Thinking of Purchasing 2011 4wd w/38k miles-Is this typical wear?
Discussion in '2nd Gen Builds (2007-2013)' started by 4mm, Mar 17, 2024.
  1. Mar 17, 2024 at 2:52 PM
    4mm
    4mm [OP] New Member
    Francisco
    2015 Sequoia
    I found a crewmax in my area for $18k but unsure if the surface corrosion and wear matches a 38k mile one owner truck. I’ve read this gen suffers more rust issues than newer years.
    Do the following pictures show typical aging or wear for this truck?
    It also has a spacer front level kit which I believe would have to be removed.
  2. Mar 17, 2024 at 2:57 PM
    4mm
    4mm [OP] New Member
    Francisco
    2015 Sequoia
    Plus I would buy stock wheels with AT tires.
  3. Mar 17, 2024 at 2:58 PM
    LML 3500HD
    Where is the truck from? Is it a Texas truck or shipped out from the rust belt?
    It is a 13 year old truck, but it does seem a little excessive.
    ZappBrannigan and OldGuy03 like this.
  4. Mar 17, 2024 at 3:02 PM
    4mm
    4mm [OP] New Member
    Francisco
    2015 Sequoia
    South Texas and according to the CARFAX always serviced in south Texas. Here is an engine picture.
    ColoradoTJ likes this.
  5. Mar 17, 2024 at 3:05 PM
    LML 3500HD
    I would pass. It's like it was a beach cruiser that never was rinsed off after.
  6. Mar 17, 2024 at 3:06 PM
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    Take a hammer & tap the rust. That will tell you how bad it is.
    OldGuy03 likes this.
  7. Mar 17, 2024 at 3:16 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Looks good to me. Unlike fellows from areas with 0% humidity, I'm more worried about the suspension mods I saw.
  8. Mar 21, 2024 at 6:56 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I would tap all the heavily rusted areas with a hammer as well. Seems like just surface that could be cleaned up with a wire wheel. But the hammer will give you all the answers you need to know. For that price and mileage I would consider it. I would also get rid of the suspension mods and wheels. Like @ColoradoTJ said it was likely a beach truck which would make the rust seem normal even if the mileage is that low. But that doesn't mean it's a shit truck. Just might need a little tlc.
  9. Mar 21, 2024 at 7:12 AM
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    I have seen a lot worse I was going to say but put my glasses on and looked again. The bubbles in the bed would make me say run away. I am glad he didn't have a liner in it to hide that. I am surprised the bottom side of the truck isn't worse.
  10. Mar 21, 2024 at 7:15 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Good eye. Almost looks like someone tried to rattle can it to cover something?
  11. Mar 21, 2024 at 12:05 PM
    4mm
    4mm [OP] New Member
    Francisco
    2015 Sequoia
    I’m going to recheck that. It was drizzling that day and thought it was water.
    Lifer[QUOTED] and OldGuy03 like this.
  12. Mar 21, 2024 at 7:37 PM
    4mm
    4mm [OP] New Member
    Francisco
    2015 Sequoia
    Should the tie down loops at the rear be oem painted or bare metal?
  13. Mar 21, 2024 at 7:40 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    They come painted. But if they are used a lot the metal hooks from ratchet straps can wear them out. Nothing to worry about in my book. It's a throw away part in the whole scheme of things.
  14. Mar 21, 2024 at 8:42 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    That looks fairly beat up for those miles.
