Ticking noise from transmission
Discussion in '3rd Gen Tundras (2022+)' started by Fooyotatundra, Jan 13, 2023.
  1. Feb 16, 2023 at 5:58 PM
    Fooyotatundra
    Fooyotatundra [OP] New Member
    2022 sr5 trd 4x4
    Exactly what kap1 said, there’s no definite answer to if it’s an issue, it’s more so a piece of mind kind of thing. I think for the ones that did have the transmission replaced, toyota corp told the dealers directly to take that action so they can get the old transmission back and do further investigation, as well as to not have a bad reputation since it’s a brand new truck/model.
    Rcflyersd and Kap1[QUOTED] like this.
  2. Mar 12, 2023 at 12:10 PM
    papag1272
    papag1272 New Member
    Geo
    2014 Tundra Crewmax SR5
    I'm in the process of buying a new 23 Tundra SR5 Crewmax. At the dealership, Koons in Annapolis, MD a few trucks on the lot had that ticking / clicking when I test drove them. So they replaced all the transmissions. Heading back tomorrow for another test drive and hopefully take one off their hands. I'm told they still have their warranty.
  3. Mar 12, 2023 at 12:21 PM
    papag1272
    Geo
    TRANS or Differential?????????
    I was at KOONS Toyota in Annapolis, MD and a couple of the SR5,s had that same clicking. Since then they told me they have replaced a few transmissions & differentials. I'm headed back tomorrow to hopefully purchase one. Will definitely test drive it before hand.
  4. Mar 12, 2023 at 12:26 PM
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    They can keep replacing them, it’ll still be there. It’s on every hybrid I’ve ever driven.
    can’t say on non hybrid
    e46_ema and (deleted member) like this.
  5. Mar 12, 2023 at 3:58 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Let us know if you find one without the clicking noise please. Seems like it's normal operation... Based on the info we have at the moment
  6. Mar 13, 2023 at 6:58 PM
    t300
    t300 New Member
    Manitoba
    22tundra
    My mid May build 2022 has been ticking since day1. Most noticeable when window open at a drive through. Hasn’t gotten worse so just ignoring it and assume it’s normal. Till it’s not.
  7. Apr 24, 2023 at 7:44 PM
    Cravens2019
    Cravens2019 New Member
    2022 Tundra SR5
    Have the same problem here with my 22. Notice it more on hot day or after long drive. Definitely noticeable in drive thru.
  8. Apr 26, 2023 at 2:13 PM
    22tundradude
    22tundradude New Member
    22 Tundra TRD Off Road
    Having mine replaced as we speak. Started with ticking sound and progressed to gear slipping from 1st to 2nd. Keep an eye out for noticeable hesitation/clunking when shifting.
    DMC11 and Mattedfred like this.
  9. Apr 29, 2023 at 11:06 AM
    green_plaid
    green_plaid New Member
    2023 SR with less than 200 miles and less than a week old started making the same exact noise. Was fine the day I drove it off the lot. Kinda makes me sad ...
  10. May 23, 2023 at 9:47 AM
    irwinj06
    irwinj06 New Member
    Any updates on the problem and solution?
  11. May 24, 2023 at 7:50 AM
    DMC11
    DMC11 New Member
    22 Tundra LR Limited OR
    What made the dealership decide to replace it? Were they able to replicate? Mine has been having similar symptoms. I brought it up at 15k service, they did the TSB for hesitation/start up clunk. Now due for 20k service, and I’ve noticed some harsh shifts/with clunking noise that I’ve never noticed before.
  12. Jun 20, 2023 at 11:06 AM
    Alexcanada1234
    Alexcanada1234 New Member
    Hi there, I took my 2022 Capstone in and they found metal shavings in the transmission- replaced transmission and any component that the transmission fluid touched. With the new transmission installed the ticking is still prevalent. I also have a slight burning smell after about 40 mins of runtime. Truck has 20,000 Km on it. Toyota stated that this noise is normal function for the transmission.
    e46_ema likes this.
  13. Jul 28, 2023 at 9:52 AM
    TNtundra22
    TNtundra22 New Member
    Is there any consensus as to whether this is normal or sign of transmission issue? Seems like I have seen both takes. I have the same exact noise from the video in first post. Has been like that since day 1, 15,000 miles on July 22 build.
    e46_ema likes this.
  14. Jul 28, 2023 at 11:06 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Nobody knows. So far we don't have reports of anyone's transmission actually failing, many trucks on this forum make this noise and still drive without any issues
    e46_ema likes this.
