Think I found the solution to the dim front turn signals on 18+
Discussion in '2.5 Gen Tundras (2014-2021)' started by thomasbus337, May 16, 2020.
  1. Jul 31, 2020 at 9:01 PM
    #211
    1794 PRO
    1794 PRO New Member
    Zach
    2015 Super White 1794 Tundra CM
    So I’ve contemplated doing this myself and I would just de-pin an old wiring harness I have laying around and cut the wire back far enough to give me enough length to add the pin to the center hole that was removed and then tap the other end to the marker bulb wire on the side of the headlamps, after all they are running lights. Buuuut I opted not to because I actually dig the headlights with just the DRL’s on. And as far as voiding your warranty that’s incorrect. That won’t void your warranty however if you brought the truck in for a problem like the light stopped working and I deemed it to be caused by the wire you tapped in, you would be responsible for the repair, not warranty.
  2. Aug 1, 2020 at 6:19 AM
    #212
    RoyL
    RoyL New Member
    2018 Tundra Limited Double Cab Silver Sky Metallic TRD Off Road
    None. Stock from the dealership.
    Hello Zach, you got me started on it again, I played with cars and trucks for over 50 years and got burned out on that heavy duty stuff, but a wiring job shouldn't be that difficult except for the connectors, which a parts house should have (I hope), next would be, which wire to tap into, YOU obviously know which one I need, I haven't unwrapped that loom yet, there has to be a s____ load of wires under there. Would you be so kind as to identify which one for me, PLEASE.
    I was prepared to pay the dealership for the addition until (Rich) said it would void my warranty. Then I dropped it. Now I'm cranked up again. The light is not a big deal, but it's there and I want to use it, just to be different.
  3. Aug 1, 2020 at 7:12 AM
    #213
    Snowcat4360
    Snowcat4360 New Member
    Derek
    2018 TRD Sport Crewmax
    Century topper, bed rug, ultimate rod case
    I already installed my bar with no issues and followed the instructions to a T, clipping the blue wire as stated. Are you saying that you cannot de pin and move the pin for brighter turn signals after installing per the NSV instructions? Or can I move it without issue?
  4. Aug 1, 2020 at 7:34 AM
    #214
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    If you repinned your factory harness to fix the turn signal, then later get the lightbar, you will need to restore your factory pinout, then on the nsv harness to the turn signal, cut the outer blue wire, then move the center wire back to the outer 28w filament. The harness expects factory wiring, but you can fix the turn signal at the nsv plug, the same way you originally fixed the factory plug.
  5. Aug 1, 2020 at 7:39 AM
    #215
    Snowcat4360
    Derek
    I have not re pinned yet or to clarify, moved the pin on the turn signal to the brighter location, but have already installed the bar with perfect function.
  6. Aug 1, 2020 at 7:49 AM
    #216
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Yes, it works fine if you haven't altered your factory plug or run leds. It's simply a reminder to anyone who has or gets their recall done that the nsv lightbar harness expects the original wiring and pinout
  7. Aug 2, 2020 at 8:32 AM
    #217
    SDNY
    SDNY New Member
    Castleton NY
    2024 Sequoia Sonic Red
    hello all, on this subject, I had my truck serviced at my dealer on Friday. After the service they had me schedule for two recalls on the truck. One being the fuel pump and the 2nd is for dim turn signals. So, there is a recall to change the wires around as discussed in the thread. Check with dealer for the recall and save yourself some time. Hope this helps out.
  8. Aug 9, 2020 at 2:51 PM
    #218
    KERNEL_DALE
    KERNEL_DALE New Member
    Norcal
    19’TRD-PRO
    Before the recall everything is perfect.
    After the recall remedy as what they told me that they unplugged my nsv harness. I noticed that when i replugged the nsv harness my front turn signal is not working and my left rear turn signal is hyperflashing.
    im so upset...
    does anyone experienced this scrnario also..
  9. Aug 9, 2020 at 2:56 PM
    #219
    Boyd8019
    Boyd8019 New Member
    Bob
    Las Vegas, NV
    2020 White Tundra TRD Sport
    BDS 7" lift, 20x10 Fuel "Lethal" wheels, 37x13.50R20 Cooper Discoverer STT PRO tires, AMP Research PowerStep XL electric running boards, Line-X spray in bedliner, 6" BAM Muffler from Dirty Deeds.
    It's elsewhere in this thread (?) I think you have to take it back to the way it was so that you can clip the blue wire so everything will work properly is what I've seen. (Post #216 above) @KERNEL_DALE
  10. Aug 9, 2020 at 3:03 PM
    #220
    KERNEL_DALE
    Norcal
    19’TRD-PRO
    Originally i did clip the blue as what the video said.
    do you mean i need to reattached it? The blue wire?
  11. Aug 9, 2020 at 3:10 PM
    #221
    Boyd8019
    Boyd8019 New Member
    Bob
    Las Vegas, NV
    The way I understand it is that you have to take the turn signal lights back to the way they were before the recall because the NSV light was designed to the way the truck was when it came from the factory. The NSV lightbar is expecting original wiring in order to work properly.
  12. Aug 9, 2020 at 3:12 PM
    #222
    Boyd8019
    Boyd8019 New Member
    Bob
    Las Vegas, NV
    @KERNEL_DALE If you were to repin your turn signal back to the way it was (prior to the recall fix) your NSV lightbar would work when you plugged it back in.
