Timing chain Cover leak. Looking for advice
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra694, Apr 5, 2024.
  1. Apr 26, 2025 at 5:30 PM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    Pull a 180 on a different “stealership.” Right before you take your truck in, take an oil can and hose some motor oil on the area of the leak. Don’t go nuts. Just make it appear more than a weep. If the truck wasn’t under warranty and you didn’t know it was seeping, I guarantee the stealership would bring it to your attention and give you a quote to fix. Fight fire with fire.
  2. Apr 26, 2025 at 5:37 PM
    Tundra694
    Tundra694 [OP] New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    my dumbass would forget to use old oil. Um sir it seems your engine is leaking extremely clean oil ….
  3. Apr 26, 2025 at 6:11 PM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    You would want to use clean oil. Not black oil. You want the leak to appear as an active leak.
  4. Apr 26, 2025 at 8:52 PM
    brown_subaru
    brown_subaru New Member
    Eastern WA
    2021 Tundra SR5 TRD
    Not a bad idea…
  5. Apr 27, 2025 at 2:58 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    if that doesn't work, as a subaru owner, you can just drive right through the front window of the dealer and demand your fix.
    Going to have to peak at mine today. 21 with 34k miles, right around all the posts here.
    brown_subaru[QUOTED] likes this.
  6. Apr 27, 2025 at 1:59 PM
    ToyotaBeast
    ToyotaBeast New Member
    If you don't have warranty I wouldn't do it. Its a very expensive job and I have seem them come back seeping oil again if the prep work is not perfect. Its not worth ripping apart a motor and introducing dirt and debris that will have an affect in the long run. Plus the seeping oil will help present rusting.
    woods and brown_subaru like this.
  7. Apr 27, 2025 at 3:16 PM
    Tundra694
    AJ
    I can honestly say if the warranty was expired I’d wipe it off and pay no mind. Part of me doesn’t want it ripped apart in case someone screws it up the other part wants to fix it under warranty so I don’t have a $3k bill years down the road. My luck they’d put too much sealant on and it would get stuck in an oil journal or something lol
  8. Apr 27, 2025 at 3:30 PM
    ToyotaBeast
    I would go for it under warranty, just request that only a master tech works on it. That would bring me more piece of mind.
    brown_subaru likes this.
  9. Apr 27, 2025 at 5:58 PM
    brown_subaru
    Eastern WA
    2021 Tundra SR5 TRD
    This is exactly how I feel about it.
  10. Apr 27, 2025 at 6:05 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I’d get it done under warranty.. had mine done back in January this year. No more leaking/seeping.. dealer gave me no fuss either. Set appt for inspection, showed up.. an hour later, they said it tech verified timing cover leak. Will order parts needed and get it fix. Set appt to drop off and got a loaner. 2 days later it’s done. I paid nada thing..i like this dealer.
  11. Apr 27, 2025 at 6:27 PM
    brown_subaru
    Eastern WA
    2021 Tundra SR5 TRD
    The problem is that my dealer said Toyota won't cover it under warranty because it is only a "normal seep". So I am going to try another dealer and see what they say.
    BrandonL812 likes this.
  12. Apr 28, 2025 at 8:00 AM
    PRNDS
    PRNDS New Member
    FL
    2021 Black Limited 4x4
    I too have this issue on my 2021 with 57k. Brought it to my local dealer this morning. Was informed by the shop foreman that Toyota will not warranty oil seeps, just leaks only, and they have to provide photographic proof of the leak for warranty approval. I asked about what if it leaks when I'm out of warranty. He said that the leak has been documented under warranty and it does begin to leak outside of warranty, they will submit a warranty claim since it was reported under warranty. He said all they can do is monitor for now.
    I have 61k left on my CPO warranty.
  13. Apr 28, 2025 at 6:50 PM
    brown_subaru
    Eastern WA
    2021 Tundra SR5 TRD
    My dealer told me it would have to progress to a leak before the warranty is up to be covered. He even told me an option would be to pick up an extended warranty. So your dealer sounds better than mine. I am going to try another dealer and see what they say. Plus, I have an inquiry into Toyota with pictures so we’ll see.
    woods and BrandonL812 like this.
