Tie rod replacement and any suggestions?
Discussion in 'Suspension' started by JerseyTundra1260, Nov 4, 2017.
  1. Nov 4, 2017 at 5:32 AM
    JerseyTundra1260
    JerseyTundra1260 [OP] 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
    Yesterday had my Toytec coilovers, SPC Uca's and Toytec shackles installed. Took it to Toyota for alignment and they screwed it up. Pulls to the right and they said due to corrosion they could only adjust so much. I know the SPC Uca's help for some of the alignment. To be honest I don't think they knew what they were doing. The alignment was a lot better before I had anything done. Do you think I should just buy new tie rods and have them replaced considering I'm having issues every time they try and do an alignment? If so any recommendations which ones. I really do not want to drive the truck like this. Any help appreciated :thumbsup:
  2. Nov 4, 2017 at 5:43 AM
    WatTundra
    WatTundra New Member
    Kenny
    FTW, TX
    2016 MGM Tundra
    Stock as a rock minus tint
    I'm no help in this matter but I'm going to tackle this same install next weekend, so I'm here for the same possible issue. Off subject but do you have any before and after pics?
  3. Nov 4, 2017 at 5:45 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Acrotalus likes this.
  4. Nov 4, 2017 at 5:50 AM
    JerseyTundra1260
    Marc
    New Jersey
  5. Nov 4, 2017 at 5:57 AM
    JerseyTundra1260
    Marc
    New Jersey
    Before and after shot
  6. Nov 4, 2017 at 5:58 AM
    JerseyTundra1260
    Marc
    New Jersey
  7. Nov 4, 2017 at 6:30 AM
    Stewie
    Stewie New Member
    2016 Crew Max
    Replacing tie rod ends wont fix your problem. Take the truck to a reputable alignment shop and have them align it properly.
    Worn out tie rod ends would affect toe.
    TheBeast likes this.
  8. Nov 4, 2017 at 6:56 AM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
  9. Nov 4, 2017 at 9:59 AM
    JerseyTundra1260
    Marc
    New Jersey
    Yes I did. I just got back from another shop that was recommended from my installer. Here are my new specs compared to yesterday's. I don't know after everything has been installed after driving it there seems to be like a vibration I can feel when I first start taking off. Don't know what that could be?
  10. Nov 4, 2017 at 10:04 AM
    JerseyTundra1260
    Marc
    New Jersey
    Also noticed that my driver side front wheel sits more under my flares than my passenger side.
  11. Nov 4, 2017 at 10:26 AM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    Other than your camber still wasn't set "well" (ie, matching both sides), your other numbers are similar to mine. Its easy to nail the camber with the spc's so it may be another case of lazy work.
    My last alignment:
  12. Nov 4, 2017 at 10:43 AM
    JerseyTundra1260
    Marc
    New Jersey
    So it's the SPC Uca's not set identical I am gathering. That's why the one wheel is tucked under some. Any idea what the vibration could be? Sort of feels like my driveshaft I can't explain it. Could the new rear shackles have anything to do with this
  13. Nov 4, 2017 at 10:50 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Doesn't sound like you're in the market for new tie rod ends but, I damaged one of mine installing my C/O's. I fixed it with a Coachbuilder steering kit instead of going back to OEM.
    JerseyTundra1260[OP] likes this.
  14. Nov 4, 2017 at 10:59 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Is it a shudder on acceleration? Did you install a carrier bearing drop?
  15. Nov 4, 2017 at 11:25 AM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    Yah, I'm not sure what all you changed, but a driveshaft shudder is usually fixed with carrier bearing drop. Call coachbuilder, he has a calculator that will tell you the exact thickness you'll need to realign your drive shaft. The SPC's have infinite range of camber within the spec, so the camber setting is purely up to how much effort was put into adjusting the bug nut on top in the elongated hole. (caster is adjusted by rotating the plate on the bottom side of that elongated hole)
  16. Nov 4, 2017 at 12:51 PM
    JerseyTundra1260
    Marc
    New Jersey
    Yes and yes
  17. Sep 16, 2018 at 12:04 PM
    FA141794
    FA141794 New Member
    2014 silver 1794
    California legal K&n 34" ko2 Bora spacers bilsteins 6112 5160 hellwig sway bar wheeler bump stops go rhino rb20 gator aluminum bed cover bedrug Optima battery 27f camburg upper control arm RCI Steel skid plate powerstop kit
    831Tun likes this.
  18. Sep 16, 2018 at 12:19 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Well, they're stout. Overall I'm pleased. Alignment "techs" love to use channel locks on 'em and eff up the PC. I've had alignment shops that are unwilling to pop them off the spindle and to make proper adjustments. So, they kinda need to be close when installed. (hard to explain but threaded in or out) I'm off road frequently and they make a lot of noise when they're dirty. @InfernoPRO informed me that boots are now included to cover the heim and keep them cleaner and reduce maintenance. Because they're straight and beefy, it's possible for them to hit the spring perch but only in, what I'd call, extreme applications, ie 3.0 shocks with a lot of caster.
    InfernoPRO and FA141794[QUOTED] like this.
