Thoughts on aftermarket tpms ? Or stick with dealership
Discussion in 'Wheels & Tires' started by Baine, Dec 27, 2020.
  1. Dec 27, 2020 at 10:41 AM
    Baine
    Baine [OP] New Member
    2014 tundra crewmax
    3 inch lift with 33s an true duel exhaust 40 series flow master
    So i was told by the tire shop i just had my tires installed at ,that i will need tpms sensor soon ,but he didn't know i used to be a mechanic, an i know there is pretty much only one way to know your sensors are bad ,is when one goes out ,typical life of them are from 5 to 10 years , they just have ,a watch battery pretty much , but my question is there are alot of good aftermarket parts out ,but are tpms sensors are one of those parts you just stick with at the dealership? Or is there good aftermarket ones ? Oh an ive heard there are different ones ,like for different types of rims is this true ?
  2. Dec 27, 2020 at 12:47 PM
    There are different types. Steel wheels for example use a different sensor than alloy wheels. I would just get OEM sensors. I ordered some for my 2020 and they were about $62.00 each.
    ElNopal and Baine[QUOTED][OP] like this.
  3. Dec 27, 2020 at 12:50 PM
    Baine
    2014 tundra crewmax
    Thanks ,ill do that
  4. Dec 27, 2020 at 2:43 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    I put aftermarket Autel sensors on my Alloy wheels when I upgraded from my steelies. They work great no issues.
    Baine[OP] likes this.
  5. Dec 27, 2020 at 2:56 PM
    Baine
    2014 tundra crewmax
    Thanks ill look those up
  6. Dec 27, 2020 at 3:10 PM
    glowblue
    VA
    Baine[QUOTED][OP] likes this.
  7. Dec 27, 2020 at 3:16 PM
    Baine
    2014 tundra crewmax
    Sweet thanks
  8. Dec 27, 2020 at 4:51 PM
    timsp8
    NY
    There was a guy on here who had issues with his tpms after getting new tires. If I remember right, it turned out the shop broke one and put an aftermarket one in it’s place. He couldn’t get it to sync. He had to go back and get them to put an oem one in. I think he had a 2020.
  9. Dec 27, 2020 at 5:10 PM
    Baine
    2014 tundra crewmax
    Ya i just had new tires put on ,was checking them out an noticed a rubber valve stem, they had messed up mine an replaced it with rubber one ,when i called them ,they just said it was bad an they replaced it ,but i don't have a light on ,but now im nervous i will soon ,because of this .
  10. Dec 27, 2020 at 5:24 PM
    glowblue
    VA
    Not sure about that dudes experience but don’t think you HAVE to use OEM sensors. I have aftermarket sensors on my 2019 and they work perfectly! I’ve read something changed with the 2020 model year but in my case the aftermarket sensors worked just fine.
  11. Dec 27, 2020 at 5:30 PM
    Baine
    2014 tundra crewmax
    Ive got 2014 so im sure aftermarket will work to ,i feel more confident buying them now ,after hearing others having good experience with them ,someone earlier gave me a good brand they used an they do have great reviews
    glowblue likes this.
  12. Dec 27, 2020 at 5:32 PM
    Baine
    2014 tundra crewmax
    My only thing is ,those autel have to be programed, I'll have to find if dealership can do them ,or someone who can .
  13. Dec 27, 2020 at 5:48 PM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
  14. Dec 27, 2020 at 5:52 PM
    glowblue
    VA
    Baine[QUOTED][OP] and Haggis777 like this.
  15. Dec 28, 2020 at 1:51 PM
    jaymannj
    jaymannj New Member
    2021 Tundra Platinum
    The Toyota tpms (specifically the active tpms) is kinda finicky, in my experience, when replacing with aftermarket (I.E dill 7002 and 7003... depending on model/year of vehicle) to get it to work correctly you would need to replace all 4 sensors.... otherwise the tire installer will be able to get the MIL off but probably will not read the active pressures in the dash!
  16. Dec 28, 2020 at 1:58 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I am looking for a whole set to go into rims I just got and there seem to be $30 sensors that will fit both Steel and Alloy wheels too and from reliable makers to boot!
    https://www.tpms.com/Toyota-Tundra-Huf-IntelliSens-TPMS-Sensor-p/h0072-toyota-tundra.htm
    And there are even cheaper ones on Amazon that claim to be preprogrammed?
    https://www.amazon.com/Replacement-...31-6----8-1---&vehicleName=2015+Toyota+Tundra
    I really dont know what to think?
  17. Dec 28, 2020 at 2:02 PM
    jaymannj
    jaymannj New Member
    Personally based upon my experience as a tire guy, the 7002A from dill is the way to go!
    https://www.tpms.com/7002A-Dill-Redi-Sensor-p/7002a.htm
    Any of these will have to be programmed to the vehicle, the easiest is just stop at ur local Costco and let them just unlock and scan them... Bartech scan tool is an awesome piece of equipment, and you can skip the whole deflate, re-inflate headache :)
  18. Dec 28, 2020 at 3:37 PM
    Baine
    2014 tundra crewmax
    All the support is awesome thanks everyone
    ezdog likes this.
  19. Dec 28, 2020 at 3:40 PM
    Yes the 2020 is different and needs OEM sensors. I have mine and waiting to finish running my tires down.
    BravoDeltaRomeo and Baine[OP] like this.
  20. Dec 28, 2020 at 3:53 PM
    Baine
    2014 tundra crewmax
    Ya im sure they started doing only oem because they want the money an work ,i usually only buy from the dealership, but was hearing from tire shop they go up to 150 each then i was like maybe ill check a good aftermarket set
  21. Dec 31, 2020 at 12:03 PM
    mcm0455
    mcm0455 New Member
    2020 Tundra Platinum
    I have a 20 Tundra Platinum and used aftermarket sensors from TireRack.com. I had to buy a TMPS programmer but now if I decided to change my wheels, it is pretty simple to program the TMPS sensors.
  22. Dec 31, 2020 at 12:24 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    Have them clone the original sensor IDs. That way you don't need to reprogram the truck ECU as well. I have used autel in all 4 of my vehicles, zero issues in over 6 years.
    Leo's first likes this.
  23. Jan 3, 2021 at 9:35 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Did you have to or can a tire shop do this on the cheap?
  24. Jan 3, 2021 at 10:36 AM
    mcm0455
    mcm0455 New Member
