Ticking noise from transmission
Discussion in '3rd Gen Tundras (2022+)' started by Fooyotatundra, Jan 13, 2023.
  1. Feb 5, 2025 at 9:43 AM
    #91
    jfish7676
    jfish7676 New Member
    2025 Tundra Limited
    Thinking more about this tick...does anyone have any idea why it goes away in Neutral or Reverse and sounds different in Park vs. Drive? All of that points to transmission to me, but the dealer said "direct injection fuel pump" which sits on top of the transmission (hence location of the sound). Once the truck is in neutral, all you hear is the engine, which sounds totally normal. Park or drive, you get the tick sound every 3-4 second (in drive), little more consistent in park. Thoughts?
  2. Feb 6, 2025 at 5:04 PM
    #92
    sudobash
    sudobash New Member
    There was a TSB released in October of last year to reprogram the TCM on the Hybrid only for this tick. Supposedly it may resolve the tick for some time, but it has some back for some owners. There is a new Tech Tip out today that is worded in a way to make it seem like the TSB will ultimately not resolve the issue.
  3. Feb 6, 2025 at 5:53 PM
    #93
    jfish7676
    2025 Tundra Limited
    Thanks, I told my advisor about the TSB but he said it doesn’t apply to mine. I don’t have the hybrid. After looking into it more, I’ve noticed that:
    • Park - The tick is more pronounced and frequent.
    • Reverse - Nothing
    • Drive - 4-6 ticks with 2-3 second pauses
    • Neutral - Very faint tick similar to Park but lighter
    Also noticed that in park, the tick goes away when you rev the engine but does return once RPMs settle. Advisor said “Normal operation with direct injection…”
    I’m still confused.
  4. Apr 16, 2025 at 7:58 AM
    #94
    24LTD
    24LTD New Member
    Any updates on this? I have the same ticking noise on my 24'
  5. Apr 16, 2025 at 8:19 AM
    #95
    dano9258
    dano9258 New Member
    2024 Limited 4x4 OR Pkg
    MX4 Cover
    I’ve had this tick every 3-5 seconds while in drive sitting in drive thrus. Have had it since day 1.
  6. Apr 16, 2025 at 8:44 AM
    #96
    Gonefishingdave
    Gonefishingdave New Member
    Dave
    Central New York
    2024 MGM Tundra TRD OR Limited
    Bakflip cover, AVS vent visors
    Things like this make me glad my hearing is shot due to too much gun play as a youngster.
    Also fireworks.
    My easy fix: turn the radio up
    MikroT likes this.
  7. Jun 5, 2025 at 5:58 PM
    #97
    ehh1234
    ehh1234 New Member
    25’ Tundra TRD Platinum& Pro Sequoia
    Just chiming in, I have a 25’ TRD Platinum which also has this ticking, had it since ~40ish miles, also had a 24’Plat hybrid.. same issue, at the time I thought it was just something with the hybrid system, apparently not because my nonhybrid does it as well. Concerning because I do feel an aggressive shift from time to time from park to drive. My 25’ Sequoia Pro is doing the same.. will bring this up on service on 12tb
  8. Aug 7, 2025 at 9:49 PM
    #98
    Richo
    Richo New Member
    Rich
    2025 Tundra SR5 Rally
    none
    what did you find out?
