Think I found the solution to the dim front turn signals on 18+
Discussion in '2.5 Gen Tundras (2014-2021)' started by thomasbus337, May 16, 2020.
  1. Jul 21, 2020 at 10:43 AM
    #181
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    7443. Some bulbs don’t require a resistor. The bulbs I got from vled wound up not needing a resistor. This only applies if you have the oem led headlights.
    Tundyfundy likes this.
  2. Jul 21, 2020 at 7:18 PM
    #182
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Re-wired mine today. Thanks thomasbus337 for figuring this out, you saved me from almost buying some LED's, and now it seems a trip to the dealership. :hattip: Very easy fix and makes a huge difference in the brightness. :thumbsup: One thing i found is that its easier to push the rubber plug out from the inside with a paperclip rather than to try to pry it out from the outside. Thanks again.
  3. Jul 21, 2020 at 8:28 PM
    #183
    RustyPNW
    RustyPNW New Member
    Oregon
    2018 Cement Tundra SR5 CM TRD
    5100 middle setting, stock rears
  4. Jul 22, 2020 at 7:42 AM
    #184
    K9scout
    K9scout New Member
    2019 Tundra Trd Pro
    This worked out super easy. Thanks again for helping us all out.
  5. Jul 22, 2020 at 7:58 AM
    #185
    rrocke17
    rrocke17 New Member
    pete
    2020 Limited TRD Offroad Tundra
    Not sure if this is related, Juts had mine fixed via recall.::
    Vehicles Affected: Approximately 183,000 model-year 2018-20 Toyota Tundra pickup trucks
    The Problem: The wire harness connected to the front turn signal bulbs was assembled incorrectly, causing them not to illuminate as brightly as intended and increasing the risk of a crash.
    The Fix: Dealers will modify the wire harness connected to the front turn signal bulbs for free.
    What Owners Should Do: Toyota will begin notifying owners by late mid-September. Owners can call the automaker at 888-270-9371, the National Highway Traffic Safety Administration’s vehicle-safety hotline at 888-327-4236 or visit its website to check their vehicle identification number and learn more.
    14burrito and jdmek998 like this.
  6. Jul 22, 2020 at 3:10 PM
    #186
    ckyrux
    ckyrux New Member
    2019 Tundra Limited Crewmax TRD Off-Road
    Thanks for doing this. Mine didn’t show it needed it when I ran the vin but it was wired wrong and was always dim. I fixed it in 10 minutes. 2019 limited.
  7. Jul 22, 2020 at 3:44 PM
    #187
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Just did mine, took like 10 minutes, only because the passenger side is kind of tight to get to with the washer fluid tank in the way. Piece of cake and a huge difference in brightness
  8. Jul 25, 2020 at 9:40 AM
    #188
    daw5spd
    daw5spd New Member
    Dave
    Eastern Oregon (Greater Idaho)
    2019 Cement Off Road DC
    Undercover SE tonneau TRD Rear Sway Bar AJT trim pieces Console wireless charger Drivers side grab handle Meso lights
    Did mine this morning, 2019 OR. Really appreciate this forum.
  9. Jul 25, 2020 at 10:03 AM
    #189
    jdmek998
    jdmek998 New Member
    2021 Tundra Platinum
    I guess my 19 has the campaign open for this. It will be getting done next friday. I have leds in there now. Hopefully this fixes it. I was about to swap pins.
    14burrito and jewsNbrews like this.
  10. Jul 25, 2020 at 10:37 AM
    #190
    19Voodoomax
    19Voodoomax New Member
    Mark
    Dundee,Oregon.
    2023 Tundra TRD Pro
    After changing out the bulbs to a brighter LED we all find out that the reason for the dim light from the factory bulbs is a wire harness that was assembled incorrectly. I’m currently at the Toyota dealership for the Fuel Pump recall. The Service Advisor said that they were going to take care of the Wire Harness recall as well because apparently there is a remedy for it now. I didn’t bring my original bulbs that I took out. Maybe I can leave in the LED’s or they maybe will want to put originals back in. Will wait and see what the Service Advisor says.
    jewsNbrews likes this.
  11. Jul 25, 2020 at 12:17 PM
    #191
    Danman34
    Danman34 New Member
    Danny
    They won’t touch it if you have leds in there. Either put filament bulbs back in or do it yourself.
    14burrito likes this.
  12. Jul 25, 2020 at 6:03 PM
    #192
    19Voodoomax
    Mark
    Dundee,Oregon.
    2023 Tundra TRD Pro
    The dealership didn’t say anything about the LEDs They left in them in and took care of the wiring issue !
    jdmek998 likes this.