  14. Apr 29, 2025 at 6:30 AM
    “J”
    “J” New Member
    NC
    2021 Tundra SR Barcelona Red
    Won’t this gasket be changed when the timing chain is replaced? Wait it out until then……
  15. Apr 29, 2025 at 8:23 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    I like how the dealer thinks seepage is “normal.” Kind of like waste seeping around the base of a toilet. It’s not leaking it’s just seeping. That’s a complete joke in my book. So glad I never bought any warranty and all the bullshit from a dealer that comes with it.
  16. Apr 29, 2025 at 2:41 PM
    Tundra694
    AJ
    this gives me hope thanks lol my corporate claim was assigned to a rep waiting to hear back.
  17. Apr 29, 2025 at 7:02 PM
    ToyotaBeast
    That's true the dealerships have to submit photo proof to toyota. A leak must to have a drip.
  18. Apr 29, 2025 at 7:50 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Oil seeps turn to oil leaks eventually. Insist on a repair. As already mentioned, apply a little oil at the seep to make it look like a drip. Do this a couple of weeks before the inspection. Give the dealership a call and tell them it is now spotting your driveway and you need it fixed. I realize that you had an issue with an oil change at the dealership but the guy doing service work is not the same guy doing the timing cover. Service work is an entry level job at the dealership.
    gizardlizard likes this.
  19. Apr 30, 2025 at 4:34 PM
    #49
    Tundra694
    AJ
    toyota corporate called today. Discussed the issue for 20 minutes or so and they’ll be reaching out to my dealer next. We. Shall. See.
  20. Apr 30, 2025 at 6:18 PM
    #50
    brown_subaru
    Eastern WA
    2021 Tundra SR5 TRD
    Nice! Good luck!
    I received a notification that a case manager was assigned to mine, so hopefully I’ll be getting a call soon as well.
  21. May 1, 2025 at 1:52 AM
    #51
    Tundra694
    AJ
    yea I got a call the day after that notification.
  22. May 1, 2025 at 12:22 PM
    #52
    brown_subaru
    Eastern WA
    2021 Tundra SR5 TRD
    I talked to Toyota. They talked to my dealer and got a story from them. Then they got the story from me. Then they told me the same thing as the dealer. It has to be dripping to result in a repair under warranty. They even said oil needs to be hitting the driveway to be considered a leak. It ended with Toyota saying that my issue is documented and to contact the dealer and Toyota if it gets bad enough to drip even if I’m outside of warranty, but they wouldn’t commit to covering it.
    In summary, they told me to go pound sand.
  23. May 1, 2025 at 1:47 PM
    #53
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Well if it’s not leaking, they aren’t going to do a thing for you. In a couple of months add some oil for a couple of weeks. Take pictures of the spots on the driveway and then bring it in.
  24. May 1, 2025 at 1:50 PM
    #54
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    should have sprayed that bitch with oil like I said. Again, you need to fight fire with fire. Fuck em. Go to another dealer and be prepared this time.
  25. May 1, 2025 at 2:26 PM
    #55
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    He really can’t do that for at least a couple of months. Toyota corp will now have a case open and will get very suspicious if it shows up at another dealership a week later. It’s really not a dealership issue. I’m sure they would love to get paid but if Toyota Corp says no they aren’t going to get paid.
  26. May 1, 2025 at 5:23 PM
    #56
    Tundra694
    AJ
    Yea I’m expecting the same but at least it’s documented for whatever that’s worth. Hey it’s documented sooo we might warranty it but maybe not lol
  27. May 1, 2025 at 6:20 PM
    #57
    brown_subaru
    Eastern WA
    2021 Tundra SR5 TRD
    Hopefully you have better luck than I did.
  28. May 1, 2025 at 6:21 PM
    #58
    brown_subaru
    Eastern WA
    2021 Tundra SR5 TRD
    I have a couple of long trips planned this summer including with a travel trailer. So I’ll see how it looks after that. Appreciate the feedback from everyone on this.
    Ruggybuggy likes this.
  29. May 2, 2025 at 7:55 PM
    #59
    ToyotaBeast
    Well Hopefully you don't run over any oil bottles on your trips and it happens to get drips from the engine that would be a shame.
    Tundra694[OP] likes this.
  30. May 7, 2025 at 4:25 PM
    #60
    Tundra694
    AJ
    Toyota case manager called today and said after reviewing the case they believe it should get repaired under warranty and told me that they’ll notify the dealer of the case and that the dealer will be contacting me to schedule service. Maybe I got lucky I dunno.
    Ruggybuggy, 00h2itr and BrandonL812 like this.
