Think I found the solution to the dim front turn signals on 18+
Discussion in '2.5 Gen Tundras (2014-2021)' started by thomasbus337, May 16, 2020.
  1. Jun 10, 2020 at 5:25 PM
    #91
    Fish2eat88
    Fish2eat88 New Member
    Jay
    2018 silver sky double cab
    295/75 3/2 lift
    Just did mine. 18 double cab sr5 6 seater. Super easy n damn world of difference.
  2. Jun 10, 2020 at 7:08 PM
    #92
    Heloravy
    Heloravy 2018 TRD Sport
    Québec, QC
    2018 MGM Tundra TRD Sport
    I just did this on my 2018! What a difference! Thank you @thomasbus337
  3. Jun 10, 2020 at 7:36 PM
    #93
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Aries Side Bars, DeeZee low profile tool box, weathertech mats, TRD RSB
    Impressive!
  4. Jun 15, 2020 at 10:02 AM
    #94
    FLG8R71
    FLG8R71 New Member
    Jax FL
    2019 Voodoo Blue TRD Pro
    I've been looking into swapping my turn signal bulbs over to LED's before coming across this thread; I just finished doing this on my 2019 and man what a difference! Thank you @thomasbus337
    Fish2eat88 and EDDO like this.
  5. Jun 16, 2020 at 5:18 AM
    #95
    mkeegan27
    mkeegan27 New Member
    CT
    2018 platinum crewmax
    The problem is with the trucks equipped with LED headlights. When the headlights are on, oncoming cars can't see the turn signal because the headlights overtake the dim amber turn. I replaced mine with an led and it seems to be bright enough now. I may the the wire switch when feeling motivated one of these days!
  6. Jun 16, 2020 at 5:19 AM
    #96
    mkeegan27
    CT
    I also swapped in some led bulbs but am wondering how much brighter they will be if we switch the wires? Thought I saw someone say it was minimal but i'm not sure.
  7. Jun 16, 2020 at 7:04 AM
    #97
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I guess mine look good because I have the standard headlights (sorry, name escapes me right now) and I have no plans to swap them to LEDs.
    mkeegan27[QUOTED] likes this.
  8. Jun 16, 2020 at 1:29 PM
    #98
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Won't make a difference, same voltage, it's the filaments in the bulbs that are 8w or 28w, led is getting same 12v power regardless.
    Fish2eat88 and mkeegan27[QUOTED] like this.
  9. Jun 17, 2020 at 8:20 AM
    #99
    phabej
    phabej New Member
    Washington
    2018 Platnium
    I replaced mine with LEDs a while back before this mod "hack correction" came out. I like my LED it matches my LED head lamps and LED fogs, all LED. :D
    I wouldn't change it, I can see the blinker reflecting off street signs across 4 lane traffic.
  10. Jun 17, 2020 at 8:24 AM
    #100
    thomasbus337
    thomasbus337 [OP] New Member
    2020 TRD Sport DC
    Yeah, if you’ve already upgraded to LED then this wiring change won’t be needed
    Flyinryank likes this.
  11. Jun 19, 2020 at 12:44 AM
    #101
    Fish2eat88
    Jay
    295/75 3/2 lift
  12. Jun 19, 2020 at 3:36 AM
    #102
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    I find that sticking my arm out the window of my two year old truck and pointing towards the direction in which I intend to turn helps as well.. :rofl:
    But seriously.. will do this mod as well. Thanks for the info!
    GODZILLA likes this.
  13. Jun 19, 2020 at 4:30 AM
    #103
    thomasbus337
    2020 TRD Sport DC
    Damn, that’s a better comparison vid than mine, that would be the one I’d show to Toyota! Thanks for sharing
  14. Jun 19, 2020 at 7:48 AM
    #104
    7dgoat
    7dgoat Member
    NJ
    2025 Terra Platinum Off-road
    Great fix!!!!!! This is why I visit the forums!!!!
  15. Jun 21, 2020 at 4:35 PM
    #105
    Fish2eat88
    Jay
    295/75 3/2 lift
    You can use it whenever man Thanks for your knowledge
    Tundra805 and GODZILLA like this.
  16. Jun 23, 2020 at 1:08 PM
    #106
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Just a note for anyone repinning their turn signal. If you get an NSV lightbar, your going to have to return your factory turn light plug wiring back to original, then rewire the NSV plug that T's into your factory headlight plug, removing the blue wire and shifting the center wire to the outside hole again to use the 28w filament. This is for 2014-2019 with DRL & LED. I was blowing 10A tail light fuse, no DRL, no motor, no side lights till I figured it out.
    silverhack likes this.
  17. Jun 23, 2020 at 1:18 PM
    #107
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    I'll add to that, that their instructions call out 2014-19 DRL LED you have to cut the blue wire at the turn signal plug, anyone that has shifted pins because of weak turn signals will need to do this, can't speak to every model tundra. Other than the blue wire gets cut or unpinned.
