Time between clay bar and polish/wax
Discussion in 'Detailing' started by Outbound, Apr 20, 2019.
  1. Apr 20, 2019 at 2:23 PM
    Outbound
    Outbound [OP] SSEM #2.5, AmeriCanadian, OG 1st Gen Rabble Member
    Aaron
    Northern Alberta
    Would I run into any problems if I broke up my paint correction job into two weekends? Tackle the clay bar this weekend and then the polish and wax next weekend?
    I need to order the polish online and would like to have the chore broken up anyways as I have alot on my plate already.
  2. Apr 20, 2019 at 2:43 PM
    DMB4x4
    DMB4x4 New Member
    2014 Tundra SR5 CM 4x4
    I would recommend to do it in one shot. Anytime you clay your vehicle and drive it again you will be collecting contaminants. I would say a day or two at most, if you wanna get the best results. I usually clay x2 times are year (every 6 mo) and wax x4 times a year (every 3 mo)
    Ps megs clay kit and cleaner wax is what I use. GL:thumbsup:
    15whtrd and Outbound[OP] like this.
  3. Apr 20, 2019 at 2:49 PM
    Outbound
    Aaron
    Northern Alberta
    That makes sense. I guess I didn't think about collecting contaminents. I grabbed the Meg's clay bar kit that came with 2 bars, lube and microfiber cloth.
    DMB4x4[QUOTED] likes this.
  4. Apr 21, 2019 at 1:41 PM
    War Machine
    War Machine SSEM # 5 3MW
    You shouldn’t have any issues whatsoever. That paint won’t get contaminated again in a month, much less a week.
    Black@Blue19 and Outbound[OP] like this.
  5. Apr 21, 2019 at 9:27 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I wouldn't worry too much over a week. Just wash it well. You could look into getting a synthetic clay mitt, like nanoskin, it will cut your claying time down to probably 1/4 the amount, maybe less
    417Tundra and TheBeast like this.
  6. Apr 21, 2019 at 10:17 PM
    TheBeast The Beach
    got a link ?
  7. Apr 22, 2019 at 2:39 AM
    Adam New Member
    Boerseun likes this.
  8. Apr 22, 2019 at 3:45 AM
    War Machine
  9. Apr 22, 2019 at 4:41 AM
    joeyman15
    joeyman15 New Member
    Nanoskin saves so much time, so much faster than
    a claybar. Seems to work just as well for me to.
    War Machine likes this.
  10. Apr 22, 2019 at 4:44 AM
    War Machine
    In case anyone is wondering, it does seem to do as good a job as real clay. One of the members asked me to test it a while back. I did a truck with Nanoskin, then went back over it with real clay. The real clay didn’t pick anything up, so the Nanoskin had gotten it all out.
    NewImprovedRon and Pudge like this.
  11. Apr 22, 2019 at 4:45 AM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    I place the clay bar in the middle of a damp chamois. I can clay bar my car in 10 minutes. no need for detail spray. That being said I like detailing and blowing money lol... so I just bought the nanoskin mitt recently and will be trying that out soon.
    Darkness and War Machine like this.
  12. Apr 22, 2019 at 5:06 AM
    War Machine
    A man after my own heart. No need, but like blowing money.
    Darkness and Faht Nocker[QUOTED] like this.
  13. Apr 22, 2019 at 5:26 AM
    nakota
    nakota New Member
    Phoenix
    @War Machine do you do anything special with the nanoskin when you’re finished using it for the day?
  14. Apr 22, 2019 at 5:31 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
  15. Apr 22, 2019 at 6:02 AM
    Pudge
    CT
    Yes you want some kind of clay lube or detail spray. I use griots speed shine because its affordable.
    War Machine and Faht Nocker like this.
  16. Apr 22, 2019 at 6:05 AM
    Faht Nocker
    Woody
    Milky Way
    if you detail a lot. I suggest buying optimum no rinse. You can make your own detail spray with this stuff. It will last for years. use distilled water and a cap full or so. I believe the instructions are on the bottle of Optimum no rinse. and get a spray bottle from Lowe's or Home Depot.
    War Machine and Pudge like this.
  17. Apr 22, 2019 at 6:13 AM
    War Machine
    I rinse it heavily, then set it out to dry. Then I put it back in the package it comes in.