  15. Jul 30, 2023 at 7:02 PM
    tundraKitKAt
    tundraKitKAt New Member
    2023 tundra sr5
    I Found out today my Ticking definitely came in from the transmission, it's interesting someone commented on the metal shavings, because that's what I presumed in my head after I started to ponder what thise noise could be or a loose valve
  16. Aug 8, 2023 at 5:37 PM
    AlfredManitoba
    AlfredManitoba New Member
    Same with mine, right now my transmission shifting not that smooth especially from 1st to 2nd gear, and I also have the ticking noise issue. The dealer will change my transmission after 4weeks because I am in Damn Canada and need to wait the delivery… so when you changed the transmission, could you feel the junk shifting from 1st 2nd gear again? And could you hear the ticking noise again? Thanks!
  17. Aug 14, 2023 at 7:52 AM
    tundraKitKAt
    2023 tundra sr5
    I heard from the grape vines that there is an actual investigation on the transmission at this present time with engineers, they may recall it.
  18. Aug 14, 2023 at 1:22 PM
    Breathing Borla
    AZ
    sisters, bothers , cousins, uncle told you type deal?
  19. Aug 14, 2023 at 1:39 PM
    #49
    tundraKitKAt
    2023 tundra sr5
    Dealer I'm close to them
  20. Aug 14, 2023 at 2:11 PM
    #50
    DaxM
    DaxM New Member
    Temple, TX
    2023 Wind Chill Pearl Capstone
    How about an investigation into those main bearings melting?
    Kap1 likes this.
  21. Sep 27, 2023 at 9:22 AM
    #51
    ToyotaAl
    ToyotaAl New Member
    Has anyone noticed a clicking/ticking noise coming from outside the truck, driver side when driving mild speeds 30-45 mph when the window is down? I just started hearing this the other day and thought it may have just been the truck warming up but it has been doing it constantly at around those speeds.
  22. Sep 27, 2023 at 9:29 AM
    #52
    brutalitybob
    brutalitybob New Member
    toyotas are known for there ability to tick
  23. Sep 27, 2023 at 9:33 AM
    #53
    ToyotaAl
    ToyotaAl New Member
    have you noticed this on a new gen 3. It’s almost like the sound of a rock being stuck in the tire or like a baseball card in a bike spoke.
  24. Sep 27, 2023 at 9:47 AM
    #54
    brutalitybob
    I have, its a pretty distinct signature sound coming from the rocker arms. Similar sound to my gen 2 tacoma.
  25. Sep 27, 2023 at 10:59 AM
    #55
    ToyotaAl
    ToyotaAl New Member
    interesting. This is the first time I’ve heard it, although I don’t get to drive with the window down that often where I live. it’s a fairly faint ticking noise. It gets somewhat drowned out with traffic and wind noise but detectable at moderate speeds. It’s different from the ticking noise that others here are experiencing when stepping on the brake during a drive thru.
  26. Sep 27, 2023 at 11:19 AM
    #56
    RallySauce
    RallySauce New Member
    Middle TN
    ‘23 MGM SR // ‘20 T4R ORP
    I have this noise as well. Only noticeable when a wall is there to reflect the noise back really. Happens in park and in drive for me but if you give it some rpm (900-1k or so) itll go away. To me it sounded like direct injection, but the noise in the OPs vid is exactly what i hear. Seems we havent come to conclusion if this is normal or not lol besides the noise my trans is fine, 2023 SR with 3k miles fwiw.
    e46_ema likes this.
  27. Sep 27, 2023 at 11:27 AM
    #57
    ToyotaAl
    ToyotaAl New Member
  28. Sep 30, 2023 at 7:43 PM
    #58
    NHKTundra
    NHKTundra New Member
    2022 Tundra TRD Pro Lunar Rock
    Retrax. Uptop AFS bed rack. Condor XL. Dobinson rear springs. BFG 35/12.5/r18. BD light bar and ditch lights. Prinsu roof rack. Diode dynamics fog upgrade.
    I’ve noticed this pretty early on with our 22 TRD PRO, initial cadence of sounds of irregularly regular, but it sounds more regular and nonstop now. Like others have mentioned only in drive through against a wall is it noticeable.
  29. Dec 31, 2023 at 11:16 AM
    #59
    huntdacntry
    huntdacntry New Member
    Stephen
    24 trd sport 4x4
    Ready lift sst “ kit. Trd pro grill swap.
    I have 24 tundra and mine is doing the same thing with transmission. Mine is at the Toyota place now. They are deciding if they are going to change the transmission.
    e46_ema likes this.
  30. Jan 6, 2024 at 9:47 PM
    #60
    Adam10532
    Adam10532 New Member
    2024 1794 trd package
    Limo tint
    I have the same problem on non hybrid