  13. Jul 26, 2020 at 3:14 PM
    #193
    Scavezze1971
    Scavezze1971 New Member
    Greg
    2018 SR5 Plus TRD Off-road (Canadian)
    Rewired my 2018 yesterday and it works like a champ. Wasn't going to wait until October, November. :)
  14. Jul 27, 2020 at 12:04 AM
    #194
    Boyd8019
    Boyd8019 New Member
    Bob
    Las Vegas, NV
    2020 White Tundra TRD Sport
    BDS 7" lift, 20x10 Fuel "Lethal" wheels, 37x13.50R20 Cooper Discoverer STT PRO tires, AMP Research PowerStep XL electric running boards, Line-X spray in bedliner, 6" BAM Muffler from Dirty Deeds.
    I rewired the plugs on my 2020 tonight. It was an incredibly easy fix. Thanks @thomasbus337 for the info and videos showing us how to do it.
  15. Jul 27, 2020 at 9:59 AM
    #195
    GreatBigAbyss
    GreatBigAbyss New Member
    2018 Tundra CrewMAX SR5 TRD Off-Road
    Did it myself over the weekend. It took 20 minutes, and was very easy. A couple of reasons I did it myself: I can, so I did. I don't trust the dealership to necessarily do even a simple task properly (I had visions of the min-wage kid they'd have doing the work losing the little rubber plugs and just shrugging, saying 'good enough'). The hassle of taking the truck to the dealership, taking the shuttle to work, being late to work, etc., would just have taken more time than doing the work myself.
    FTI likes this.
  16. Jul 27, 2020 at 11:40 AM
    #196
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Just swapped the wires over on my 2020 and they got much dimmer. Socket is wired exactly as the problem trucks... so I assume they went to a corrected bulb as a quick easy fix.
  17. Jul 27, 2020 at 11:42 AM
    #197
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Do you have some pics of your headlights? Not all 2018+ come with the LED headlight option, so it's possible this fix doesn't apply to your truck.
  18. Jul 27, 2020 at 12:00 PM
    #198
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    Thats probably it.
    Didnt realize the issue was isolated to only the LED headlamp equipped trucks.
    No biggie.
    Gave me an excuse to poke around under the hood a few mins.
  19. Jul 27, 2020 at 12:33 PM
    #199
    bigraz
    bigraz New Member
    The white locking tab on the bulb assembly didnt want to come apart easy for me and i wanted to avoid breaking it.used a tiny flat head but didnt seem to move at all
  20. Jul 27, 2020 at 1:21 PM
    #200
    Boyd8019
    Boyd8019 New Member
    Bob
    Las Vegas, NV
    Even though my truck is new, I had to "tug a little" at it to get it to come out. I used the tiny flat head to pop it past the 'locking tabs' then used a pair of needle nose pliers to remove from the plug assembly.
  21. Jul 27, 2020 at 4:08 PM
    #201
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    Done, very easy. Easier than the 100 mile round trip to the dealer.
  22. Jul 27, 2020 at 4:47 PM
    #202
    Do they look brighter or the same as before?
    Any hyperflash?
  23. Jul 27, 2020 at 7:40 PM
    #203
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Just did mine...however lost that stupid black rubber plug for a few minutes....found it under my truck halfway back:notsure:
  24. Jul 28, 2020 at 7:43 AM
    #204
    19Voodoomax
    Mark
    Dundee,Oregon.
    2023 Tundra TRD Pro
    They look the same as before. No hyper flask either.
  25. Jul 28, 2020 at 8:00 AM
    #205
    :thumbsup:
  26. Jul 28, 2020 at 9:31 AM
    #206
    RoyL
    RoyL New Member
    2018 Tundra Limited Double Cab Silver Sky Metallic TRD Off Road
    None. Stock from the dealership.
    Just got an Email from my dealership this morning about the turn signal recall, I called them and got an appointment for Friday, and I don't have to wait until September for it. Apparently they're busy, also going to do a safety check freebee at the same time. Referencing the parking light/directional signal thing, the bulb is dual filament, if they swap the wires that will still leave one filament unused (the one for the "old style" parking light) what do you think about wiring that filament to come on when the parking lights are turned on? I have no idea which wire to tap into (unless you guys know) so I thought I'd ask the dealership if they would recommend the change or not, and maybe even do it since they would be into it anyway. What do you think?
  27. Jul 31, 2020 at 8:41 AM
    #207
    RoyL
    RoyL New Member
    Dealership says anything YOU do to the wiring will void the warranty. Also he (Rich) was not to impressed with Toyota forums. So I dropped the whole conversation.
  28. Jul 31, 2020 at 8:43 AM
    #208
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I'd find a different dealership. And a service manager that understands how warranties work.
    GODZILLA, Hoff and jewsNbrews like this.
  29. Jul 31, 2020 at 9:32 AM
    #209
    RoyL
    RoyL New Member
    Now I want a second opinion. Any ideas as to where to go for that? I bought the truck new from them and had no reason to doubt them before now.
  30. Jul 31, 2020 at 8:44 PM
    #210
    1794 PRO
    1794 PRO New Member
    Zach
    2015 Super White 1794 Tundra CM
    The minimum wage lube kid wouldn’t be touching your truck. A safety recall is performed by a certified tech who cares a little more about attention to detail. At least I do.
