This bugs me.
Discussion in '2nd Gen Tundras (2007-2013)' started by azimuth, Aug 15, 2021.
  1. Aug 17, 2021 at 9:05 PM
    McYoda
    McYoda H4x0r
    Brady
    Oregon
    2010 “Grade”
    What'd you lube the latches with? Glad it all worked out.
  2. Aug 17, 2021 at 9:44 PM
    azimuth
    azimuth [OP] New Member
    2010 double cab SR5
    I had some PB Blaster so I used that.
    McYoda[QUOTED] and 1lowlife like this.
  3. Aug 19, 2021 at 11:10 AM
    tnbndr
    tnbndr New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    I would have welded material on the latch and grind until it pulls tight, but whatever you did worked.
    Now, anyone done a mod to have an open tailgate light on the dash just like the door open warning? Can't tell you how many times I've driven with my tailgate down unintentionally.
  4. Aug 19, 2021 at 3:19 PM
    Dr_Al
    Dr_Al New Member
    Al
    I had one of the cables come unlatched when loading an ATV in the bed on my 1st gen and bent the tailgate. It was easy to straighten. No, I would not use a 2x4. Just unhook the cable on the side that lines up correctly. With the tailgate open and you standing in the bed start putting weight on the corner without the cable support. Don't get too ambitious and jump on it, just start off light and keep checking. Having a friend to close and open it to check it will speed it up. Now if there's plenty of rust back there I would leave it alone.
    McYoda likes this.
  5. Aug 20, 2021 at 9:53 PM
    Cg13055
    Cg13055 @yota.parts.distributor
    South Florida
    Mcfly Tundra @yota.parts.distributor
    2012’4.0 Tundra-2004’4.7 crewcab-2021 2.7 Tacoma
    I’ve noticed this I usually slam mine and it’s fine
  6. Aug 26, 2021 at 2:15 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Wheres follow pic?
  7. Aug 26, 2021 at 9:34 PM
    azimuth
    2010 double cab SR5
    Oh. Right. I'll get one in the morning.
