Throttle dropping out
Discussion in '1st Gen Tundras (2000-2006)' started by unclejim, Oct 7, 2020.
  1. Oct 7, 2020 at 1:57 PM
    unclejim
    unclejim [OP] New Member
    James Moulton
    2006 toyota tundra double cab 4WD
    Hey friends,
    I have a 2006 SR5 4WD Tundra with about 147k on it. Lately when I hit the gas to get in the passing lane or start up a hill the throttle will cut out on me. This is independent of the position of the pedal (which stays the same) Any thoughts on the matter would be much appreciated. Thanks
    YardBird likes this.
  2. Oct 7, 2020 at 2:40 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Fuel filter
  3. Oct 7, 2020 at 2:42 PM
    shifty` We call it “riding the gravy train”
    Pretty sure the fuel filter is integrated with the fuel pump on the '05-'06, maybe other years I'm missing.
    2006Tundra and FrenchToasty like this.
  4. Oct 7, 2020 at 4:32 PM
    unclejim
    James Moulton
    @artsr2002 I think that's correct. I had heard the fuel filter can be the culprit so i went to pick one up at Autozone and they said that's not a serviceable part. Any other ideas there?
  5. Oct 7, 2020 at 5:49 PM
    Professional Hand Model
    Hand Protectors
    Throttle Position Sensor?
  6. Oct 7, 2020 at 8:17 PM
    artsr2002
    'Yonder
    Fuel regulator?
  7. Oct 7, 2020 at 8:37 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Possibly a bad coil?
  8. Oct 7, 2020 at 9:44 PM
    artsr2002
    'Yonder
    I forget the filter is part of the fuel pump system in the tank on 05-06 models. My bad.
  9. Oct 7, 2020 at 10:00 PM
    DjScoop
    DjScoop New Member
    2013 Red Rock Warrior/Limited double cab
    Try cleaning the throttle first.
  10. Oct 7, 2020 at 10:42 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    check for codes. might be going into failsafe mode (common on failing air pumps). clean throttle. live data on a scanner will show if the pedal sensor has a dead spot..
  11. Oct 8, 2020 at 1:45 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Welcome!
    Your description is pretty vague. I presume by "cuts out" you mean stumbles and/or misfires, is that correct? Can you describe in more detail what happens? When you initially press the throttle, does the engine react normally, then stumble? Or does it happen as soon as you get on the throttle? If you continue to keep the pedal pressed, does it build RPMs slowly, or continue in this state?
    bmf4069 likes this.
  12. Oct 8, 2020 at 1:54 AM
    artsr2002
    'Yonder
    I had a camaro in the past that ran ok until i gave it the beans to pass then it would stumble on its ass. That one turned out to have a clogged catalytic converter. Replaced and all was good.
    Had a firebird that had similar issues, turned out to be plugs. Replaced and all was good. There could be a number of items that could cause stumbling, hesitation, or general falling on its ass-ness.
  13. Oct 8, 2020 at 3:32 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Clean the MAF and Throttle body, then test.
  14. Oct 8, 2020 at 6:32 AM
    Snaz
    Snaz I <3 explosions
    SE CO
    '20 Limited Quicksand
    I had Pontiac years ago that would do this about every 30k miles. Cleaned the MAF and it would run like new again.
    Rex Kramer[QUOTED] likes this.
