Time to replace my gas grill, need some recommendations!
Discussion in 'Off-Topic Discussion' started by frichco228, Jul 13, 2021.
  1. Jul 21, 2021 at 3:58 PM
    #61
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    More of a technique than a recipe.
    I use 80/20 ground beef and weigh them out into 1/4lb loosely packed balls. No need to form a neat ball, it's going to get smashed anyway.
    I use 1/4lb balls because those fit my smash burger press without oozing out the side. Most adults will use 2 patties per burger, wives and kids use 1.
    I heat the griddle to about 450 and smash the burger on it and hold it down for a few seconds, using parchment paper between the patty and the press so it doesn't stick to the press. I used to put a little oil or butter down, but now I don't. The cleaner/drier the surface is, the more it sticks to the griddle, which is what you want for the best crust.
    Cook until the fat starts bubbling through the other side, and the sides of the patty turn brown, then flip.
    You're going to need a quality burger turner with a very sharp edge, because that patty is going to be stuck AF to the griddle. It needs to be wider than the patty, so get a wide one.
    Come at it at a 45 degree angle, and try to scrape the whole burger up without having any stick to the griddle. You'll probably butcher the first patty until you get a feel for what's going on. The founder of Smash Burger has a good YouTube vid on the technique.
    If you cook another round of patties I always degrease by adding water and scraping it across the griddle and into the trap. The fat left behind from the previous batch is enough to make the patty not want to stick, so the crust is never as good as the first round. Even if you wipe it down, it won't stick, so cleaning with water is important.
    Flip, add your favorite seasoning, throw the cheese on. After flipping, the burger stays on only long enough to melt the cheese.
    With thicker cheese I like to put a cheese melting dome over it to along with a spritz of water underneath to speed it along. At the point you flip the burger, it's basically done so you don't want it cooking for a long time or it will get dry.
    Toast the bun, mayo on both sides (it helps keep the bun from getting soggy from the juices of the burger.)
    Shredded lettuce on the bottom, followed by tomato, then the meat. Pickle and onion on top, along with ketchup and mustard.
    NWPirate[QUOTED] and Boerseun like this.
  2. Jul 21, 2021 at 5:41 PM
    #62
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Build your own. I salvaged a nice Weber grill from a guy for cheap. Replaced the regulators, burner tubes, and heat deflectors. I s*** canned the rusted out cart and built a nice outdoor island.
  3. Jul 22, 2021 at 5:27 AM
    #63
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Grillegrates definitely are the best. I have some heavy cast iron “mangrate” brand on my gas grill. They are a huge improvement over grilling on just the factory stuff.
    r1-superstar likes this.
  4. Jul 25, 2021 at 10:17 AM
    #64
    frichco228
    frichco228 [OP] Valued Member
    2016 Crewmax 4WD, TRD Offroad
    As promised, here is what we purchased. I wanted something that had a great warranty, had full replacement parts available, removable drip pan, not huge $$$. So after a lot of research, went with Napoleon. This is the Rogue XT, 3 burner with smoker box. Just did the initial burn in and will be grilling ribeyes for dinner!
    Thanks for everyone's input and feedback. This one was a bit more than I planned to spend but I think the warranty and quality were worth it, $599
    20210725_130344.jpg 20210725_130402.jpg 20210725_130357.jpg 20210725_130724.jpg
  5. Jul 25, 2021 at 10:30 AM
    #65
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    Yes!!!!! Napoleon makes great stuff! You should be really happy with that.
    Hoff likes this.
  6. Jul 26, 2021 at 5:28 AM
    #66
    NWPirate
    Zach
    WA
    Just saw your response, sorry. I missed the notification.
    Thanks for the tips!
  7. Dec 2, 2021 at 5:46 PM
    #67
    thedonn
    thedonn New Member
    A weber summit is about as good as it gets. I git mine for $2500 or so maybe 15 years ago. I dont use gas much anymore but I love that grill!
    BlueCrushSC16[QUOTED] likes this.
  8. Dec 3, 2021 at 6:36 AM
    #68
    frichco228
    Just following up since I saw a recent reply to this post.
    Had the Napoleon for a while now, used it quite a bit and it is the best grill I have ever owned or cooked on! It is amazing for the price. Excellent quality and performance.
    Hoff, WBW and Boerseun like this.
  9. Dec 3, 2021 at 7:22 AM
    #69
    BlueCrushSC16
    Charleston, SC
    Well, I'm moving and can't take the built in Summit with me. I'm having to settle for a less expensive option for now.
    Monument Stainless Steel 6-Burner Liquid Propane Gas Grill with 1 Side Burner Model #77352
    It looks pretty good. We'll see how well it performs. I'm supposed to take delivery on Sunday 12.5
  10. Mar 18, 2022 at 1:45 AM
    #70
    NWPirate
    Zach
    WA
    It's getting close to grilling season, bringing this thread back to life!
    You still liking the Blue Rhino? Any issues?
    I'm going to try and pull the trigger on a griddle soon before there's a summer price bump. Amazon has it for $398 right now.
    ATV25 likes this.
  11. Mar 18, 2022 at 4:00 AM
    #71
    thedonn
    thedonn New Member
    I have a Blackstone that is great. A 36" is $399 when its not on sale. I read that Blackstone was the original but who knows....mine is great
    NWPirate[QUOTED] likes this.
  12. Mar 18, 2022 at 4:55 AM
    #72
    NWPirate
    Zach
    WA
    Good to know, thanks.
