Ticking noise on brand new 2024 tundra
Discussion in '3rd Gen Tundras (2022+)' started by Coop82Toyota, Dec 14, 2023.
  1. Feb 22, 2024 at 9:10 AM
    #61
    james_1234
    james_1234 New Member
    James
    We do. I have already been approved for a buyback, but would rather have a replacement and am pursuing that currently. I had a significant trade-in when purchasing the truck, which save a good bit on taxes. It would make more sense for me to get a replacement.
  2. Feb 22, 2024 at 1:59 PM
    #62
    dano9258
    dano9258 New Member
    2024 Limited 4x4 OR Pkg
    MX4 Cover
    That’s what mine is. So from what I’m hearing, it’s only worrisome if it’s constant?
  3. Feb 25, 2024 at 8:36 PM
    #63
    Toyota1990
    Toyota1990 New Member
    My new 2024 tundra sr is doing the same thing at 100 miles. Loud tick coming from transmission bell housing area. Loudest when in park at idle. Sounds like something internal. Truck drives fine otherwise. I'm Going to have it looked at tomorrow I hope.
  4. Feb 25, 2024 at 9:12 PM
    #64
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Thread reminds me of cracked manifolds that Nissan Titans suffered from when entering higher milage. Same exact sound.
  5. Feb 26, 2024 at 4:54 AM
    #65
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    Off subject but made me think of it. The last Titan generation coincided with organized new vehicle theft rings in my area. The only one to get caught were the Titan thieves because the engines always blew under high speed pursuit. The GM and Toyos could take one high speed chase without blowing up so thieves could at least ditch and make a run into the woods
    Nobody ever stole the Fords or Rams for what ever reason. The Ford lot has zero fencing or security.
  6. Feb 26, 2024 at 7:07 AM
    #66
    dano9258
    dano9258 New Member
    MX4 Cover
    I haven’t heard mine in park, only in drive. Let me know what they tell you.
  7. Feb 26, 2024 at 8:32 AM
    #67
    james_1234
    James
    Yeah, that is me. Good luck on the replacement. The lady I talked to told me there were no Limited trims 4x4 with my options available at all and that they could build a Limited in April, but would not be the same as the truck I have. Buyback is on the table though, not sure I am going to go through with it. I would lose some money on that deal and got such a good deal on the one I purchased. Thinking about taking them up on the extended warranty, keeping mine and seeing if they will throw in anything else. I did confirm with the dealer that it would not be a remanufactured transmission. I know we discussed that at some point.
    Tundrastruck91 likes this.
  8. Feb 27, 2024 at 1:16 PM
    #68
    Toyota1990
    I dropped my tundra off yesterday to have the transmission tick diagnosed. Technician said he had not seen it yet. Called the toyota tech line and they recommended a new transmission right from the beginning. I'm assuming they know there is a problem. Luckily they have a new trans and convertor in the warehouse and I should have my truck back within 2 days. Hopefully the new transmission fixes the noise.
    Kap1 likes this.
  9. Feb 27, 2024 at 1:20 PM
    #69
    james_1234
    James
    Your dealer had one in the warehouse? I have been waiting for a month for a transmission to arrive to my dealer. It was initially supposed to be two (2) weeks, but they have added to it yet again. Hopefully mine will be here next week. Hope they get you back up and running soon. Please check back in with us to let us know how the new transmission operates and if it fixes your issues.
  10. Feb 27, 2024 at 1:22 PM
    #70
    Toyota1990
    Yes he said there are 3 available and only 1 torque convertor. Could be a regional thing not sure, I'm located in mississippi. Where are you at?
    james_1234 likes this.
  11. Feb 27, 2024 at 1:23 PM
    #71
    james_1234
    James
    I would like to think it is a regional deal, but I am in northwestern Alabama. About an hour from Mississippi.
  12. Feb 27, 2024 at 1:37 PM
    #72
    Toyota1990
    We should should be in the same region. Hopefully they aren't just telling me they have one. I have a brand new loaner tacoma untill it's fixed, I'm sure they want to get it back as soon as possible.
  13. Feb 27, 2024 at 1:54 PM
    #73
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    So we went from the turbos to the occasional engine bearing failure which appears to have missed the 2024's and now the transmission is a problem!
    Looking forward to the Gen 4's...
    Leo's first, hagrid and james_1234 like this.
  14. Feb 27, 2024 at 3:01 PM
    #74
    dano9258
    dano9258 New Member
    MX4 Cover
    Do you have a video of the ticking? I’ve seen one where it’s a constant ticking and sounds really bad. But mine is the every 3-5 seconds there are three ticks. I think maybe there are two different kinds of ticks people are speaking about maybe?
