Timing belt off one tooth?
Discussion in '1st Gen Tundras (2000-2006)' started by Woodyxr, May 20, 2023.
  1. May 20, 2023 at 6:17 AM
    Woodyxr
    Woodyxr [OP] New Member
    2004 DC, 2006 DC
    I recently bought a 2006DC Limited with 198k. Drove it home and immediately replaced the timing belt so I didn't really have any seat time before changing the belt. I did the work and double checked the marks and all seemed good. Truck started fine and runs ok, but has what seems to be some valve clatter under light acceleration. No lights on the dash. I'm wondering if the timing could be off by one tooth? Would that throw a light or code? Any input is appreciated.
  2. May 20, 2023 at 7:45 AM
    Mr Badwrench
    Mr Badwrench New Member
    I've got valve clatter too. It's mainly when the engine isn't up to operating temp. If the alignment marks lined up, then you got it.
    Woodyxr[OP] and des2mtn like this.
  3. May 20, 2023 at 7:50 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    These trucks are a little noisy, almost like a sewing machine. The steering shaft seal is often shot by this mileage and this can increase the drivetrain noise you hear in the cab. Read about replacing it here: https://www.tundras.com/threads/diy-steering-shaft-seal.48664/
    You could always put the crank at zero degrees, then pull back both the timing covers check that the marks on the cams are matching for self assurance.
    Woodyxr[OP] likes this.
  4. May 25, 2023 at 11:06 PM
    dmamrenko
    dmamrenko New Member
    Dennis
    Salvage Tundra Rebuild
    Minor
    I am still not done on my 04 and am so so nervous to start it up when I finish. This is my first timing belt job and I replaced other components.
    Did your finished product look something like this?
    Sunnier, shifty`, bmf4069 and 2 others like this.
  5. May 25, 2023 at 11:19 PM
    Casper421
    In the woods
    06 DC
    You’re good to go
  6. May 26, 2023 at 5:41 AM
    Which is actually kinda funny, because Toyota also made embroidery, knitting, and sewing machines :rofl:
  7. May 26, 2023 at 6:12 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Learn something new everyday!
  8. Jun 1, 2023 at 11:23 PM
    Jack87
    Jack87 New Member
    Jack
    Denver, Co
    2001 White Tundra TRD AC Limited 4WD
    Pretty much stock
    This should be ok as your at top dead center but personally I did mine at the "T" marks which is meant for the timing belt maintenance. Important part is to move the belt slack to the left side where the tensioner is before pulling the pin.
  9. Jun 1, 2023 at 11:25 PM
    Jack87
    Jack87 New Member
    Jack
    Denver, Co
    Pretty much stock
    I have always liked sewing machines!
