Tie Rod Rub
Discussion in 'Suspension' started by khens12, Dec 7, 2019.
  1. Dec 7, 2019 at 9:20 AM
    khens12
    khens12 [OP] New Member
    Kevin
    2018 Tundra SR5 Off-Road 4x4
    - Icon Billet UCA - King 2.5 Coilovers - King 2.0 “Shorty” Bumpstops
    Hey guys. Waiting in line at the tire shop for the new KM3’s to go on and just looking at if it might rub and noticed this.
    the tie rod is hitting the front of the coil on the coil over. How are people resolving this?
    photo attached
    Rica25 likes this.
  2. Dec 7, 2019 at 9:43 AM
    Vizsla
    Vizsla 2 = 2.5
    You can sacrifice some caster and maybe clear, but honestly it’s easier to just ignore it. Think everyone I know rubs there at some point.
    *edit* sorry said that wrong - noticed you have adjustable uppers, can actually lose caster with the uppers and lowers to pull it away.
    joonbug likes this.
  3. Dec 7, 2019 at 9:58 AM
    Blueknights75
    Ron
    Clayton, NC
    Can’t wait to see some pics of those tires on your truck!!
    Rica25 and khens12[QUOTED][OP] like this.
  4. Dec 7, 2019 at 10:37 AM
    khens12
    Kevin
    I hit up the shop to look at the alignment again this week to see if I can resolve it. I have some slight rubbing I will have them look at too.
    thank you very much for the insight.
    Rica25 likes this.
  5. Dec 7, 2019 at 11:36 AM
    TheBeast The Beach
    yes the KING are pretty thick there. if it's not the tie rod, it's the sway bar end links usually. An alignment might give you a bit more clearance.
    joonbug, Rica25 and khens12[OP] like this.
  6. Dec 7, 2019 at 11:36 AM
    TheBeast The Beach
    35"s KM3 ? ;)
  7. Dec 7, 2019 at 11:38 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Mis alignment spacers in correctly?
    I ask because I have 7 degrees caster and 3.0 shocks and I barely touch.
    Rica25 likes this.
  8. Dec 7, 2019 at 11:46 AM
    khens12
    Kevin
    I’m almost 100% sure it’s the tie rods. The Sway bar was removed when I did the lift. I’m going to have them look at alignment and see if I can gain any room with the icon UCA’s.
    basically - went 315/70r17. With the 8.5” wide icon wheel it sucked up a little bit of the width of the KM3.
    I sure hope they are... I didn’t personally do the install but I know plenty of shops have installed them incorrectly. Are you talking misalignment on the UCA bolt at the top or on the bottom mount of the shock?
  9. Dec 7, 2019 at 11:49 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    I was referencing more so the bottom in the LCA. That would have a light influence on coilover position.
  10. Dec 7, 2019 at 11:51 AM
    khens12
    Kevin
    Definitely. When the rain stops I’ll jump under the truck and take a look / photos.
    So I know what orientation they should be - is the larger spacer to be placed on the back side of the shock mount or in the front of the shock mount? (Towards the rear of the truck)
    Rica25 likes this.
  11. Dec 11, 2019 at 6:03 PM
    Subydude007
    Subydude007 New Member
    Washington
    2017 MGM CM Platinum 4X4
    -Tint -TRD Pro shifter -2018 TRD Pro LED headlights -Morimoto fogs -Remote start -6112s plus shims in front, 5160 plush shackles in rear -Diff drop -CB drop -Icon 6speeds -BFG KM3 315/70-R17
    @khens12 how much did you have to do to the front fender liner / mud flap? This setup works without BMC as well right? I’ve got all my parts on order and doing basically the same setup in a few weeks. I understand the Icons minimize how much you have to do to the inside of the wheel well when running 315/70-17s.
  12. Dec 11, 2019 at 6:14 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Will it still rub if you slide the boot up a little?
