Think I found the solution to the dim front turn signals on 18+
Discussion in '2.5 Gen Tundras (2014-2021)' started by thomasbus337, May 16, 2020.
  1. May 27, 2020 at 3:15 PM
    #61
    TTund16
    TTund16 New Member
    Sounds like based on what you are saying, any 18+ Tundra with LED headlights option from the factory will have dim turn signals. Is that right?
  2. May 27, 2020 at 3:16 PM
    #62
    thomasbus337
    thomasbus337 [OP] New Member
    2020 TRD Sport DC
    That appears to be the case, yes.
    BlueBottle and TTund16 like this.
  3. May 27, 2020 at 9:54 PM
    #63
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Having crappy luck lately lol. New replacements for the turn signal plugs coming in friday, grabbed a set of oem tow mirrors and passenger mirror was broken in shipment20200527_074655.jpg
  4. May 28, 2020 at 12:27 AM
    #64
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I wonder if the lower voltage was to add longevity to the bulbs or maybe to prevent damage to the housing from heat.
    TTund16 and Cpl_Punishment like this.
  5. May 28, 2020 at 7:18 AM
    #65
    thomasbus337
    2020 TRD Sport DC
    The owners manual lists the appropriate bulb as a 28w bulb so that's what they intended us to have. I'd be concerned about heat if the 28w portion was being used as a DRL like it was on the older models.
    EDDO likes this.
  6. May 28, 2020 at 11:35 AM
    #66
    taipan101
    taipan101 New Member
    Great information here! I have a 2020 Crewmax with factory led and it is wired incorrectly as thomasbus337 had pointed out.
    I tried to make the switch however was stumped by the lack of slack of the wiring. The white wire that goes into the socket is extremely short.
    Please share as to how to go about completing this modification. Thanks.
  7. May 28, 2020 at 11:59 AM
    #67
    thomasbus337
    2020 TRD Sport DC
    I did mine with the front grille and headlight housings removed from the truck. Here’s a short vid I made using one of my mock wiring harnesses
    https://youtu.be/L2vhE2GmlnY
  8. May 28, 2020 at 12:47 PM
    #68
    TTund16
    TTund16 New Member
    I recall some threads about the discoloration due to heat. Not sure if there was any other damage besides that. Need to search the site.
    My '16 DRL and turn signal share the same 28W and it feels pretty warm if I am idling for a while (no air flow). It doesn't get too hot here but not sure about TX heat plus the DRL heat plus the sun ...
  9. May 28, 2020 at 1:19 PM
    #69
    thomasbus337
    2020 TRD Sport DC
    I’ve seen the discoloration on the older models with the 28w amber DRL, but the discolor was on the bulb socket itself, and these units only use the bulb for turns
    EDDO likes this.
  10. May 28, 2020 at 7:57 PM
    #70
    CyberViking
    CyberViking New Member
    The Ozarks
    2018 MGM Tundra TRD Sport
    I really need to try this.
  11. May 29, 2020 at 6:39 AM
    #71
    rj1022
    rj1022 New Member
    RJ
    2016 Tundra TRD Pro Crewmax MGM
    I did it to my 20 TRD pro yesterday. It only took 10min (I unbolted the top of the washer resivour to allow a little more room for the passenger side) but Much brighter now
    7dgoat, GODZILLA and jewsNbrews like this.
  12. May 30, 2020 at 12:16 PM
    #72
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    @thomasbus337
    Thank you for first pointing out a problem I didn’t know I had then a free, easy solution to it. I shifted the WW reservoir and the battery out of the way to make room. I hereby nominate this thread for a sticky. :thumbsup:
    Fish2eat88 and rebmo like this.
  13. May 30, 2020 at 12:44 PM
    #73
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    For anyone that doesn’t know @thomasbus337 trust me he knows his shit. His evidence points what he said is true. Toyota USA needs to see this and acknowledge it. Maybe even fire the engineer responsible for this and hire @thomasbus337 lol. I’m serious how can they miss this. Signals are always supposed to use the brighter filament on a dual filament bulb. No matter a park light function is used or not.
    On my 2016 platinum. I had led drl and I upgraded to the 18+ led headlights. I used @thomasbus337 write up to make my wiring harness. This was before it was available for sale. I do recall what I did with my turn signals. I kept mine stock wiring because I used my original ck socket w vled bulb. If I was to swap to the 18+ socket I remember I had to swap the pins. So it looks like Toyota forgot to swap pins when they moved on to the new socket style. Is that right @thomasbus337 ?
    thomasbus337[OP] likes this.
