsit has some minor dings, other then that it runs great, it has the double cab with the 6' what ever bed, I hope it last me long enough to trade up in about 3 years.
  22. Feb 10, 2020 at 3:47 PM
    #142
    KissMyAxe1
    KissMyAxe1 New Member
    Utah
    2008 Black Tundra SR5 Crewmax
    Mine has been doing this. Sounds like a heat-shield is rattling, so hopefully that is all it is. I've seen a lot of other posts about this, and how it only happens on a cold start. I haven't done much digging around though. The oil looks new, and it should be. I would be super bummed if there's a big issue though. I'll do some digging around.
  23. Mar 18, 2020 at 7:26 PM
    #143
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    Ok so I had the same sound it was so bad my wife was sure it was a rod knocking. I even had someone ask me what year did toyota put a diesel in there trucks. All that said I used premium gas I tried barrymans additive. It helped but didnt last long.
    With this last oil change i added 2 quarts of STP oil treatment and 6 quarts of oil. I run conventional oil 5000 mile changes.
    Now I have run Lucas oil treatment in my truck from new and in every oil change and it never helped. The stp (blue bottlel is 2.88 walmart) has stop my knock dead. And has not returned they do offer a synthetic stp (I think it is a gold bottle). Try this might help you out It did me.
  24. Feb 17, 2021 at 11:47 AM
    #144
    Rocko9999
    Rocko9999 New Member
    Did the sound ever come back?
  25. Mar 2, 2021 at 9:50 AM
    #145
    KissMyAxe1
    Utah
    It comes and goes, it's only ever there during a cold start, and it quickly goes away. Could be getting something like a oil preloader (is that the correct term?) to put oil at the top of the engine for cold starts would make it go away too.
    Rocko9999[QUOTED] likes this.