  13. Dec 12, 2019 at 8:11 AM
    khens12
    Kevin
    I have yet to do any trimming. For general driving it does not rub unless I’m full lock at reverse. I have made it work for the time being in order to get into parking spaces in the work garage but I believe I will need to trim/re-align and last resort trim the body mount in order to provide full clearance while articulating off road.
    I removed the stock mud flaps. I honesty believe it is all in the alignment numbers which can vary as I’m sure you’ve read about on the forum.
  14. Dec 12, 2019 at 8:11 AM
    khens12
    Kevin
    Joon - what boot are you referring to? The tie rod is on the front side of the coilover, right?
    joonbug[QUOTED] likes this.
  15. Dec 12, 2019 at 8:25 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    This boot. Sometimes it’s just the thickness of the rubber boot that makes it rub. You can loosen the clip and slide the boot upward a little. If it still rubs you’re going to have to adjust with caster.
    Vizsla likes this.
  16. Dec 12, 2019 at 10:21 AM
    khens12
    Kevin
    Gotcha! I need to take a look at this. I hit up the shop that did the install and alignment originally to see if they had time to look at it but never got a response.
    Do you happen to know the correct misalignment spacer orientation I had inquired about in earlier posts?
  17. Dec 12, 2019 at 11:46 AM
    Vizsla
    Vizsla 2 = 2.5
    Are they different lengths? King directions makes no mention of a difference.
    http://www.kingshocks.com/wp-conten...5-2007-+-Toyota-Tundra-2.5-Front-Coilover.pdf
    The 3.0 directions mention spacers, bigger in front.
    http://www.kingshocks.com/wp-conten...8-2007-+-Toyota-Tundra-3.0-Front-Coilover.pdf
    TheBeast and joonbug like this.
  18. Dec 12, 2019 at 12:14 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  19. Dec 12, 2019 at 4:53 PM
    khens12
    Kevin
    its real hard to tell which orientation they are installed after getting under the truck...
    I checked the king directions and nothing.
  20. Dec 15, 2019 at 5:00 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    BabyBlackYota likes this.
  21. Dec 15, 2019 at 5:25 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    rod rub sounds like a personal problem. i'd recommend this.
    the warming aspects help tremendously. if that doesn't work, you can step it up with this one.
    have fun and report back since, you know, inquiring minds want to know...
  22. Jul 8, 2020 at 12:17 PM
    mjgonz1
    mjgonz1 New Member
    Michael
    Milwaukie Oregon
    2018 trd sport white crewmax
    Interested in trd dual exhaust
    Curious on any update with your post?
    Mine were installed two days ago and I'm getting a rub from the tie rod.
  23. Jul 13, 2020 at 5:33 PM
    I think my boot hits as well with my Toytecs. I get a loud pop at times when I'm at full lock but havent look at it yet. Could be my skid plate?
  24. Jul 13, 2020 at 5:37 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Full lock pop is usually the steering stops. Put some grease on em and see if it stops (they’re on the ball joint mount)
  25. Jul 15, 2020 at 9:42 PM
    khens12
    Kevin
    No updates here on my end. I actually sold the truck a week ago and went back to stock before selling.
    seems to be somewhat common on the tundras though....
  26. Jul 15, 2020 at 10:49 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Not to jack the thread..link for this sway bar link? @mjgonz1
  27. Jul 15, 2020 at 11:00 PM
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
    Not positive but it looks like the bds sway bar end link its on there website. Here's mine
    saybng[QUOTED] likes this.
  28. Jul 16, 2020 at 3:12 AM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    Mine rubs with aluma series. I ignore it
    mjgonz1 likes this.
  29. Jul 20, 2020 at 12:28 PM
    mjgonz1
    mjgonz1 New Member
    Michael
    Milwaukie Oregon
    Looks like your coilovers have some rub spots also, mine is going back in on friday to look at adjusting caster a little bit to help with clearance of tie rod. This was the suggestion given to me by the tech support at bds suspension this week.
  30. Jul 20, 2020 at 12:31 PM
    mjgonz1
    mjgonz1 New Member
    Michael
    Milwaukie Oregon
    These came included with the bds 4.5 inch lift kit