  15. Feb 27, 2024 at 3:02 PM
    #75
    Toyota1990
    It won't let me upload but yes I have a video I can send.
  16. Feb 27, 2024 at 3:15 PM
    #76
    Toyota1990
    I'm a vibration analyst by trade so I'm pretty familiar with figuring things like this out. Also have an automotive repair shop I work in on the side. While I could be wrong I believe this problem is related to excessive clutch pack clearance inside the transmission. The noise is definitely coming from the pump end of the transmission. Its also worth noting that the noise is absent untill the truck warms up. And does not do it much under load. Only in neutral. All the tundras I have seen have this same noise at very very low amplitudes which I believe to be normal. Mine happens to be very very loud. I believe it's a QC issue with the transmission manufacturer. I doubt we well ever know the real cause. I'm glad my dealership is putting a whole new unit in. Hopefully this takes care of the issue. I will update when I get the truck back.
    CringyDad likes this.
  17. Feb 27, 2024 at 3:48 PM
    #77
    james_1234
    James
    Same exact scenario for me. Only when completely warmed up and in neutral/park. Dead silent while in drive and reverse. I tried to upload a video as well but couldn't get it to upload. Delta1Seven has uploaded a video to this forum that hits it on the head, although I believe mine was a little louder. https://www.tundras.com/posts/3496515/
  18. Feb 27, 2024 at 3:50 PM
    #78
    dano9258
    dano9258 New Member
    MX4 Cover
    Upload to YouTube and then share the link please. I’m curious if it’s what I’m hearing too
  19. Feb 27, 2024 at 4:23 PM
    #79
    Toyota1990
  20. Feb 27, 2024 at 4:54 PM
    #80
    dano9258
    dano9258 New Member
    MX4 Cover
    Thank you. It sounds like yours is constant ticking.
    Has anyone had any ticking every 3-5 seconds and then it repeats? Anyone where those have had any real issues or have been replaced?
  21. Feb 27, 2024 at 4:57 PM
    #81
    Toyota1990
    Does it appear to come from transmission? If you have an automotive stethoscope you can rule the trans out. It will be obvious.
  22. Feb 27, 2024 at 5:04 PM
    #82
    dano9258
    dano9258 New Member
    MX4 Cover
    I don't know where it's coming from. I only hear it in drive thrus when im up against walls. Whenever I get home and get underneath, I don't hear it. If I had to guess, it sounds like it's coming from the front half of the vehicle, but that's the best I can say.
    EDIT: Sounds like this: https://www.tundras.com/threads/ticking-noise-from-transmission.118719/
  23. Feb 27, 2024 at 5:24 PM
    #83
    Toyota1990
    My 22 did this for sure. Havent had the 24 long enough to tell. I believe it's part of the waste gate/turbo system doing it. It sounds different than mine but hard to tell. I know my 22 did an intermittent tick but nothing like what the 24 is doing. Look up "waste gate rattle" that's what yours sounds like. Many turbo vehicles have some degree of this.
  24. Feb 27, 2024 at 5:35 PM
    #84
    dano9258
    dano9258 New Member
    MX4 Cover
    I went out and took a video. You can hear the shift points. Video starts in drive with the tick, then to park, then to reverse, then neutral before the end. Only time the tick is hear is when the vehicle is in drive.
    https://streamable.com/xrqyji
  25. Feb 27, 2024 at 5:39 PM
    #85
    Toyota1990
    Yeah sounds to consistent to be the waste gate rattling.
  26. Feb 27, 2024 at 6:53 PM
    #86
    Kap1
    Kap1 New Member
    San Francisco, CA
    This intermittent tick in the video sounds normal. Tundra that service manager owns was doing this same thing when he was in park. Mine does this as well
  27. Feb 28, 2024 at 11:14 AM
    #87
    Toyota1990
    The new transmission and torque convertor came in this morning. Not sure why others are having to wait months.
  28. Feb 28, 2024 at 11:18 AM
    #88
    Delta1Seven
    Delta1Seven New Member
    Damien
    Is it "remanufactured" by chance? Corporate told me getting a refurbished transmission would help expedite the replacement but I demanded a new one.
  29. Feb 28, 2024 at 11:19 AM
    #89
    Toyota1990
    I asked them If it was "remanufactured" or OEM new. They said it was new. Hopefully they are telling the truth. I will make sure I see the paperwork with it.
  30. Feb 28, 2024 at 11:20 AM
    #90
    Delta1Seven
    Damien
    Good thinking. I was just curious.
