Throttle body sensor problems
Discussion in '1st Gen Tundras (2000-2006)' started by rickybobby6969, Jan 23, 2020.
  1. Jan 23, 2020 at 2:20 PM
    rickybobby6969
    rickybobby6969 [OP] New Member
    2003 tundra extended cab 5 speed
    My truck recently lost the gas pedal while driving I pulled over got it towed did a little research discovered that it may be my throttle body position sensor I went to Napa got the part that their computer said. I started digging in to it stripped one of the bolts which has led to a full day of work I had to take the hole throttle body of and pound a screwdriver into the stripped bolt. I have the part of this leads to the fun part I notice the part o have took off of my truck is a 4 prong the one I was sold was a 3 prong. I have brought back the part and me and the manager tried getting the correct part. I have been informed that the part is not in existence and never was as he was holding it. Amazon had one for the 1990-95 4 runner I belive it is the same. Has a anyone taken off the part and replaced it my truck is a 2003 Toyota Tundra v6(3.4) manual
  2. Jan 23, 2020 at 2:51 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Mind explaining that a little more, as in you pushed on gas pedal and nothing appeared to happen ??
    Don't know if it will help but can you post a pic of your sensor ?
  3. Jan 23, 2020 at 4:32 PM
    rickybobby6969
    I’ll attach a pic of the sensor in the morning and I was driving about to go into 4th gear next thing I knew my foot was at the floor it was like my truck was off. I pulled over and I couldn’t do anything but stay in first gear around 2k rpms
  4. Jan 24, 2020 at 4:02 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Should of tested the sensor first with an ohm meter, because you sure it's not the gas pedal sensor. Just a thought.
    bmf4069 likes this.
  5. Jan 24, 2020 at 5:13 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    True, if technically capable or at least observe visually and audibly what happens with engine on and manually rotating throttle linkage ?
    bmf4069 likes this.
  6. Jan 24, 2020 at 10:57 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    If your tps is bad it'll cause a bad idle and won't accelerate at all.
  7. Jan 25, 2020 at 1:39 PM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    I'm not sure of the make up of this particular TPS, but most have 3 circuits in it. Idle circuit, mid-range sweep, and the wide open throttle circuit.
  8. Jan 25, 2020 at 3:49 PM
    rickybobby6969
    Sorry about no pic of the sensor I have installed the new sensor and had a crazy high idle still around 2k I adjusted the throttle body and now it is back to 800-900 area my gas pedal has a lot of play still but the sensor fixed the gas pedal not working
  9. Jan 26, 2020 at 2:52 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    No Vacuum leaks?
  10. Jan 28, 2020 at 11:47 AM
    rickybobby6969
    No as of right now I have to give it gas to get it to cold start