  18. Jun 27, 2020 at 1:59 PM
    #108
    GREENwithENVY
    GREENwithENVY New Member
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Yep, did mine a minute ago - took about an hour. I don't have the smallest hands, so had to make some room. On the pax side, I removed the three bolts holding the windshield washer reservoir and slid it back a bit. On the driver's side, I loosened the battery hold down and slid it to the left. The reason it took me an hour was I'd reinstalled the pax side and looked on top of my tool box and saw the white plastic lock, so after some choice words, I had backtrack a bit. Worth the time and the few cuss words...Thanks to the OP.
    [An removal-install note for the rubber butt plug on the connector - I found it super simple to use the smallest jeweler's screwdriver, enter the EMPTY socket hole from the connector face and push the rubber plug out (better than trying to flip it out from the back and throwing it across the engine) and on the reinstall, BEFORE you move the pin to the outboard end of the plug, put the rubber plug back into the connector, then reinstall the pin. I found it to give me a bit more room...and didn't drop the damn thing.]
    EDDO likes this.
  19. Jun 27, 2020 at 2:14 PM
    #109
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Did mine the other day just like you GREEN. unmount the washer fluid and slid the battery over. Now they're bright like my '14 was.
    EDDO likes this.
  20. Jun 29, 2020 at 1:55 PM
    #110
    Krispy247
    Krispy247 New Member
    New York
    2018 Tundra white platinum
    Great info. Thanks. This was probably one of my most unhappy tundra moments. knowing I'm using my directional & no one knew I was trying to turn. 1st problem that had to be fixed. (I'm not goin to get into the " premium sound system "") LoL... Thank you! even tho I had previously installed the LED's. Great post....
  21. Jun 29, 2020 at 3:02 PM
    #111
    NoCoToyo
    NoCoToyo New Member
    Northern Colorado
    2019 Long Bed 4x4
    it's coming
    Although cool to fiddle around with, swapping the wire on a '19 SR makes them dimmer...
  22. Jun 29, 2020 at 3:06 PM
    #112
    thomasbus337
    2020 TRD Sport DC
    Yeah, this modification isn't needed on the models with just the LED DRL's
  23. Jun 29, 2020 at 3:09 PM
    #113
    NoCoToyo
    NoCoToyo New Member
    Northern Colorado
    2019 Long Bed 4x4
    it's coming
    [Off topic] Just installed OEM fog lights, and aside from the fog harnesses pre-wired, I saw two other harnesses/plugs hanging loose behind bumper. Any ideas? Parking sensor?
  24. Jun 29, 2020 at 3:24 PM
    #114
    TTund16
    TTund16 New Member
    Someone needs to figure out how the dim turn signals on certain models passed NHTSA tests and/or requirements!
    don't lights need to pass some visibility and brightness tests?
    How did Toyota get away with that if the lights are too dim?
  25. Jun 29, 2020 at 4:07 PM
    #115
    thomasbus337
    2020 TRD Sport DC
    I guess we would also have to know who does the certification for the lights, is it the headlight manufacturer or Toyota? If the headlamp maker tests them off the truck using their own wiring setup then they will work properly. The problem is when they are mounted on the truck that has been using the same 3 pin plug and wiring configuration since 2014
    rebmo likes this.
  26. Jun 29, 2020 at 8:29 PM
    #116
    Tundra805
    Tundra805 Quality. Durability. Reliability.
    Tennessee
    2020 CrewMax SR5 TRD 4x4 5.7 Cement
    @thomasbus337
    Dude. You are the man! Thank you so much for all this information, research and videos. I was reading it all and thought "oh wow, this is gonna be gnarly!" – I just finished doing the wire swap (15 minutes) and bam! I have bright front amber turn signals that people can actually see!
    I did mess up and leave the white clips out but took three minutes to go back in and re-install them.
    Thank you again. I am so grateful for this forum and people like you that help us all.
    TTund16 likes this.
  27. Jun 29, 2020 at 9:28 PM
    #117
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I think I'm going to give this a try - I already have JDM Astar LEDs swapped in, but it looks like they're 2 stage bulbs, so I might be able to get a little more juice out of them with this mod. I'll give it a try tomorrow and report back.
    I think LEDs themselves appear brighter without the mod because they're getting installed in a reflective housing meant for halogens.. right?
  28. Jun 30, 2020 at 9:30 AM
    #118
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Just did the pin swap and it definitely appears to have helped with the Astar's, but it's hard to tell how much in the day time. Can't wait to blind some people at night now.
  29. Jun 30, 2020 at 5:00 PM
    #119
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Damnit... started getting hyperflash on the passenger side after driving around a bit. Not sure why it's only happening on one side... now I'm torn between swapping the pins back or putting the old halogen bulbs back. I might get resistors eventually.
  30. Jul 6, 2020 at 1:05 PM
    #120
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Well, one of my coworkers was confirmed with Covid last week. So we’re back to working from home until we can all go get tested. So I figured ide knock this out this morning. I have vled leds in the turn signals. I may notice an ever so slight increase in brightness when I compared one to the untouched other. But then again it’s hard to determine intensity in the daylight. Guess I’ll have to see how it looks at night.