    NewImprovedRon, Faht Nocker and Pudge like this.
  18. Apr 22, 2019 at 6:16 AM
    War Machine
    I usually use whatever detail spray I have in hand. I generally have several different ones on hand, since I buy stuff way too often. I also have a gallon jug of Blackfire Clay Lube, but I only bought it because it was on sale really cheap and I was already ordering some stuff. I actually haven’t used it yet, so I don’t know if it’s any better.
    @Faht Nocker ’s ONR suggestion is a good idea also. ONR is an outstanding product to keep around anyway.
    Faht Nocker likes this.
  19. Apr 22, 2019 at 10:04 AM
    Outbound
    Aaron
    Northern Alberta
    Lots of great info here. I already picked up Mother's clay bar kit so I'll use that. I have the Nanoskin mitt on my Amazon list so I'll eventually grab one. They're $50+ here though and the clay bar kit was $30.
  20. Apr 22, 2019 at 10:33 AM
    six7zero
    six7zero New Member
    Pacific Northfresh 503
    15 SR5 Crewmax
    @War Machine is it a good idea to use the bar if claying for the first time then switch to the mit? Never clayed my truck since getting 5yrs ago.
  21. Apr 22, 2019 at 10:43 AM
    War Machine
    I’ve only used real clay a couple of times. Once I got the mitt I’ve never looked back. All the ones I’ve done have been for the first time, and it’s worked perfectly. I see no reason to use the real stuff at all.
    It takes way longer to do with traditional clay, and like @NewImprovedRon said, you can clean it if you drop it. Traditional clay is a one time use item, and if you drop it or get something caught in it, it has to go in the trash.
    @Outbound can you return the kit you got? The mitt is pretty much the same price. Using a real clay bar will take hours.
    For me to do the whole process on a truck (wash, iron x, clay, wash again, dry and apply sealant) usually runs dead on two hours.
  22. Apr 22, 2019 at 12:01 PM
    Outbound
    Aaron
    Northern Alberta
    Unfortunately since i already opened the box i cant return the kit. :(
  23. Apr 22, 2019 at 12:07 PM
    Faht Nocker
    Woody
    Milky Way
    I have used clay bar for years. Like I said previously: put the clay bar in the middle of a damp chamois. This cuts the time in half or more. I do a small area then fold the clay bar, repeat. Just make sure to wipe with a dry microfiber after you clay bar an area. wash, clay bar, polish, wax or sealant, done. :thumbsup:
    Outbound[QUOTED][OP] likes this.
  24. May 31, 2019 at 11:23 AM
    Heff
    Heff New Member
    2017 Tundra Limited
    Do y'all polish after clay? I usually don't, but I've read that you are supposed to.
  25. May 31, 2019 at 11:36 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    If not, you have nothing protecting the clear coat.
    JohnLakeman likes this.
  26. May 31, 2019 at 11:38 AM
    Heff
    Heff New Member
    2017 Tundra Limited
    By polish, I mean use a paint correction compound.
    Pudge and Trooper2[QUOTED] like this.
  27. May 31, 2019 at 11:44 AM
    Trooper2
    JR
    Believe only if needed or desired. Would be to address swirl marks and maybe light scratches. Darker colors more prone to see.
    Heff[QUOTED] likes this.
  28. May 31, 2019 at 1:25 PM
    Pudge
    CT
    I have polished after clay to try to remove swirls and scratches. It's not necessary but definitely will leave your truck looking better than if you skip this step
  29. May 31, 2019 at 1:30 PM
    War Machine
    I never have, but yes, it’s generally recommended. It has a lot to do with the condition of the paint to begin with. I think mostly it’s because of marring induced by the clay, but I haven’t ever gotten any marring with the Nanoskin Mitt.
  30. Jun 4, 2019 at 6:45 AM
    briarpatch
    briarpatch New Member
    I have, but mainly if I'd planned on polishing anyway. There can be some micro-marring from clay or clay mitts, but the average person is never going to see that. On the occasional customers car, I'll clay and then 'one step' it (i.e HD Speed, Meguiars D166, Blackfire One Step), unless they're specifically asking for multi-step paint correction.