  14. May 31, 2020 at 4:40 PM
    #74
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Is this only a problem in the U.S. due to different DRL laws? I had my dad and brother take a look at my truck too and they both said my turn signals are sufficiently bright in the stock configuration.
  15. Jun 1, 2020 at 7:30 PM
    #75
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Replaced my plugs and wired up to 28w filament. Dramatic improvement, thnx for the useful/simple fix!
  16. Jun 2, 2020 at 4:02 AM
    #76
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    What about 2018 SR5 that came with single LED DRL/awful halogen HL?
    I switched those out to 2019 TRD Pro LED’s... should I check this?
  17. Jun 2, 2020 at 5:22 AM
    #77
    thomasbus337
    2020 TRD Sport DC
    When you converted the lights did you use a turn signal adapter or re-pin or did you unplug from the one and plug in the other?
  18. Jun 2, 2020 at 5:31 AM
    #78
    DvilleMafia
    DFW
    2018 Tundra SR5 4x4
    Adapter from iHacker (think that’s his name)
  19. Jun 2, 2020 at 5:34 AM
    #79
    thomasbus337
    2020 TRD Sport DC
    If you used this harness setup with the small plugs in the center of the pic then you are all set. These adapters have the pins in the correct spot
    DvilleMafia likes this.
  20. Jun 2, 2020 at 1:06 PM
    #80
    TTund16
    TTund16 New Member
    That means adapter makers know their stuff. They also look nicely built like from Toyota factory. :thumbsup:
  21. Jun 2, 2020 at 1:10 PM
    #81
    thomasbus337
    2020 TRD Sport DC
    Yes, we figured it out while planning this retrofit harness back in the Fall of 2017
    TTund16[QUOTED] likes this.
  22. Jun 2, 2020 at 1:17 PM
    #82
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @thomasbus337 figured this out! I built my harness thanks to him.
  23. Jun 5, 2020 at 9:27 AM
    #83
    ACEMAN4
    ACEMAN4 New Member
    Louisiana
    2019 Midnight Black Metallic 5.7L Crewmax TRD Sport 4x4
    Did this mod works great Thanks for sharing
  24. Jun 5, 2020 at 10:35 AM
    #84
    TRDThirstyPRO
    TRDThirstyPRO New Member
    Tom
    New York
    2020 TRD pro
    Awesome stuff, took 10 min . Difference is definitely noticeable. Thank you @thomasbus337
  25. Jun 5, 2020 at 10:49 AM
    #85
    Critical05
    Critical05 New Member
    2018 MGM TRD Sport, Crewmax 4x4
    Out of curiosity, tried this mod on my upgraded LED Lasfit 7443 turn signals bulbs. The switching of the terminals did not increase their brightness.
    Also now figured out why Amazon wrongly suggested a 3157 bulb for my 2018 with factory LED headlights.
  26. Jun 8, 2020 at 7:22 AM
    #86
    Tumbler
    Tumbler New Member
    2023 CrewMax Limited HV in MGM
    It won't change anything with other bulb types because the voltage supply is the same in either arrangement, it is the bulb that dictates the brightness. In the case of the OEM bulb there are 2 filaments each of which illuminates based on its characteristics when 12V is applied. In the case of the LED it is the same bulb arrangement pulling from one or the other of the terminals (seems like both if it works in both arrangements) so with the same voltage applied the illumination would not change.
    Boerseun and Cpl_Punishment like this.
  27. Jun 8, 2020 at 8:48 AM
    #87
    Critical05
    That was my initial thoughts as well. Then I thought there might be two brightness levels since the red version are used for parking/brake lights. Maybe they engineered this out for their amber lights or maybe I need to power both terminals (center and outside) to get extra super bright turning signals. Although these lasfits are bright enough, I don't need to short something out by trying to power both terminals.
  28. Jun 10, 2020 at 7:49 AM
    #88
    HARPER306
    HARPER306 New Member
    SK, Canada
    2020 Voodoo TRD Sport CM
    Just did this last night, took all of 5 minutes and works great thanks!
    As a side note, the harness has little plastic clips that clip the harness to the frame, you can pull the harness a bit to release the clip and gain a little extra to make the job easier. I unbolted my washer reservoir for the passenger side but was able to do the driver side without touching the battery
  29. Jun 10, 2020 at 10:47 AM
    #89
    Fish2eat88
    Fish2eat88 New Member
    Jay
    2018 silver sky double cab
    295/75 3/2 lift
    I thought all 2018 had Led HL from factory?
  30. Jun 10, 2020 at 11:14 AM
    #90
    thomasbus337
    2020 TRD Sport DC
    They all have LED DRL’s but the LED headlights are standard only on the higher trims or certain option packages on the SR5’s
