This sound normal ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by mv133, Dec 13, 2021.
  1. Dec 13, 2021 at 10:02 PM
    mv133
    mv133 [OP] New Member
    21 tundra SR5
    Brandy new
  2. Dec 13, 2021 at 10:15 PM
    mv133
    21 tundra SR5
    Brandy new
    That’s a 30 degrees cold start .. does mellow down after my drive home once i park it’s a little quieter
  3. Dec 14, 2021 at 3:07 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Oil?? I do not know what the cold weather oil you should run though? All the new ones run 0/20,, (I think) without going and looking?
  4. Dec 14, 2021 at 11:32 AM
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder +3, bilstein 8112 front and 8100 double bypass rear, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
    sounds normal to me:thumbsup:
  5. Dec 14, 2021 at 11:34 AM
    mv133
    21 tundra SR5
    Brandy new
    Thanks guys .. i just wanted someone with a tundra to compare didn’t want to be the creepy guy in the parking lot trying to listen to someone else’s truck haha and forgive me if i sound paranoid it’s my first brand new truck
  6. Dec 14, 2021 at 2:10 PM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    Sounds like a normal cold start to me
  7. Dec 14, 2021 at 5:15 PM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    Sounds just like my 2018.
  8. Dec 14, 2021 at 8:41 PM
    Hamster14
    Hamster14 New Member
    Utah
    2014 Tundra Limited
    -46 gallon tank - shell
    5w-30 will make it quieter overall but normal
  9. Dec 15, 2021 at 6:21 AM
    mv133
    21 tundra SR5
    Brandy new
    I can’t find a solid answer if it’s ok to run 5-30 it seems like a pretty huge debate.
  10. Dec 15, 2021 at 7:23 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    My 15 did that when really cold, I wasn’t concerned.
    My 17 doesn’t
  11. Dec 15, 2021 at 8:21 AM
    pursuit2550
    pursuit2550 New Member
    Nothing to debate. To this day the 5.7 in other parts of the world use 5w-30. 0w-20 is being used to satisfy CAFE/EPA standards. I switched. No more noise, except for the idle tick, but no more sounding like a diesel. And I have more oil pressure.
    Hamster14 likes this.
  12. Dec 15, 2021 at 9:04 AM
    mv133
    21 tundra SR5
    Brandy new
    oh wow get out, i might switch over at 20k .. and i guess some trucks are just louder then others they seem to vary for sure
  13. Dec 15, 2021 at 10:02 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    There's a handful of threads about knocking sounds on these engines.
    I used to have this exact sound. Knocking coming from driver side only on a cold start - and after it warmed up it went away.
    Here's the thread I chimed in on a little while ago (post 46 and the fix in post 49):
    https://www.tundras.com/threads/201...engine-compartment-after-startup.56919/page-2
    It was covered under warranty. After Toyota having it for a couple weeks or so, final diagnosis was the valves weren't getting oil like they should to top of engine. They replaced both heads & other stuff leading up to that. It's been fine since they fixed it.
  14. Dec 15, 2021 at 10:26 AM
    mv133
    21 tundra SR5
    Brandy new
    Might sound crazy but my knock sounds separate from the motor. Almost in the trans area. I hear the valves
    Uhhhh.... likes this.
  15. Dec 15, 2021 at 1:50 PM
    pursuit2550
    This is my 4th 5.7, 08-10-14-20. They all had the same tick noise at idle and just a slight rpm raise, it would go away. Now with the 20, since it came from the factory with 0w-20 it had the same tick but also a diesel sound to it. You could really hear it when you went through a drive-thru. I quit going to the dealer for the free oil changes and tire rotations because I was switching over to 5w-30, plus I didn’t care to leave the oil in there for 10k and those idiots would torque the wheels with a impact gun. Anyways as soon as I switched over the diesel sound went away and only had the normal tick, plus higher oil pressure. I don’t want to say for sure but I also think they didn’t change my filter. Waiting to change the oil out again to compare to the last dealer oil change. It just looked too black and weird for a filter that only had around 6k on it. But I will see.
  16. Dec 15, 2021 at 2:03 PM
    Uhhhh....
    Dave
    7” BDS, 37s
    Just because the tick is very common with this engine, doesn't mean it's normal and nothing is wrong. New engines shouldn't tick.
  17. Dec 15, 2021 at 6:40 PM
    pursuit2550
    I have had 4 tundra’s , my dad also has one. From what I have gathered it’s the VVT. A lot of vehicles has some sort of ticking noise which is normal. Could be injector tick, cam phasers, valve train, etc. On all my tundras as soon as you give it the slightest amount of gas in park it goes away. Could be because the VVT is now pressuring, I don’t know. I will say that the 0-20 make the engine sound like a diesel leading me to believe that there is less of a cushion of oil with in the parts, if that makes sense. Either way Toyota did switch to 0w-20 in the US for CAFE/EPA standards. Lexus has the UX that uses 0w-16 so we can expect to start seeing that oil soon in all vehicles.
  18. Dec 15, 2021 at 7:09 PM
    mv133
    21 tundra SR5
    Brandy new
    so do your tundras sound like mine on a cold idle? Slightly goes away once at operation temperature but you can still hear it. Also did you ever run 5-30?
  19. Dec 15, 2021 at 7:09 PM
    Uhhhh....
    Dave
    7” BDS, 37s
    I hear ya that it’s common. Mine did the same thing - slightest amount of gas when parked & it went away.