  13. Aug 9, 2020 at 3:15 PM
    #223
    KERNEL_DALE
    Norcal
    19’TRD-PRO
    Before recall everything is in placed and working just fine.
    if i removed the harness n put back the factory wire it all works. I just dont understand why after the so called remedy it turns out the left front turn signal not working and the rear turn left signal is hyperflashing
  14. Aug 9, 2020 at 3:22 PM
    #224
    Boyd8019
    Boyd8019 New Member
    Bob
    Las Vegas, NV
    Before the recall fix you had 2 wires coming out of a 3 wire capable plug. 1 on the right and 1 in the middle, resulting in a dim front turn signal. The recall only consists of taking the middle wire out and moving it over to the far left, giving you a bright front turn signal. Taking the wire from the outside hole and putting it back in the middle will result in a dim front turn signal but your NSV lightbar will work again. @KERNEL_DALE
  15. Aug 9, 2020 at 3:25 PM
    #225
    KERNEL_DALE
    Norcal
    19’TRD-PRO
    Is that the factory wire you mean? That connects to the nsv harness?
  16. Aug 9, 2020 at 3:25 PM
    #226
    Boyd8019
    Boyd8019 New Member
    Bob
    Las Vegas, NV
    @KERNEL_DALE If you follow this thread from the beginning (time consuming I know) it will walk you through the whole process. It is SUPER easy to do. Too bad we don't live closer I could show you easier than I can tell you how to do it.
  17. Aug 9, 2020 at 3:29 PM
    #227
    Boyd8019
    Boyd8019 New Member
    Bob
    Las Vegas, NV
    Not the wire that connects to the NSV harness, the wire that is in the plug for the turn signal. If you move it from the outside back to the middle and then plug your NSV light in again (don't make any other changes besides moving the wire in the plug over 1 slot) your NSV light will work again.
    Let me go take a pic of my plug end and I'll post it up so you can see it. BRB
    KERNEL_DALE[QUOTED] likes this.
  18. Aug 9, 2020 at 3:52 PM
    #228
    Boyd8019
    Boyd8019 New Member
    Bob
    Las Vegas, NV
    The black/white wires need to go back to the middle hole in order for your NSV lightbar to work again.
  19. Aug 9, 2020 at 3:54 PM
    #229
    Boyd8019
    Boyd8019 New Member
    Bob
    Las Vegas, NV
    @KERNEL_DALE Also see post #3 on page 1, post #67 on page 3, and post #106 on page 4 to help explain what I'm trying to say.
  20. Aug 9, 2020 at 3:58 PM
    #230
    KERNEL_DALE
    Norcal
    19’TRD-PRO
    U
    is that both left and right Front Turn signals
  21. Aug 9, 2020 at 4:01 PM
    #231
    Boyd8019
    Boyd8019 New Member
    Bob
    Las Vegas, NV
    The 1 with the bulb out is the driver side, the pink tint is the passenger side.
  22. Aug 9, 2020 at 4:34 PM
    #232
    KERNEL_DALE
    Norcal
    19’TRD-PRO
    Noted. Thank you so much..
  23. Aug 10, 2020 at 5:29 AM
    #233
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    I had my '19 Limited in for the fuel pump recall and the tech also applied a recall for the connector on the front right and left.
    MODIFY THE FRONT TURN SIGNAL LIGHT CONNECTOR LH & RH SIDES
    MODIFY THE FRONT TURN SIGNAL LIGHT CONNECTOR LH & RH SIDES ~|~20TA12 SAFETY (NONCOMPLIANCE) RECALL 20TA12 (REMEDY NOTICE) - CERTAIN 20 ~|~OPEN RECALL PER TIS ~|~MODIFY THE FRONT TURN SIGNAL LIGHT CONNECTOR LH & RH SIDES
    iHacker likes this.
  24. Aug 11, 2020 at 1:36 PM
    #234
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
    I just noticed my 2019 qualifies for the turn signal recall as well. Any idea was exactly they do to 'modify' the wire harness? Don't really want my harness getting hacked up with butt connectors. I may decline this recall unless I can get some solid info on what exactly it is they're doing to fix the issue.
  25. Aug 11, 2020 at 1:44 PM
    #235
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    They do exactly what is outlined in this thread - the harness gets repinned. No cutting/splicing.
    GODZILLA and Hoff like this.
  26. Aug 11, 2020 at 2:07 PM
    #236
    801Tundra
    UTAH
    Thanks - was being lazy and hadn't read thru the entire thread until now. Lots of good info here. Thanks @1794 PRO for sharing the tech instructions!
  27. Aug 11, 2020 at 3:08 PM
    #237
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    I thought there is a pending recall for this. At least there is in Canada. Apparently still waiting on parts.
  28. Aug 11, 2020 at 3:50 PM
    #238
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    ...what parts? or are you talking about the fuel pump recall?
  29. Aug 11, 2020 at 4:00 PM
    #239
    GCanuck
    Gary
    BC,Canada
    No I believe the wiring harness to fix the dim led turn signals.
  30. Aug 11, 2020 at 4:31 PM
    #240
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    No new harness needed, it’s just moving one wire on the existing harness
    GODZILLA and frostybrew4me like this.
