Ticking noise when accelerating
Discussion in '1st Gen Tundras (2000-2006)' started by SDSurfing, May 24, 2020.
  1. May 24, 2020 at 8:15 PM
    SDSurfing
    SDSurfing [OP] New Member
    Silver 2006 Toyota Tundra
    Bilstein leveling kit, Toyo open country tires, ProComp 17's
    There is a ticking noise coming from underneath my 05 Tundra when accelerating. If I hit the throttle in neutral there is no ticking noise...it only starts when I reach 2000 rpms. It doesn't sound like a horrible problem its more so annoying. Anyone know what this could possibly be? I don't think it is a loose heat shield. The sound sounds like a piece of tape is stuck in a fan or something.
    leosvividlife likes this.
  2. May 25, 2020 at 1:14 PM
    Professional Hand Model
    Hand Protectors
    Get someone to rev it will you are under for inspection. Or, put a brick on the pedal and then crawl under. Make sure you are in park with the e-brake engaged. :D
  3. May 25, 2020 at 3:38 PM
    SDSurfing
    This would work except the noise only happens when the car is moving. Stationary there is no noise
  4. May 25, 2020 at 3:40 PM
    SDSurfing
    Well the timing belt, brakes and water pump all have been done within the last 500 miles.
  5. May 25, 2020 at 4:40 PM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Possible: exhaust (manifold?) leak, lifter tick, low oil level, something stuck on knuckle/brake area rubbing on wheel, rock stuck in tire, pine needles stuck in radiator (hitting fan).
    Noises are hard to diagnose over internet.
  6. May 25, 2020 at 6:07 PM
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    My wife got a stone stuck in the disk brake shield right after she got a new Honda and I thought something was messed up. Dealer figured it out right away. Made a tick tick tick noise at speed. Easy to check. Good Luck.
    SDSurfing[OP] likes this.
  7. May 25, 2020 at 6:23 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  8. May 25, 2020 at 9:18 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    bmf4069 and SDSurfing[OP] like this.
  9. May 25, 2020 at 9:28 PM
    SDSurfing
    The guy I got it off of said its the exhaust manifold and said its normal for these first gens. Hmm...What about the exhaust manifold? Like I need to replace it? I appreciate all of the responses, all possibilities. Taking her into the shop this week. Hopefully they can figure out what it is. Thanks again everyone!!!
    fighthedude likes this.
  10. May 25, 2020 at 9:35 PM
    empty_lord
    05 rollover special
    it is common to have the exhaust manifold crack. Replace is the only fix.. this is where most people just put headers on, its not the easiest job in the world
  11. May 25, 2020 at 10:16 PM
    SDSurfing
    Does anyone have any idea how much it is to get a shop to replace? Essentially how much are good headers plus install? Anyone would suggest Dealer or Auto Shop?
  12. May 25, 2020 at 10:24 PM
    empty_lord
    05 rollover special
    I believe typical labor time is 8 hrs. Plus the cost of parts. So your looking at ~1000-1100 at a dealer in labor
    SDSurfing[QUOTED][OP] likes this.
  13. May 25, 2020 at 10:43 PM
    SDSurfing
    Sheesh that sounds like a lot. Well if its cracked I would ideally like to hopefully get it welded or buy a stock manifold as a more cost efficient method if possible. Headers do sound nice though. Even though smog certified ones here in California aren't cheap
  14. May 25, 2020 at 10:47 PM
    empty_lord
    05 rollover special
    i believe headers end up being cheaper. new oem will end up cracking again eventually. others will chime in here though. welding i dont believe lasts. but then again i dont think ive seen anyone weld them
  15. May 25, 2020 at 11:40 PM
    SDSurfing
    Oh ok. Right on well I'll have news on this towards the end of the week once I bring it in for inspection. Thanks again for the help much appreciated
    empty_lord[QUOTED] likes this.
  16. May 26, 2020 at 2:21 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Whether you repair the current manifold, replace with stock, or replace with headers, the manifold has to come off and one has to go back on -- so labor will be the same.
