Throttle body cleaning how to question
Discussion in 'Performance and Tuning' started by Naut18, May 26, 2022.
  1. May 26, 2022 at 6:12 AM
    Naut18
    Naut18 [OP] New Member
    2016 Tundra TSS
    Good day all!
    2016 Tundra with the 5.7 flex. The truck runs great but has a rough idle at times. I suspect the throttle body could use a cleaning but am seeing conflicting information on how to go about it. I see where it's recommended to NOT push the throttle plate open by hand as it will require the computer to be reset. Other "how to's" do not mention this at all. Is there a difference in approach if the TB is removed or not?
    Any guidance is greatly appreciated.
  2. May 26, 2022 at 6:51 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I always thought that throttle body cleaning was something that is rarely needed, but dealerships love to charge people for it.
    Have you thrown a bottle of fuel system treatment in the tank? I recommend Berrymans B12 Chemtool
  3. May 26, 2022 at 7:58 AM
    Naut18
    2016 Tundra TSS
    Yeah....Ran a couple of bottles of BG 44k through it with little to no change.
    Looking in the TB, I can see some goo and grime that needs to be cleaned out.
  4. May 26, 2022 at 11:21 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  5. May 26, 2022 at 11:31 AM
    Naut18
    2016 Tundra TSS
  6. May 26, 2022 at 11:49 AM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Easily done.
    I’ve taken mine off twice for cleaning and other work, including a little porting (lightly) and polishing the first time.
    Here and here are some of the write ups.
    Simply put, just disconnect the battery, unplug the connector, then unbolt it.
    While it’s apart, you can trim out the screen and do the throttle body bypass (see my first link above).
    WVI and RobertD like this.
  7. Jun 8, 2022 at 7:10 AM
    Naut18
    2016 Tundra TSS
    I guess I'm missing the part about the throttle body bypass. I cleaned the throttle body, polished it up quite a bit and I'm shocked with the improvement.
    HulkSmurf14 and frichco228 like this.
  8. Jun 8, 2022 at 11:32 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    here you go.
  9. Jun 9, 2022 at 4:27 AM
    737fixer
    737fixer New Member
    You absolutely can push open the throttle plate. What is recommended is to do it slowly. The issue is the motor. Just clean it with a normal throttle body cleaner and take it easy when letting the plate open and close.
  10. Jan 25, 2023 at 3:38 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    @Rockslide read this thread and quoted post above. FYI - This is the tuning and performance sub forum.
    Taco-Spike likes this.