    My dealership thought it was enough of a problem to get approval for a $12k warranty repair though. Crazy I know. I don’t know if you saw my post in the other thread (I linked it in this thread) but they replaced quite a bit before finally replacing both heads. No tick at all anymore.
    I’m not saying the tick is a huge issue. Frankly, I don’t know. Will it hurt to leave it? By accounts of a lot of the guys here, no, it won’t hurt. But I do still hesitate to say it’s normal, when they went to such great lengths to fix mine, and were able to resolve it. (Who knows - maybe they just wanted to be able to bill Toyota corporate for the big repair. …but the repair was approved.) Their diagnosis (oil wasn’t getting to the top of the lifters) doesn’t sound good. I admittedly know hardly anything about this stuff though - only my one personal experience with it.
  20. Dec 16, 2021 at 3:21 AM
    pursuit2550
    Yes. It sounds more like a knock that a tick. When it was new it had a knock and tick. It sounded like no other 5.7 I have had. I switched to 5w-30 and the tick is gone. Still have the knock but less pronounced. I will post a video or 2.
  21. Dec 16, 2021 at 3:54 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    My 1997 T100, 3.4L V6, sounds that way on start up. And has sounded that way on start up since......1997.
  22. Dec 16, 2021 at 4:01 AM
    pursuit2550
    LS3 likes this.
  23. Dec 16, 2021 at 4:20 AM
    pursuit2550
    The OP that started that thread definitely had a problem. From what you wrote of what the dealer did, to what they said “the valves weren't getting oil like they should to top of engine” sounds more like oil pressure issue or blockage in the oil passage at the head. I don’t know all the in’s and out’s of the 5.7 but do know about engines. A lifter that is collapsed or that will not fully pressurized will will sound like the video in that other thread. Now what they did to your truck was replace the chain tensioner which if not pressurized will cause slack in the chain and make noise. That has been one of the noise issues with this engine. Also the VVT solenoids not properly working will cause noise. Damn engines now a days are too complicated.
    So now you don’t have any sounds at cool start or after it’s warmed up?
  24. Dec 16, 2021 at 7:14 AM
    Uhhhh....
    Dave
    7” BDS, 37s
    "The OP that started that thread definitely had a problem."
    You know, it's been ~couple years since mine was fixed... I listened again to OP video in the other thread, and from what I remember, mine did sound much more like that rather than the video in this thread. So...sorry if I caused any concern with what I was saying. Thinking about it more, I remember remote starting my truck, and walking out to it in the parking lot at work, being able to clearly hear that thing rattling from ..I dunno...100 yards away? Far. That thing made a racket.
    They replaced:
    - all lifters and cam gears on driver's side
    - both timing chain tensioners
    - cam shaft pully assembly
    - valve adjusters
    - cylinder head gaskets
    - valve arm sub assembly
    It was still making the noise after all that. They then replaced the head on driver's side. The noise then stopped on the driver side, but they then noticed the noise on the passenger side (possibly was always there on passenger side, but not as bad and being drowned out by louder driver side?). They replaced passenger side head and noise completely gone.
    Right - I have no noise at all now on cold start, or after it's warmed up. No ticking/knocking noise *as heard in video in the other thread*.
    I'm bowing out of this thread after re-watching the video in the other one and realizing what I experienced was far worse than what OP posted in his videos. For my own curiosity, I'm gonna listen to mine at startup tomorrow or Sat to hear if it sounds like the vids in this thread. Cheers, guys. Be blessed. :thumbsup:
  25. Dec 16, 2021 at 8:35 AM
    mv133
    21 tundra SR5
    Brandy new
    OP? Sorry I’m not to big On forums … so do you think there’s a problem with mine ? Haha
  26. Dec 16, 2021 at 9:28 AM
    pursuit2550
    OP=Original Poster. I was talking about the other thread where the OP had a very loud sounding lifter noise it seemed. From your video, it just sounds like the normal 5.7. It is new so you could bring it up to the dealers attention and have them look at it. Nothing to lose.
  27. Dec 16, 2021 at 10:09 AM
    mv133
    21 tundra SR5
    Brandy new
    got yah! Bringing it in tomorrow morning. My problem is i don’t trust anyone there going to keep it over night and give me a loaner so they can take a listen when it’s cold in the morning. Maybe I’m crazy but I’d rather have it looked at. My dad also has a tundra and it doesn’t make the sound mine does. If they pull some crap and tell me it’s because i have a cat back exhaust Im going to be mad
  28. Dec 17, 2021 at 8:08 AM
    mv133
    21 tundra SR5
    Brandy new
    So I go to the dealer this morning when I made the appointment I said I would like to speak to a mechanic before I check it in. The lady at the counter says yeah that’s not happening as I’m staring at 10 mechanics through glass window. I’m like really before i check it in let me just get someone’s opinion that knows something about these trucks !! So i walked the hell out after driving 45mins. People are so lazy why can’t i ask a tech a question!? Let the thing blow up i want to crash it through the show room floor.
  29. Dec 17, 2021 at 8:34 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    That's your normal 5.7 valve train noise.
    Try 5/30 and throw in a can of Ceratec.
    It'll go away and the engine will run even nicer.
  30. Dec 17, 2021 at 10:17 AM
    mv133
    21 tundra SR5
    Brandy new
    Someone said maybe a exhaust leak that it’s common ? I got asked if it was a diesel lol my buddy is a mechanic and he said he never heard a tundra sound like that it’s driving me nuts . But these last two days have been warmer in NJ and it hasn’t been as bad soooo idk. Here’s a video of a warmer weather cold start .. don’t worry bout it?
    https://youtu.be/rY8FBqho_6M
