timing belt / serpentine belt
Discussion in '1st Gen Tundras (2000-2006)' started by timo_berg3, Sep 22, 2024.
  1. Sep 22, 2024 at 3:25 PM
    timo_berg3
    timo_berg3 [OP] New Member
    I replaced my timing belt on my 2002 Toyota tundra. I used the aisin timing belt as recommended by someone on tundras.com. after I put everything back together and started my truck it shredded my serpentine belt and then I bought a new one and it shredded that one too. after further investigation I noticed my fan pulley is sitting farther back than the rest of the pulleys. does anyone know why that would be or how I can fix it?
  2. Sep 22, 2024 at 4:59 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    Pics would help greatly
    G_unit3000 likes this.
  3. Sep 22, 2024 at 6:28 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    What year and engine? What parts did you replace? Did you replace the fan pulley bracket? Did you seat the fan correctly? What about the tensioner and idler assembly. Photos please.
  4. Sep 22, 2024 at 7:32 PM
    AZBoatHauler
    So.Arizona
    Any chance you put the studs in the front cover in the wrong position?
    FrenchToasty likes this.
