Tie downs in rear seat of truck
Discussion in '2.5 Gen Tundras (2014-2021)' started by mpicasso, Apr 23, 2023.
  1. Apr 23, 2023 at 8:52 PM
    mpicasso
    mpicasso [OP] New Member
    Need to secure dog kennel in rear seat area of truck. After removing 1, or both, seats,.how do secure the kennel with supplied straps (Gunner kennel).
    In the RAM, there are secure points on the floor, close to the door, and need something similar.
    https://cdn.carbuzz.com/gallery-images/2021-ram-1500-back-seats-carbuzz-694820.jpg
    Any suggestions? Would love another Tundra but may have to go RAM as this vehicle is 30% tow the boat, 60% dog stuff, and 10% work/other (honestly have no idea if the percentages are correct but...kennel is a permanent fixture in my other vehicle).
    Thanks in advance!!!
  2. Apr 23, 2023 at 9:12 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    The RAM looks flatter across in the rear also. The Tundra has a hump in the floorboard that might make it awkward. If you plan to make the kennel a permanent fixture, the Ram may be a better choice for you. The 3rd gen is worse, I believe it has a large storage compartment under the seat.
    2nd gen:
  3. Apr 23, 2023 at 9:23 PM
    mpicasso
    Was at dealership today, looking at a '19 Pro. If I take one set of the seats out, kennel will fit well on the hump. My concern is then how to secure the kennel with said straps.
    Really hoping to NOT needing to go RAM...
  4. Apr 23, 2023 at 10:27 PM
    JimboSlice413
    Bakersfield
    When you remove the seats, there's going to be some really beefy threaded holes and bolts left over that used to hold them down. I'm not sure if they'll line up in a way you can use them but just an idea. Check out 1:43
    https://www.youtube.com/watch?v=T2QtTlChlO8
  5. Apr 24, 2023 at 10:03 AM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    I would look into using some d-ring tie down hooks and put them here. I don't think it would ruin the integrity of the seats or anything to have them down there. Use the back bolts from the front seats as another anchor point. You might have to trim that cover, or leave it off. I would use rubber coated rings so they don't rattle when not in use.
  6. Apr 24, 2023 at 11:19 AM
    mpicasso
  7. Apr 24, 2023 at 12:21 PM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