    @T-Rex266 What brand was yours again?
    T-Rex266 likes this.
  13. Mar 18, 2022 at 8:24 AM
    #73
    Blackstone. 36” as well. It’s best to pay for the name
    I’ve seen others deform and have issues
  14. Mar 18, 2022 at 8:27 AM
    #74
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I recommend this...
    Boerseun and NWPirate like this.
  15. Mar 18, 2022 at 8:29 AM
    #75
    r1-superstar
    DB
    UTAH
    Yes, they are!!
    Hbjeff[QUOTED] likes this.
  16. Mar 18, 2022 at 11:59 AM
    #76
    NWPirate
    Zach
    WA
    Good point, I didn't even consider that some might deform.
    So Blackstone and Camp Chef are the 2 big names?
    T-Rex266[QUOTED] likes this.
  17. Mar 18, 2022 at 2:32 PM
    #77
    I only have experience with BS. I also bought the soft cover, opposed to hard. Weather can cause it to shrink / expand as I’ve seen some experience issues with that. Just another consideration for the cover
  18. Mar 18, 2022 at 3:10 PM
    #78
    NWPirate
    Zach
    WA
    Right on, thanks.
    I think I'll go with a BS, as far as you know is there only one 36" model to look at?
    I would prefer the grease trap up front, but that's not a deal breaker.
  19. Mar 18, 2022 at 3:18 PM
    #79
    JMB
    JMB I buy Nickelback albums at Target.
    Chesapeake, VA
    2013 Super White Tundra DC
    Three months later, still the same? I got the Prestige 665 last week, cooked two steaks on it last Sunday, it's like learning to grill all over again, so consistent. No hot spots and 1st time I've had 5 burners. And a sear burner. Lifetime warranty on the important stuff and 15 years on everything else sold it for me. Real deal cook tomorrow, 10 steaks and about a dozen chicken kabobs.
  20. Mar 18, 2022 at 3:23 PM
    #80
    thedonn
    thedonn New Member
    I have the hard cover for the griddle surface and if you add something to seal the screws on top its a lifesaver. I cook on mine year round and I don't use. the soft cover. you can see it in this pic hanging off the back
    Boerseun likes this.
  21. Mar 18, 2022 at 3:28 PM
    #81
    thedonn
    thedonn New Member
    I got a traeger last year and after years of only doing charcoal the pellet grill is my go to grill for most things. I still use a smoker for pork butt and ribs and maybe gas for steaks and burgers
  22. Mar 18, 2022 at 3:54 PM
    #82
    NWPirate
    Zach
    WA
    What do you mean to seal the screws?
  23. Mar 18, 2022 at 4:49 PM
    #83
    Yep. More burners too and the area for trash / paper towels
  24. Mar 18, 2022 at 4:54 PM
    #84
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    BAA28AB3-467A-4CC7-81AD-9E6540A3DB4F.jpg Buttermilk pancakes on the Blackstione. Leave it outside under the cover of back porch and a grill cover.
    Need a new grill too for burgers, ribs and such,, looking at NexGrill. They last awhile and if you can get parts they last a bit longer.
    Tundra Dude 45, NWPirate and Hoff like this.
  25. Mar 18, 2022 at 5:03 PM
    #85
    SAGE63
    San Diego County
    So weber bought Ducane and then they created The Genesis series. I have had my Ducane for 24 years now. replaced some burners and plates over the years but still works great. works better than my Built-in Bull16476482029738251805564532965928.jpg
  26. Mar 18, 2022 at 5:22 PM
    #86
    SAGE63
    San Diego County
    love my 2 burner camp chef with griddle have single and double griddle plus burger box use for camping and as a backyard griddle for those taco parties...love my weber kettle for camping too
  27. Mar 18, 2022 at 5:52 PM
    #87
    thedonn
    thedonn New Member
    I have a WSM for ribs, pork butt and thanksgiving turkey, traeger for fish, chicken and pork tenderlon - use this one 3x a week, a weber gas that barely ever gets used and a big green egg that really only gets used for roadside chicken. I must have the right tool for the job lol
    Jernik[QUOTED] likes this.
  28. Mar 18, 2022 at 5:58 PM
    #88
    thedonn
    thedonn New Member
    I almost did that but there is no grease trap that Im aware of. A package of Bacon generates much more grease than I thought it would. the griddle is worth the $ to me just for breakfast prep. Bacon, hash browns, onions - I wish I got mine years ago
    get the griddle just for bacon , steak and cheese, onions and breakfast potatos - you wont regrett it
    Boerseun[QUOTED] likes this.
  29. Mar 18, 2022 at 6:12 PM
    #89
    thedonn
    thedonn New Member
    I thought about one of those but couldnt get rid of my Kettle. DO they have an ash removal system?
  30. Mar 18, 2022 at 6:14 PM
    #90
    Tundra Dude 45
    Tundra Dude 45 New Member
    Eric
    2019 SR 4.6L DC 4X4
    8” BAMuffler, TRD airflow accelerator, front window tint/windshield sun stripe, debadged tailgate 4x4 emblem, trimmed mud flaps, antenna removed stainless screw added, TRD rear sway bar, AFE high flow air filter.
    Just brought this bad boy home! Going to assemble tomorrow. Got the Home Depot card, $50 off and 0% for 6 months. This is my first grill of my life.
    Jernik and Boerseun like this.
