Thoughts about Diode Dynamics Stealth LED Bumper Light Kit?
Discussion in '3rd Gen Tundras (2022+)' started by MrKABC, Nov 22, 2023.
  1. Jul 7, 2024 at 1:56 PM
    PATundra13
    PATundra13 New Member
    Pittsburgh, PA
    2024 Tundra 1794 I-Force Max, Smoked Mesquite
    RC running boards and RC hard tonneau cover, TRD air filters, Mace MFG knobs, Beat Sonic amp, TVD decals, front windows tinted.
    Thank you!
  2. Nov 22, 2024 at 2:38 PM
    Brit84
    Brit84 New Member
    Sorry for reviving this but does anyone have wiring plan for this so that it turns on/off with the hi beams. (24 limited)
  3. Nov 22, 2024 at 2:47 PM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
  4. Nov 22, 2024 at 3:04 PM
    Brit84
    Brit84 New Member
    Those are the premium headlights, which I do not have. The same module needed on the base headlights too?
    Thanks
  5. Nov 22, 2024 at 3:10 PM
    Ipaddick
    Ipaddick New Member
    Canada
    I assume it’s still canbus. But not sure honestly.
  6. Nov 22, 2024 at 6:31 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    You might be able to tap into the wiring as the standard light are much simpler than the premium ones. All you need is a trigger wire connection so it might be easy to do it that way.
    I had my DD lightbar wired to a switch on the left hand panel. I did it that way as I wanted to turn on the lightbar with just the running lights or DD fogs. I had more options with the separate switch.