  17. May 26, 2020 at 3:57 AM
    Hand Protectors
    Try either caulking or replacing the steering wheel bushing/donut. The sound travels through it and if its torn badly will quiet things down if replaced. Cheap fix. Assuming the tick really is headers.
    Most people report the tick at idle not at 2000 RPM.
  18. May 26, 2020 at 11:43 AM
    SDSurfing
    At idle it’s completely quiet. Even revving in neutral it’s quiet. The second I am moving it starts. So strange
  19. Jun 7, 2020 at 8:15 AM
    MaineGuide72
    MaineGuide72 New Member
    Maine
    2005 Tundra TRD double cab
    TCD 6” suspension lift, 2” body lift, ion wheels, 80s rollbar with 5 daylighters , fabricatied solid steel bull bar with front receiver and 10k winch etc...
    Before you do anything look underneath the truck where the steering wheel shaft enters the cab and see if your steering shaft seal is ripped. If it is it will make that annoying ticking sound when accelerating. It’s a 20.00 part and an hour labor. The sound is very similar to an exhaust manifold leak
    bmf4069 likes this.
  20. Mar 4, 2021 at 10:45 AM
    Dannydirtyfingers
    Dannydirtyfingers New Member
    Texas RR
    2004 Tundra AC SR5 2wd
    5100 Bilsteins 4th notch, JBA uppers
    Anything new on this issue? My 04 has something similar, haven't had time to do the normal wheel bearing, brake etc etc test... I did read about the diff losing a pin inside... Been searching for hours but nothing concrete.
  21. Mar 4, 2021 at 11:08 AM
    Dannydirtyfingers
    Texas RR
    Yeah I just saw that thread.... Guess I just have to check everything... Noticed another tundra in a parking lot had the same issue as well... Crazy because I only have 75k miles. No issues driving or going over bumps. Just when I'm in a parking lot going slow... Thanks!!
  22. Mar 4, 2021 at 11:22 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It's worth mentioning that I only heard the "tick tick tick" at real low speeds too. Once I replaced the steering shaft seal I don't hear that noise anymore.
  23. Mar 4, 2021 at 11:26 AM
    Dannydirtyfingers
    Texas RR
    Interesting, but how about when your window is rolled down?
  24. Mar 4, 2021 at 12:10 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I heard it with the window down for the first time in a long time recently. Didn't bother me nearly as much as it did before I swapped that seal.
    Jack McCarthy likes this.
  25. Mar 4, 2021 at 12:16 PM
    Dannydirtyfingers
    Texas RR
    I think I should see if I could record the noise somehow... Thanks again!
  26. Mar 26, 2021 at 11:23 AM
    BigBen
    BigBen New Member
    White 2004 SR5 Double Cab 4WD
    I’m picking up an immaculate 04 sr5 tundra with 84,000 miles on it - actually at the dealer right now about to purchase. Same issue - No whirring/ticking sound at idle or neutral, but as soon as it’s in drive moving, there’s that ticky whirry sound that increases with RPMs coming from the drivers side. Really hyped about this truck but a little worried about the sound - I haven’t driven these though so not sure if it’s normal or not.
  27. Mar 31, 2021 at 7:41 PM
    nickrick78
    nickrick78 New Member
    Nick
    Pittsburgh PA
    2004 DC
    I had the same problem, mine was the gasket for the flange between the one manifold and exhaust pipe.
  28. Mar 31, 2021 at 10:00 PM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    My 04
    Had same ticking . Exhaust manifold leak. Labor is crazy and my mechanic stated they don’t like doing them because the bolts will sometimes break and it’s a pain in the ass. Dealer literally stated the same. If it’s not causing any harm.....
  29. Mar 31, 2021 at 10:07 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Steering shaft seal got rid of my tick.
    Or... maybe it just prevents me from hearing it. Either way, that’s a win in my book.
  30. Apr 1, 2021 at 4:53 PM
    Barabajackel
    Barabajackel New Member
    Pittsburgh
    06 double cab
    If you do find out it’s a manifold take it to a muffler /exhaust shop I have had manifolds and or headers put on for a fraction of that about 150 to 200 a side plus parts and they do them daily so they usually can get them off without breaking anything
