Timing belt replacement.
Discussion in '1st Gen Tundras (2000-2006)' started by Dot, Jan 10, 2016.
  1. Jan 10, 2016 at 3:58 PM
    Dot
    Dot [OP] New Member
    I've got 89,000 miles, 2005 V8. I've had friends go 150,000 miles before replacing. Anybody have one break?
  2. Jan 10, 2016 at 6:33 PM
    Mike Tread lightly.
    south carolina
    Don't let it break. 2uz-fe it is a interference engine. Major damage will happen.
  3. Jan 10, 2016 at 7:04 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    What he said^
  4. Jan 11, 2016 at 6:40 AM
    ToyotaTundraMike
    2015 Tundra
    My 06 Tundra got about 130k before I realized I should probably look into it since I got the truck at 80k, and decided to replace it (and the water pump at the same time) before it was too late. Of course that was several years ago and I wouldn't rely on many belts to last 10+ years, specially one that could potentially cause some major damage if it were to break. If your pushed for cash you could probably put it off for a little bit (and I doubt anyone here would recommend that you do so), but there is a reason they say to replace it at 90k.
    4x4toy likes this.
  5. Jan 12, 2016 at 3:00 PM
    Dot
    Dot [OP] New Member
    Thanks all
  6. Jan 27, 2016 at 8:42 PM
    Rkcruza
    Rkcruza New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    What they all said! You don't want it to break. Mine went about 10 years and was replaced at 90k. As stated, replace the water pump also as it is fairly cheap and you'll be right there when you do the timing belt.
  7. Jan 29, 2016 at 11:08 AM
    monocogger
    monocogger New Member
    Tyler
    2001 Tundra V8 2WD TRD Acess Cab
    I just did mine @ 296,346 miles last weekend. The last it was done was a t 140K. So thats... about 156k miles. I got lucky and it just skipped a tooth and didn't break. It's a solid weekend's worth of work but doable with a little mechanical knowledge. The A1Auto's youtube video was a lifesaver!
